dan(at)azshowersolutions. Guest
Posted: Wed Jul 06, 2011 5:22 pm Post subject: PTT buzz |
Well, my ghost is still in the plane. I was able to roll the plane completely out of the garage last weekend and it still had the nasty oscillating buzz as the PTT button was pressed to operate my Garmin SL40. Again, this is without the engine running and just operating on my 12V battery. The TX light comes on (on the radio), the transmit light turns red on the intercom, and when someone else calls I can hear loud and clear.
In trying to troubleshoot I was doing searches on other blogs and found a possible reason I'd like to bounce off of this list. One other person had a buzz happening similar to mine (using the same radio) and found after great deliberation that the connection to his antenna was poor. He said he bought a "cheapo" antenna (yes I did this) and did a poor-man's termination using a ring terminal on the threaded antenna bottom and then running the outer coax wire to ground. He had an EE stop by and quickly found this as being a problem. he purchased a "quality" antenna with a BNC connector, hooked it up, and said problem solved.
My question is this...before I go and lay down over $100 for an antenna, does anyone concur with this as a possible problem? I would also like to know if there is a BNC connector (or proper terminator)designed to hook up to an antenna with just the threads on the bottom. Thanks
Dan B
--- On Tue, 6/21/11, Dan Billingsley <dan(at)azshowersolutions.com> wrote:
| Quote: | From: Dan Billingsley <dan(at)azshowersolutions.com>
Subject: Re: PTT buzz
Date: Tuesday, June 21, 2011, 6:29 PM
I didn't turn the lights off but I
was able to roll the plane out from under the lights a ways.
When I did that, the noise became less prominent. I will
need to wait until I have an extra hand to roll the plane
all the way out of the garage (The slope + gravity= plane in
street). One of the guys I talked to today had a good point
about when I key the mic inside the closed space I have
quite a bit RF dancing back and forth in there. Would it be
reasonable to say it could be some feedback interference as
well?
Dan
--- On Tue, 6/21/11, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com>
wrote:
> From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com>
> To: aeroelectric-list(at)matronics.com
> Date: Tuesday, June 21, 2011, 2:45 PM
> --> AeroElectric-List message
> posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
> > I think I found the ghost...When I first heard it
it
> sounded like AC cycling (the noise was very
consistant).
> AFter going thru this symptom with a few
folks...Garmin
> techs saying they never heard of it b-4...
> > I was scratching my head and looked up. The
antenna
> was hovering between two floursent lights in the
> garage...it WAS AC!
> > Dan
> Hmmmm . . . good hypothesis. If you turn
> off the lights
> does the buzz go away?
> Bob . . .
> AeroElectric-List Email Forum -
browse
Un/Subscription,
Chat,
> FAQ,
> - MATRONICS WEB FORUMS -
Forums!
> List Contribution Web Site -
> -Matt
> Dralle, List Admin.
longg(at)pjm.com Guest
Posted: Thu Jul 07, 2011 5:01 am Post subject: PTT buzz |
Dan,
Maybe a silly question, but have you tried another radio in its place? Had it bench tested lately?
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Thu Jul 07, 2011 5:29 am Post subject: Re: PTT buzz |
Dan,
Of course, I concur. Here's why:
Coaxial cables are classed as high frequency waveguides because the energy transmitted in them is almost entirely within the insulation. An amazing demonstration of this is that the group wave velocity is exactly equal to the speed of the electromagnetic wave in the particular material out of which the insulation is made. The importance of this is directly proportional to frequency. For audio purposes it matters little. Above a Megahertz it becomes critical.
"Pigtails" where the coax shield is twisted into a lead and both the inner conductor and twisted-up-shield lead are treated as separate wires is deadly to signals above a Megahertz. The shield should be terminated by any method that does not increase the impedance of the shield or the inner conductor. There are many ways to do this, but they all use some collar arrangement to terminate the messy coax shield. Any coax catalog has lots of solutions--use them.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Thu Jul 07, 2011 5:36 am Post subject: PTT buzz |
Hi Dan,
Any chance that someone in your area could just loan you a BNC type
antenna & coax for it? If so, you could just substitute. On 2nd thought,
how about a 'rubber ducky' off a handheld? You'd still need a BNC to BNC
cable, and a Male-Male BNC adapter to hook up the antenna, but that
should be easier & cheaper than a $100 antenna.
