Circuit Design Software
Goto page 1, 2  Next
maca2790
PostPosted: Sun Jul 10, 2011 3:17 pm    Post subject: Circuit Design Software Reply with quote
HI all,
Anyone suggest easy to use CAD software? One that has the appropriate symbols (Starter Relays etc).
Cheers
John MacCallum
Builder # 41016
VH-DUU
PostPosted: Sun Jul 10, 2011 8:01 pm    Post subject: Circuit Design Software Reply with quote
At 06:13 PM 7/10/2011, you wrote:
HI all,
None are "easy" . . . every cad system has it's
own 'language' and mouse/keyboard protocols to learn.
The brand of software will have little to do with
the outcome of your finished product.
TurboCAD will open, edit, save and print the AudoCAD
drawings on my website. You can snatch the symbols
library right out of those drawings.
Please be forewarned. If you are not already a
reasonably adept cad-driver, you have many hours
ahead of you for first learning to communicate
with the software's own language and more hours
acquiring the 'art' of producing 'pretty' drawings.
In the final analysis, the drawings will convey
no more meaning or have any higher value than those
produce neatly the a pencil, pink pearl eraser,
and straight-edge in a 3-ring binder for a whole
lot less $time$. $time$ that you might wish
to spend on your airplane instead.
On the other hand, getting good with a cad program
opens a lot of doors for doing designs of all types
and getting the parts to fit together on paper before
you start cutting wood, metal, tile, wires, etc. etc.
I've been driving an ancient version of AutoCAD for over
25 years. One of the best investments of $time$ I have
ever made after learning to type.
harley(at)AgelessWings.co
PostPosted: Mon Jul 11, 2011 4:18 am    Post subject: Circuit Design Software Reply with quote
Morning, John...
As Bob said, there are many! And there are some open source free ones out there as well. And they are all different in their commands and useability.
I started with Generic Cadd at work back in the early '80s because the pharmaceutical company I worked for didn't have any IT department then and I had to buy my own computer and software...Gcadd was cheap then ($99).
After a few years, when they started supplying Autocad at work, I stuck with GCadd so as not to have to learn something new. My work (production equipment and control design) was not involved with the building engineering where the Autocad was used, so I was allowed to do so.
I liked GCADD better than Autocad anyway, as I could work faster...GCADD used two letter commands for the drawing options as well as the standard icons or menu options that one had to hunt down to select. It was fast and easy with the left hand doing the selecting on the keyboard and the right doing the drawing with the trackball.
So, I've stuck with it through the years. Generic Cadd is now Visual CADD and works the same way. I would never change now.
So, find one that you can use and like (for example, Visual Cadd, www.tritools.com , has full function demo for 30 days then you can either just drop it or buy it...I believe many others do as well.)
Or select one of the open source freebies ( for example, http://sourceforge.net/projects/free-cad/ )
Note that most of them will be able to use the symbols you need. Although their are differences, the format is pretty standard and can be found all over the internet for downloading ( www.caddprimer.com/CAD_Symbols_symbol_library/CAD_symbol_symbols_library.htm ). Or, as Bob said, just open any of his drawings and extract the symbols. Or, as I do, just make your own...any item you draw in Cad can be saved as a symbol.
They all have their own level of difficulty, but once you've learned what you need to know about one of them, the rest are easier...so start with one, learn what you can, then try a few others until you find one that you like.
Harley
HI all,
Cheers
John MacCallum
Builder # 41016
VH-DUU
Mauledriver(at)nc.rr.com
PostPosted: Mon Jul 11, 2011 6:57 am    Post subject: Circuit Design Software Reply with quote
If you are just looking for something to document your electrical system, you might consider ExpressSCH:
http://www.expresspcb.com/expresspcbhtm/download.htm
It appears to be free software that can be used to design custom boards. I used just the SCHematic part to document my entire electrical system. It doesn't have most of the components (symbols) we use in our aircraft but I found it pretty easy to create my own.
It has just enough 'smarts' to act like a electrical schematic tool should, rather than a drawing tool. A long way from a CAD program but a step closer to what you might want than a universal drawing tool or Powerpoint.
(I'd show you a sample but I'm not at home)
Bill "dripping sweat all over the project" Watson
On 7/10/2011 7:13 PM, John MacCallum wrote: [quote] <![endif]--> <![endif]-->
HI all,
Cheers
John MacCallum
Builder # 41016
VH-DUU
Bubblehead
PostPosted: Thu Jul 14, 2011 9:00 am    Post subject: Re: Circuit Design Software Reply with quote
harley(at)AgelessWings.co wrote:
Morning, John...
