Mike Whisky
Posted: Thu Jul 28, 2011 11:54 am Post subject: 5inch before and after redcube fuel-transducer |
Hello
For those who installed the redcube fuel transducer which comes with AFS did you manage to allow a straight line 5in before and after the redcube. If not do you still have accurate readings of fuel flow?
Cheers
Michael
_________________ RV-10 builder (flying)
#511 |
Posted: Thu Jul 28, 2011 2:38 pm Post subject: 5inch before and after redcube fuel-transducer |
Make the inlets and outlets as straight as you can but I've seen 90s
screwed into each end and it still worked fine. IIRC the outlet is
the most critical.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Thu, Jul 28, 2011 at 12:54 PM, Michael Wellenzohn
<rv-10(at)wellenzohn.net> wrote:
Hello
Cheers
Michael
RV-10 builder (interior,avionics, wiring)
#511
http://forums.matronics.com/viewtopic.php?p=347945#347945
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Thu Jul 28, 2011 3:02 pm Post subject: Re: 5inch before and after redcube fuel-transducer |
And put it between the servo and the spider. I have 45's on each side of my cube. Great accuracy.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
maca2790
Posted: Thu Jul 28, 2011 3:52 pm Post subject: Re: 5inch before and after redcube fuel-transducer |
I have put mine in the Position provided by Vans in the QB Fuselage I received. It's about 7 inchs from the Andair Pump I have Installed and I will most likley run the outlet to a lower postion on the firewall where I will place a Gascolator.
cheers
John MacCallum
VH-DUU
Posted: Thu Jul 28, 2011 5:13 pm Post subject: 5inch before and after redcube fuel-transducer |
John, why a gascolator? How are you going to get to it to sump it???
Linn
On 7/28/2011 7:52 PM, maca2790 wrote:
cheers
John MacCallum
VH-DUU
http://forums.matronics.com/viewtopic.php?p=347957#347957
Kelly McMullen
Posted: Thu Jul 28, 2011 8:53 pm Post subject: 5inch before and after redcube fuel-transducer |
Some countries seem to believe that a gascolator is necessary for both
carbureted and injected engines and thus require one.
On Thu, Jul 28, 2011 at 6:09 PM, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Linn
> cheers
> John MacCallum
> VH-DUU
A&P/IA, EAA Tech Counselor
KCHD |
maca2790
Posted: Fri Jul 29, 2011 2:05 pm Post subject: Re: 5inch before and after redcube fuel-transducer |
I believe it is an advantage to have a water Trap in the System as well.
I'm not sure if it is required in Australia but I will check with my Tech Counselor next week when he visits. I bought an extension tube for the Bowl and hope to drain it through a hole in the cowl such as on the 172 SP I have been flying lately.
>John, why a gascolator? �How are you going to get to it to sump it???
>Linn
Posted: Fri Jul 29, 2011 3:27 pm Post subject: 5inch before and after redcube fuel-transducer |
My understanding is there is no path for water to gravity flow to a
gascolator in most low wing aircraft. The water in the fuel tank collects
at the low point. For RVs that is at the fuel tanks sump as water cannot go
up hill via the fuel line, even if the gascolator is lower than the bottom
of the tank. Water entrained in the fuel as fuel is flowing may have a
small fraction separate in the gascolator, but the majority will remain
entrained. I do know however that the Andair gascolator filter screen meets
the requirement for the AFP fuel injection system.
Carl
maca2790
Posted: Sat Jul 30, 2011 2:53 pm Post subject: Re: 5inch before and after redcube fuel-transducer |
Re water suspended in the fuel I don't know either if the Andair Gascolator
will remove it. I will follow up with Andair and see what they say.
cheers
John MacCallum
Mike Whisky
Posted: Sun Jul 31, 2011 9:29 am Post subject: Re: 5inch before and after redcube fuel-transducer |
Thanks for your replies.
From what I understand now based on your feedback it shouldn't be a risk to install the redcube in the tunnel but should try to leave some straight line at the output of it.
Well I'll do my measurements then and order Bonaco Teflon lines.
Michael
#511 |
Posted: Sun Jul 31, 2011 11:45 am Post subject: 5inch before and after redcube fuel-transducer |
Michael,I have been following the thread but am not completely up to date on the last conversations since I have been flying X-County back from OSH.
That being said I strongly recommend you do not install the cube in the tunnel. I think the general consensus is that it is more important to install it between the fuel server and the spider than having 5" in/out of the cube.
I had mine in the tunnel and could not get a steady reading on my FP. This made it impossible to refine my LOP flying and it also consistently set off my Low FP alarm because the reading bounced so much during straight & level flight. When I finally relocated the cube to the above detailed location the readings became rock solid and I have not had a single Low PF warning since.
Good luck,
Robin
On Sun, Jul 31, 2011 at 10:29 AM, Michael Wellenzohn <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)> wrote:
[quote]--> RV10-List message posted by: "Michael Wellenzohn" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
Michael
#511
http://forums.matronics.com/viewtopic.php?p=348168#348168
le, List Admin.
Mike Whisky
Posted: Sun Jul 31, 2011 2:42 pm Post subject: 5inch before and after redcube fuel-transducer |
Mike,
Sorry no photos but the location is specific to your firewall forward.
In my case I have forward facing cold induction. Basically we found a
place where we were able to fabricate a small bracket to support the
cube and ran our line out of the servo with a straight shot into the
cube then as much of a straight out till the tube turns up towards the
spider.
I suggest you sit underneath your engine and hold the cube till you
find the best place understanding where you are coming from and where
you need the line to go. Some people leave the cube unsupported but I
preferred it to be supported and tied to something substantial.
Good luck,
Robin
Sent from my iPad2.
On Jul 31, 2011, at 2:00 PM, "Mike Whisky" <rv-10(at)wellenzohn.net> wrote:
Robin,
Thanks for your feedback, how and where exactly did you mount the red cube? Pictures would be appreciated.
Looks like I was the only one not being in Osh this year
Mike [Wink]
RV-10 builder (interior & finishing)
#511
http://forums.matronics.com/viewtopic.php?p=348182#348182
bill.peyton
Posted: Mon Aug 01, 2011 5:47 pm Post subject: Re: 5inch before and after redcube fuel-transducer |
While I have read that some have decent results from mounting the FP sensor in the tunnel between the electric and mechanical fuel pumps, I would not recommend it. As Robin stated, the readings will fluctuate wildly due to the interaction between the pumps. I have personally seen this on several installations, both carburetor and injected. As long as you mount it after the mechanical pump and leave a couple of inches of straight they seem to work fine. Putting it between the servo and the spider is a good example of this. Making a bracket and supporting the hose leading to and away from the cube is also important.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Mike Whisky
Posted: Tue Oct 04, 2011 12:14 pm Post subject: Re: 5inch before and after redcube fuel-transducer |
Hello all,
I thought I´d post my solution of the position of the fuel flow sensor (red cube). For those who are looking for an alternative position.
I need to order now new fuel lines and will then finally attach the bracket to the engine case and safety wire the bolts.
90.03 KB |
14915 Time(s) |
91.2 KB |
14915 Time(s) |
#511 |
