lowell23@msn.com
Joined: 16 Apr 2011 Posts: 10 Location: Burnsville, MN
Posted: Tue Jul 19, 2011 9:44 am Post subject: Rear Spar Troubles |
During this years annual it was found that at some point someone had put a lucite 'inspection panel' on the inside right wing - just ahead of the flap. When they had done that, they ran five screws into the rear spar cap, and possibly into the spar itself. Does anyone know of an approved spar repair?
Thank you,
Lowell Johnson
| | - The Matronics Piper-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Piper-List |
100.05 KB |
6559 Time(s) |
grosseair(at)comcast.net Guest
Posted: Tue Jul 19, 2011 10:33 am Post subject: Rear Spar Troubles |
What kind of aircraft are you talking about?
| Quote: | ------------------------------------------------------------------------
lowell23(at)msn.com <mailto:lowell23(at)msn.com>
July 19, 2011 12:44 PM
Thank you,
Lowell Johnson
http://forums.matronics.com/viewtopic.php?p=347061#347061
http://forums.matronics.com//files/rear_spar_200.bmp
lowell23@msn.com
Posted: Tue Jul 19, 2011 10:50 am Post subject: Re: Rear Spar Troubles |
I should have mentioned it is a 1952 PA-22.
Lowell
Kellym
Posted: Tue Jul 19, 2011 12:51 pm Post subject: Rear Spar Troubles |
One approved method is to replace the wing with a serviceable used
one.....minor repair, log book entry only.
Otherwise you are probably looking at getting Piper or DER to engineer
an approved repair to present to FSDO for field approval as a major repair.
Kelly
A&P/IA
KCHD |