I did the same thing. I needed a CAD package and my employer did not want to ante up for a full package but he did pay for a seat of Generic Cadd. 20 years later I've used AutoCad, TurboCAD, and my favorite SolidWorks but GenericCadd has a fond place in my heart. I loved the two letter abbreviations. I entered them left handed and worked the mouse right handed and could really fly!
Keller, TX
RV-8 N247TD
PostPosted: Thu Jul 14, 2011 2:02 pm    Post subject: Circuit Design Software Reply with quote
AutoCAD has a script file one can edit
For example, here's my one and two letter
overlay script for 99% of all the AutoCAD
commands I need to do my work. I learned to
mouse with either hand and type with the ohter
to minimize tendencies for repetitive motion
damage.
I also found this list useful for teaching
AutoCAD . . . If one learns this list of
commands first, you can be VERY productive
while learning the other 1000 commands as needed!
AR, *ARRAY
B, *BLOCK
BR, *BREAK
C, *CIRCLE
CH, *CHAMFER
C, *COPY
E, *ERASE
ED, *DDEDIT
EL, *ELLIPSE
EX, *EXTEND
H, *HATCH
I, *INSERT
L, *LINE
LA, *LAYER
LT, *LINETYPE
M, *MOVE
MI, *MIRROR
P, *PAN
PE, *PEDIT
PL, *PLINE
P, *PURGE
R, *REDRAW
RE, *REGEN
RCT, *RECTANGLE
RO, *ROTATE
S, *STRETCH
SC, *SCALE
SCR, *SCRIPT
T, *TRIM
V, *VIEW
W, *WBLOCK
X, *EXPLODE
Z, *ZOOM
I knew some folks who had to routinely use two
different cad systems. The customized command overlay
file made AutoCAD mimic the other program to a large
degree . . .
ainut(at)knology.net
PostPosted: Thu Jul 14, 2011 5:24 pm    Post subject: Circuit Design Software Reply with quote
I'd like to have a drawing system that is not a CAD system. I want to
place a part with standardized icon, draw a line from there to the next
part, and have the computer automagically arrange everything so that
nothing overlaps and one can label the wires, etc. Don't know that it
exists. Guess I'll have to write it someday.
David M.
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
damage.
AR, *ARRAY
B, *BLOCK
BR, *BREAK
C, *CIRCLE
CH, *CHAMFER
C, *COPY
E, *ERASE
ED, *DDEDIT
EL, *ELLIPSE
EX, *EXTEND
H, *HATCH
I, *INSERT
L, *LINE
LA, *LAYER
LT, *LINETYPE
M, *MOVE
MI, *MIRROR
P, *PAN
PE, *PEDIT
PL, *PLINE
P, *PURGE
R, *REDRAW
RE, *REGEN
RCT, *RECTANGLE
RO, *ROTATE
S, *STRETCH
SC, *SCALE
SCR, *SCRIPT
T, *TRIM
V, *VIEW
W, *WBLOCK
X, *EXPLODE
Z, *ZOOM
degree . . .
If you're an American, just say NO to the Obamanation, to socialism, and get rid of Soros.
..democracy and a republic can function only in a firm partnership with morality and religion. -- John Adams. Indeed. Same should be said for ANY type of gubmnt
PostPosted: Thu Jul 14, 2011 6:09 pm    Post subject: Circuit Design Software Reply with quote
to place a part with standardized icon, draw a line from there to
the next part, and have the computer automagically arrange
everything so that nothing overlaps and one can label the wires,
etc. Don't know that it exists. Guess I'll have to write it someday.
But who is your market? For most product development
efforts the schematic is but an intermediate step
between conception and production. Schematic generation
programs with any degree of sophistication generate
'net lists' which are operated on to convert the schematic
to an etched circuit board. Interestingly enough, these
same schematics are often used to publish various
service/training manuals. The net list generator couldn't
care less whether the schematic is on one or 100 pages.
But the poor tech trying to trace a circuit has to jump
across pages with cryptic 'bus labels' to guide them.
Some free schematic generation systems like Express PCB
would probably come close to what you want to do but for
a guy who grew up looking at ARRL schematics in the
Handbook and QST magazine, symbology for most schematic
generation programs seems pretty crude . . . but then
the drawing of crystal clear diagrams is becoming a lost
art form.
