backstagelive(at)gmail.co Guest
Posted: Sun Jul 10, 2011 8:45 am Post subject: First Flight. (Joe) |
Congratulations Paul! Keep us posted as you go through the flight test
process. A long time back, there was a thread about turning the Zodiac
landing gear around so it takes more of the weight off the nose during
landing and takeoff. I'm not sure if anyone has done that. Is there anyone
watching this thread that has actually done that? Would that be something
you would consider Paul?
Joe
psm(at)att.net Guest
Posted: Sun Jul 10, 2011 11:47 am Post subject: First Flight. (Joe) |
Hi Joe,
I actually installed my gear with the flat edge forward on the first
pass. I think I understand the reason the nose is so hard to get off
the runway. It is because the main gear is put far enough behind the CG
so you can step on the step behind the wing and still not make the tail
smack in to the ground.
Paul
On 7/10/2011 9:42 AM, Joe wrote:
anyone watching this thread that has actually done that? Would that be
something you would consider Paul?
Joe
merlin
Joined: 05 Oct 2008 Posts: 15 Location: Fair Play, S.C.
Posted: Sun Jul 10, 2011 11:49 am Post subject: First Flight. (Joe) |
That's what I plan to do as well and I'm going to go with the grove gear to save some weight added by the upgrade.
Sent: Sun, July 10, 2011 12:42:49 PM
Subject: Re: First Flight. (Joe)
Posted: Sun Jul 10, 2011 12:11 pm Post subject: First Flight. (Joe) |
Hi Joe,
Before you change something as big and heavy as the landing gear "Spring" you might want to check into the weight and balance impact. With the Zenith spring and Jabiru engine the first W&B came up really nicely with the CG nearly centered in the envelope.
Paul
On 7/10/2011 12:47 PM, JEFFREY WEBB wrote: [quote] That's what I plan to do as well and I'm going to go with the grove gear to save some weight added by the upgrade.