If you can't come up with a local solution, I might have one and a cable
in my collection I could ship to you for testing.
Another (long shot) idea is, are you running off a bench power supply,
or the plane's battery? If a bench supply, I wonder if RF could be
getting into the supply. Bob might be better able to address that
possibility.
On 07/06/2011 08:19 PM, Dan Billingsley wrote:
Dan B
--- On Tue, 6/21/11, Dan Billingsley<dan(at)azshowersolutions.com> wrote:
> From: Dan Billingsley<dan(at)azshowersolutions.com>
> well?
> Dan
> --- On Tue, 6/21/11, Robert L. Nuckolls, III<nuckolls.bob(at)aeroelectric.com>
> wrote:
>> From: Robert L. Nuckolls, III<nuckolls.bob(at)aeroelectric.com>
>> posted by: "Robert L. Nuckolls, III"<nuckolls.bob(at)aeroelectric.com>
> it
> consistant).
> folks...Garmin
> antenna
>> garage...it WAS AC!
>>> Dan
>> off the lights
>> Bob . . .
Posted: Thu Jul 07, 2011 5:47 am Post subject: PTT buzz |
At 08:19 PM 7/6/2011, you wrote:
--> AeroElectric-List message posted by: Dan Billingsley <dan(at)azshowersolutions.com>
DIY antennas have been successfully installed
on lots of OBAM aircraft. Back in the early days
of VHF comm radios in airplanes, virtually all
the antennas were built at the airframe factory,
not purchased.
Build one of these from RadioShack parts:
[img]cid:.0[/img]
Stick it on the back of your comm transceiver in place
of the antenna coax. See if the 'buzz' goes away. Keep
the test transmissions short . . . a few seconds. This
load is only good for 2W continuous so your transceiver's
output represents an potential 'overload' condition but
short test transmissions wont hurt it.
If the noise goes away, then quality of the feedline
and antenna system is suspect. It could be a poorly
installed connector at the transceiver end, at some
intermediate joint, or the antenna end. The fact that
you have a DIY antenna is not an automatic recipe for
failure but it does put some extra-ordinary requirements
on the fabricator for quality of the made-up joints.
You could fabricate an antenna using one of these
coax-connector-to-rod adapters that are common to
the CB radio accessories market. One such article is
Radio Shack 219-0961
[img]cid:.1[/img]
This product is designed to accept the PL-259
"UHF" style connector and an antenna rod fitted
with a 3/8-24 threaded end. Note that this product
comes with an internal tooth star washer to
effect good electrical connection between coax
shield and the aircraft skin. This washer needs
to be exactly centered in the final make up of
the joint.
[img]cid:.2[/img]
You can install this style connector directly on the
end of your coax but it's a bit of a chore
http://tinyurl.com/2lwyc
You'll also need a step-down adapter
[img]cid:.3[/img]
to mate the smaller RG-400 style coax with the
larger connector.
Alternatively, you can install a BNC connector
on the end of your coax and use a BNC-UHF
adapter on the antenna mount.
[img]cid:.4[/img]
Steer clear of any coax connector that is
not crimped or soldered. "Twist on" or other
"solderless" connectors are to be avoided.
Many folks have discovered that $100 for a pre-assembled
antenna is not too bad a deal. You can spend a goodly
chunk of $time$ fabricating your own antenna. It's
not difficult but it's not a trivial exercise either.
198.34 KB |
12312 Time(s) |
27.68 KB |
12312 Time(s) |
60.09 KB |
12312 Time(s) |
14.1 KB |
12312 Time(s) |
15.82 KB |
12312 Time(s) |
Posted: Thu Jul 07, 2011 6:16 am Post subject: PTT buzz |
I think the terms 'deadly' and 'critical' are not
appropriate here. Yes, as soon as you break out a
shield and center conductor from a coax cable,
the resulting conductors are no longer 'coax' and
they become part of the antenna.
No, they are not 'ideal' connections between
the coax and antenna elements. But their effects
on overall performance is impossible to simply
observe and can only be measured with pretty
sophisticated equipment.
There was some discussion a few years back
about the value of adding the ferrite beads
over feed line attached to an embedded foil
VOR antenna. See the "foil antenna" series
photos at:
http://aeroelectric.com/Pictures/Antenna
I did some work in the RF lab and found
that it took a couple dozen beads to
drive the 'deleterious effects' of antenna-to-
feedline mismatch to immeasurable levels. At the
same time, having NO beads installed produced
no observable value.