So before you launch into what has to be a monumental
programming and graphics effort, it could be well to
make sure there's a market for your work-product.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
tim2542(at)sbcglobal.net
PostPosted: Thu Jul 14, 2011 6:15 pm    Post subject: Circuit Design Software Reply with quote
Micro soft Visio.... Works great for this, made for it in fact.
On Jul 14, 2011, at 6:11 PM, David <ainut(at)knology.net> wrote:
I'd like to have a drawing system that is not a CAD system. I want to place a part with standardized icon, draw a line from there to the next part, and have the computer automagically arrange everything so that nothing overlaps and one can label the wires, etc. Don't know that it exists. Guess I'll have to write it someday.
David M.
> damage.
> AR, *ARRAY
> B, *BLOCK
> BR, *BREAK
> C, *CIRCLE
> CH, *CHAMFER
> C, *COPY
> E, *ERASE
> ED, *DDEDIT
> EL, *ELLIPSE
> EX, *EXTEND
> H, *HATCH
> I, *INSERT
> L, *LINE
> LA, *LAYER
> LT, *LINETYPE
> M, *MOVE
> MI, *MIRROR
> P, *PAN
> PE, *PEDIT
> PL, *PLINE
> P, *PURGE
> R, *REDRAW
> RE, *REGEN
> RCT, *RECTANGLE
> RO, *ROTATE
> S, *STRETCH
> SC, *SCALE
> SCR, *SCRIPT
> T, *TRIM
> V, *VIEW
> W, *WBLOCK
> X, *EXPLODE
> Z, *ZOOM
> degree . . .
> Bob . . .
...democracy and a republic can function only in a firm partnership with morality and religion. -- John Adams. Indeed. Same should be said for ANY type of gubmnt
PostPosted: Thu Jul 14, 2011 7:08 pm    Post subject: Circuit Design Software Reply with quote
Don't need a market. It would be just for me and whoever wants it.
david
of the Gnu generation
art form.
(o o)
PostPosted: Thu Jul 14, 2011 7:09 pm    Post subject: Circuit Design Software Reply with quote
Outstanding! I'll try it. Thanks.
David
> David M.
>> damage.
>> AR, *ARRAY
>> B, *BLOCK
>> BR, *BREAK
>> C, *CIRCLE
>> CH, *CHAMFER
>> C, *COPY
>> E, *ERASE
>> ED, *DDEDIT
>> EL, *ELLIPSE
>> EX, *EXTEND
>> H, *HATCH
>> I, *INSERT
>> L, *LINE
>> LA, *LAYER
>> LT, *LINETYPE
>> M, *MOVE
>> MI, *MIRROR
>> P, *PAN
>> PE, *PEDIT
>> PL, *PLINE
>> P, *PURGE
>> R, *REDRAW
>> RE, *REGEN
>> RCT, *RECTANGLE
>> RO, *ROTATE
>> S, *STRETCH
>> SC, *SCALE
>> SCR, *SCRIPT
>> T, *TRIM
>> V, *VIEW
>> W, *WBLOCK
>> X, *EXPLODE
>> Z, *ZOOM
>> degree . . .
>> Bob . . .
zodiac601
PostPosted: Thu Jul 14, 2011 7:40 pm    Post subject: Re: Circuit Design Software Reply with quote
+1 for Visio
I've drawn electrical schematics with it several times.
stuart(at)stuarthutchison
PostPosted: Fri Jul 15, 2011 12:43 am    Post subject: Circuit Design Software Reply with quote
Another plug for MS Visio. Attached is a draft 'start circuit' I drew for
myself a few months back. Outputing to PDF resized some of the lines, but
Visio itself is great.
Cheers, Stu
VH-FLY_Start_Circuit.pdf
 Filename:  VH-FLY_Start_Circuit.pdf
 Filesize:  26.98 KB
 Downloaded:  817 Time(s)
mrspudandcompany(at)veriz
PostPosted: Fri Jul 15, 2011 4:03 am    Post subject: Circuit Design Software Reply with quote
My suggestion is to download the FREE Express PCB software
and give it a try. I find it to be rather easy to use and has symbols with
it, that are easy to place and interconnect.
