		cjaviator(at)gmail.com Guest
				 Posted: Tue Jul 26, 2011 7:59 pm    Post subject: Rocket Lord Engine Mount P/N? |
				Hi all,
  I am new to this list and am looking after an engine change on another Lister's Rocket.
 A couple of the engine mount rubbers are perished and I am after the P/N used as the aircraft and  original rubbers are not in the same locality as me!
   The gentleman who originally built the aircraft kindly lists the P/N in the logbooks but they are somewhat unreadable.
  Numbers look to be 7763-48 and J9612-8
  Engine is a Lyc IO-540-C4-B5
 Any assistance here as to what the correct P/N for this set up is would be greatly appreciated.
  Regards, Jay
  JEM Aviation Ltd
  NZ
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		stuart(at)stuarthutchison Guest
				 Posted: Wed Jul 27, 2011 5:08 am    Post subject: Rocket Lord Engine Mount P/N? |
				G'day Jay,
  They'll probably be the same as the Aztec C4B5 mount,  which are Lord J-9613-12 for later model PA23-250.
  I'm using Barry Mount 94011-02, same part # at Aircraft  Spruce.
 Kind regards,  Stu
 F1 Rocket    VH-FLY        http://www.mykitlog.com/RockFLY      [url=about:www.teamrocketaircraft.com]www.teamrocketaircraft.com[/url]
    From: owner-rocket-list-server(at)matronics.com  [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Jay  McIntyre
 Sent: Wednesday, July 27, 2011 1:57 PM
 To:  rocket-list(at)matronics.com
 Subject: Rocket Lord Engine  Mount P/N?
  Hi all,
  Regards, Jay
  JEM Aviation Ltd
  NZ
 href="http://www.matronics.com/Navigator?Rocket-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
		swaneymj
				 Posted: Wed Jul 27, 2011 9:28 am    Post subject: Rocket Lord Engine Mount P/N? |
				I talked with an engineer at Lord a few years ago and this is what he said:
 "The J-9613-12 has a "compression" sandwich and a
 "tension" sandwich on each side of the engine mount - the compression
 side takes the 1G weight of the overhanging engine. That's why the
 sandwiches are reversed top to bottom. I wouldn't normally recommend
 flying negative g's with this arrangement since the engine motion will
 be higher upside down, but if Team Rocket recommends them and everyone is happy with it, it may be OK. It's a softer system than the
 J-7764-31, which has compression sandwiches all around, so you'll get
 better vibration isolation.
 Our distributor, Herber Aircraft Services (800-544-0050), may have both
 parts in stock - ask for Ryan, she's very helpful.
 Paul Snyder"
 They recommend the J-7764-31 if you're going to do inverted aerobatics.
 Mark S.
 On Jul 27, 2011, at 06:06 AM, Stuart Hutchison <stuart(at)stuarthutchison.com.au> wrote:
  	  | Quote: | 	 		       G'day Jay,
 Kind regards,  Stu
 F1 Rocket    VH-FLY        http://www.mykitlog.com/RockFLY      www.teamrocketaircraft.com
  Hi all,
  Regards, Jay
  JEM Aviation Ltd
  NZ
  _________________ Thanks,
Mark Swaney
F-1 Rocket #31, N76TR |
		sprocket(at)vx-aviation.c Guest
				 Posted: Sat Jul 30, 2011 7:50 am    Post subject: Rocket Lord Engine Mount P/N? |
				I just went through all of this, including calling Lord, asking for  recommendations from reputable sources and searching all of the on-line  resources that I could.
  I finally decided that the Lord J-9613-12 was the appropriate one.
  Some folks (including Mark Frederick) recommended the Barry mounts due to  price, others (Aero Sport, many others) recommended Lord for quality.
    V
   From: Stuart Hutchison (stuart(at)stuarthutchison.com.au)
  Sent: Wednesday, July 27, 2011 6:06 AM
  To: rocket-list(at)matronics.com (rocket-list(at)matronics.com)
  Subject: RE: Rocket Lord Engine Mount  P/N?
   G'day Jay,
 Kind regards,  Stu
 F1 Rocket    VH-FLY        http://www.mykitlog.com/RockFLY       [url=wlmailhtml:www.teamrocketaircraft.com]www.teamrocketaircraft.com[/url]
  Hi all,
  Regards, Jay
  JEM Aviation Ltd
  NZ
 No virus found in this  message.
 Checked by AVG - www.avg.com
 Version: 10.0.1390 / Virus  Database: 1518/3787 - Release Date: 07/25/11
