byronmfox(at)gmail.com Guest
Posted: Tue Jul 26, 2011 9:06 am Post subject: Phillips 25-60 Oil |
Recently removed the banjo fitting from the air compressor on our M14P with 108 hrs SMOH. Discovered that valve and fitting were very congested with carbonized oil residue. Obviously, the oil had become overheated and broke down. M
Posted: Tue Jul 26, 2011 9:49 am Post subject: Phillips 25-60 Oil |
Oops. Sent before I was done.
Engine oil temp. always in the normal range.
Has anyone experienced this event with Phillips 25-60?
Thanks, Blitz
On Jul 26, 2011, at 10:03 AM, Byron Fox <byronmfox(at)gmail.com> wrote:
brian(at)lloyd.com Guest
Posted: Tue Jul 26, 2011 9:57 am Post subject: Phillips 25-60 Oil |
On Tue, Jul 26, 2011 at 10:45 AM, Byron Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: Byron Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)>
No, or at least not any more than any other mineral-oil based lubricant. Synthetics can handle higher temperatures.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
Posted: Tue Jul 26, 2011 9:59 am Post subject: Phillips 25-60 Oil |
Happens regardless of what type of oil you use. I wouldn't condemn the
oil unless you know positively that the output check valve on the
compressor was new or "overhauled" when you installed the engine? Just
for grins, clean it up making sure the little spring that presses the
little valve in place is also in good shape and the valve moves easily
with just the push of a pencil eraser; install new crush washers and
remove it again at the next 100 hours and see what it looks like.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 7/26/2011 12:45 PM, Byron Fox wrote:
Thanks, Blitz
> Sent from my iPhone
Posted: Tue Jul 26, 2011 11:20 am Post subject: Phillips 25-60 Oil |
Thanks, Dennis, I'll do as you suggest. When asked, Vladimir assured me that the compressor had been "overhauled" when the engine was. I did clean and check the valve and its spring, but reused the crush washers. Do you know a source for these? ...Blitz
On Tue, Jul 26, 2011 at 10:57 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
| Quote: | --> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Happens regardless of what type of oil you use. I wouldn't condemn the oil unless you know positively that the output check valve on the compressor was new or "overhauled" when you installed the engine? Just for grins, clean it up making sure the little spring that presses the little valve in place is also in good shape and the valve moves easily with just the push of a pencil eraser; install new crush washers and remove it again at the next 100 hours and see what it looks like.
Dennis
A. Dennis Savarese
[url=tel:334-285-6263]334-285-6263[/url]
[url=tel:334-546-8182]334-546-8182[/url] (cell)
Skype: Yakguy1
www.yak-52.com
| Quote: | --> Yak-List message posted by: Byron Fox<byronmfox(at)gmail.com (byronmfox(at)gmail.com)>
Thanks, Blitz
On Jul 26, 2011, at 10:03 AM, Byron Fox<byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
le, List Admin.
... Blitz
Byron M. Fox
80 Milland Drive
Mill Valley, CA 94941
415-307-2405
dougsappllc(at)gmail.com Guest
Posted: Tue Jul 26, 2011 11:32 am Post subject: Phillips 25-60 Oil |
Blitz
We stock ky2 overhaul pts
Call me.
Doug On Jul 26, 2011 12:23 PM, "Byron Fox" <byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:> Thanks, Dennis, I'll do as you suggest. When asked, Vladimir assured me that
| Quote: | check the valve and its spring, but reused the crush washers. Do you know a
| Quote: | >
| Quote: | > up making sure the little spring that presses the little valve in place is
| Quote: | > and see what it looks like.
> Dennis
> A. Dennis Savarese
> 334-285-6263
> 334-546-8182 (cell)
>> Skype: Yakguy1
| Quote: | >> Oops. Sent before I was done.
| Quote: | >> Thanks, Blitz
>> Sent from my iPhone
| Quote: | >> --> Yak-List message posted by: Byron Fox<byronmfox(at)gmail.com (byronmfox(at)gmail.com)>
| Quote: | >>> with carbonized oil residue. Obviously, the oil had become overheated and
>>> broke down. M
| Quote: | >>> Sent from my iPhone
| Quote: | >
... Blitz
Byron M. Fox
80 Milland Drive
415-307-2405
Posted: Tue Jul 26, 2011 11:53 am Post subject: Phillips 25-60 Oil |
Sorry Doug. I didn't know you stocked them or I would certainly have
said to call you.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 7/26/2011 2:29 PM, doug sapp wrote:
Blitz
Call me.
Doug
me that
clean and
know a
> dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>> wrote:
the oil
compressor was
clean it
place is
a pencil
100 hours
>> Dennis
>> A. Dennis Savarese
>> 334-285-6263
>> 334-546-8182 (cell)
>> Skype: Yakguy1
>> www.yak-52.com <http://www.yak-52.com>
>>> Thanks, Blitz
>>> Sent from my iPhone
M14P
congested
overheated and
>>>> broke down. M
>>>> Sent from my iPhone
> ... Blitz
> Byron M. Fox
> 80 Milland Drive
> 415-307-2405
Jill at M14P has crush washer sets for the output check valves.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 7/26/2011 2:17 PM, Byron Fox wrote:
| Quote: | Thanks, Dennis, I'll do as you suggest. When asked, Vladimir assured
<dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>> wrote:
Dennis
A. Dennis Savarese
334-285-6263 <tel:334-285-6263>
334-546-8182 <tel:334-546-8182> (cell)
Skype: Yakguy1
Thanks, Blitz
Fox<byronmfox(at)gmail.com <mailto:byronmfox(at)gmail.com>>
le, List Admin.
... Blitz
Byron M. Fox
80 Milland Drive
415-307-2405
N13472(at)aol.com Guest
Posted: Tue Jul 26, 2011 12:25 pm Post subject: Phillips 25-60 Oil |
Blitz, I clean the check valve approx. every 25 hours. And have reused the
washers many time with out
Trouble. But it would not hurt to replace them. Also use anti-seize compound
on the threads that screw
Into the barrel.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 702-595-2680
Posted: Tue Jul 26, 2011 1:15 pm Post subject: Phillips 25-60 Oil |
Good thought, Tom. Thanks.
On Tue, Jul 26, 2011 at 1:22 PM, Tom Elliott <N13472(at)aol.com (N13472(at)aol.com)> wrote:
[quote] --> Yak-List message posted by: "Tom Elliott" <N13472(at)aol.com (N13472(at)aol.com)>
Into the barrel.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell [url=tel:702-595-2680]702-595-2680[/url]