So, give it a go. . . "Nothing ventured nothing lost"
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.54 KB
 Downloaded:  715 Time(s)
PostPosted: Fri Jul 15, 2011 5:27 am    Post subject: Circuit Design Software Reply with quote
I would encourage anyone who is willing to spend the
$time$ to become competent in any sort of illustration
software also take the time to become fluent in
the language of speaking and illustrating "electronese".
If you look at any drawings produced in the 'Connection
or on aeroelectric.com, the diagrams speak to specific
connections of wires to terminals of devices, to wire
sizes, symbology to suggest type of terminals used,
internal functions of devices such as switches, relays,
contactors, motors, etc. The whole story on one page.
VERY FEW professional illustrators of consumer
product wiring diagrams bother to offer such detail
in their work-product. Even folks who should know
better. I can't tell you how many no-value hours
I spent trying to find a truly descriptive schematic
of how the fuel selector valve and gage system worked
in my '87 GMC truck. All the schematics in 'official'
published documents showed "boxes" with colored wires
routing between them and no information what so ever
as to what goes on inside the boxes. Having finally
discovered what I needed to know, it made perfect
sense and I can now draw the schematic from memory,
not as an activity to mimic somebody else's drawings
but as a fundamental understanding of how the system
works.
I'll suggest there are two aspects of creating really
useful drawings. The choice of illustration software
obviously drives the general appearance of the finished
drawings. But organization and completeness is entirely
up to the skills, willingness and experience of the
illustrator.
Symbols for lucid production of schematics and diagrams
are the language of the discipline. Learn the symbols
too and use what ever illustrative tools to present
those symbols in a manner that makes understanding
'jump off the page' into the mind of the competent
observer. These same drawings will provide a solid
foundation for sharing understanding for the not-so-
competent observer with a willingness and desire to
learn.
Just a few more little lines in the published schematics
for my truck's fuel system would have completed the
story and saved a lot of wasted time. COMPLETE
schematics are the tools of both teaching how
something works but the tools of understanding
for how to fix the thing that doesn't work at
some later time.
(o o)
gpabruce(at)gmail.com
PostPosted: Fri Jul 15, 2011 7:56 am    Post subject: Circuit Design Software Reply with quote
  1. Are you looking for an active program like SPICE?  (Simulated analysis)
  2. Or a passive, flat program to show the electrical diagram?
  3. Or do you want to show the actual component layout on the circuit board?
Sorry but I missed the beginning of the discussion. It sounds like you have already bread-boarded and proven your circuit and are looking to go from 2 to 3 for production. Is that correct?
On Fri, Jul 15, 2011 at 4:58 AM, ROGER & JEAN CURTIS <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> wrote:
[quote]>
               Roger
Float Flyr
PostPosted: Fri Jul 15, 2011 8:28 am    Post subject: Circuit Design Software Reply with quote
Confusing... you say you do not want a CAD system then you describe CAD
system.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Fri Jul 15, 2011 10:26 am    Post subject: Circuit Design Software Reply with quote
I've attached a schematic created with Express SCH for reference.
Bill "it can be really tough to get any work done at the airport on a
nice day" Watson
[quote] Another plug for MS Visio. Attached is a draft 'start circuit' I drew for
Cheers, Stu
Main_Power_Distribution5.7.pdf
 Filename:  Main_Power_Distribution5.7.pdf
 Filesize:  26.21 KB
 Downloaded:  718 Time(s)
PostPosted: Fri Jul 15, 2011 5:06 pm    Post subject: Circuit Design Software Reply with quote
Would it make sense to use a program like Spice in the mix, in order to
show how the circuits work (and possibly identify problems before
something is burned out?)
I'm looking at the gEDA project (gpl electronic design automation) as
the toolset to use right now. Don't know how hard it is to use or
anything. Bear in mind, I have very little background in electronics.
I'm hoping that the relatively simple schematic of the airplane will
not be terribly difficult to model.
David M.
> drew for
> lines, but
works.
illustrator.
learn.
some later time.
(o o)
PostPosted: Fri Jul 15, 2011 5:08 pm    Post subject: Circuit Design Software Reply with quote
Mostly, my purpose is to document my airplane wiring. If I can get
analysis while I'm at it, I'm willing to learn to do so. Others have
differing needs, of course.
David M.
analysis)
circuit board?
<mrspudandcompany(at)verizon.net <mailto:mrspudandcompany(at)verizon.net>>
someday.
software
symbols with
Roger
Goto page 1, 2  Next
Page 1 of 2
