handfordp(at)aol.com Guest
Posted: Wed Jul 20, 2011 6:53 am Post subject: Factory mod Finger Brakes |
I would appreciate a copy of any installation instructions for this mod or alternatively a reference to a web site. I have recently taken over a nearly completed XS Tri-gear from David Steade to replace my G-PHXS which was destroyedn a fire.
Thank you
Peter Handford
G-KIRB
g-iani(at)ntlworld.com Guest
Posted: Wed Jul 20, 2011 8:04 am Post subject: Factory mod Finger Brakes |
Peter
You will find all the Mods at http://www.europa-aircraft.biz/updates/. Then pick the “Modifications” tab and look down the list for Mod 65. This will give you the instructions for the first version of the finger brakes using the Jamar twin cylinder master cylinder. Europa have never published the revised version of Mod 65 for the Matco cylinders.
If you look in http://www.europa-aircraft.biz/assistance/manuals.php. Then look for CBM 33T (3) you will find a description of the Matco cylinder installation but the assembly diagram on page 5 works badly (the levers bind on the bracket. If you have the Matco cylinders let me know and I will produce a corrected version for you. You will need to cut one spacer and add some washers.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of handfordp(at)aol.com
Sent: 20 July 2011 15:51
Subject: Factory mod Finger Brakes
Thank you
Peter Handford
G-KIRB
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234567
 Download |
| Filename: |
Mod_65_Brakes.pdf |
241.13 KB |
| Downloaded: |
287 Time(s) |