The observable effects for DIY departures from
idea are likely to be the result of poor
connection, i.e. loss of gas tight connection
between two components . . . not for having violated
the sanctity of a coaxial feedline.
The exposed center conductor and shield pigtails
simply become part of the antenna's complex
impedance. Careful measurements would show that
the trimmed antenna length will be a tad shorter
because of exposed feedline pigtails . . . but
the time it takes to "trim for perfection" will
not make the radio perform batter in any way
you can observe.
Posted: Thu Jul 07, 2011 6:31 am Post subject: PTT buzz |
Thank You all for your thoughtful inputs...I think a good place to start will be building that dummy load Bob. Thank you and I will keep the list informed of my progress.
Dan
--- On Thu, 7/7/11, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
| Quote: | From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com>
Subject: Re: Re: PTT buzz
Date: Thursday, July 7, 2011, 8:12 AM
inner conductor.
photos at:
violated
you can observe.
FAQ,
-Matt
Dralle, List Admin.
rickofudall
Posted: Thu Jul 07, 2011 10:13 am Post subject: PTT buzz |
Dan, If you have a 121.5 ELT use the portable antenna from it.
Rick Girard
On Thu, Jul 7, 2011 at 9:27 AM, Dan Billingsley <dan(at)azshowersolutions.com (dan(at)azshowersolutions.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Dan Billingsley <dan(at)azshowersolutions.com (dan(at)azshowersolutions.com)>
Dan
--- On Thu, 7/7/11, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
> From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
> To: aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)
> inner conductor.
> photos at:
> violated
> you can observe.
> Bob . . .
| Quote: | AeroElectric-List Email Forum -
> FAQ,
> -Matt
> Dralle, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Posted: Thu Jul 07, 2011 5:20 pm Post subject: PTT buzz |
ok...the saga continues. AFter getting home today I disconnected the coax from behind the SL40 and attached the rubber anntenna off of my HT. The sound is different...it is no longer a buzz but it sounds as if it is turning itself on and off when the PTT is depressed...a pulse of sorts approx two cycles per second. Some have e-mailed and said to try turning the squelch down...check. I was also told to turn the side tone to zero...check. no luck so far. So it seems to possibly be either in the radio or a mis-guided wire going to the intercom. Double checking wires tomorrow. Throw out the ideas if you get one.
Thanks, Dan
inner conductor.
photos at:
violated
you can observe.
FAQ,
-Matt
Dralle, List Admin.
Posted: Thu Jul 07, 2011 6:08 pm Post subject: PTT buzz |
At 08:16 PM 7/7/2011, you wrote:
Thanks, Dan
This is not a meaningful test. A rubber duck is a RADIATING
device that floods the wiring behind the panel with RF
energy. If the feedline is radiating due to bad termination,
then the symptoms you're seeing may well be indiciative of
a cockpit flooded with RF. Changing the radiator from a bad
coax to an antenna mounted right to the back of the radio
is not likely to yield useful information.
You need to do the dummy load thing first.
Posted: Fri Jul 08, 2011 2:56 am Post subject: PTT buzz |
| Quote: | This is not a meaningful test. A rubber duck is a
RADIATING
RF
termination,
indiciative of
from a bad
radio
Roger That
FAQ,
-Matt
Dralle, List Admin.
Posted: Sat Jul 09, 2011 6:01 am Post subject: PTT buzz |
I built the dummy load as per Bob's direction, removed the coax from the back of the radio and installed the dummy BNC...turned things on, hit PTT...no joy. I still get the buzz. Now, that means this primary culpret is within my system. Either between my radio (SL40), my intercom
(PM 1000 II), or the Approach Fast Stack (http://approachfaststack.com/) hub that interfaces the two. Another potential goober could be with my wire runs to the headset jacks. Approach did a nice job of these using shielded wires, however, they were too short (my bad guestimate)as my termination point is behind the co-pilot. I ended up splicing these wires using a Cat-5 wire bundle to the termination point.
I was quite careful when doing this splice, however, I wonder if the lack of shielded wires could be hurting me. Any thoughts of where to start would be welcome.
Dan B
| Quote: | > ok...the saga continues. AFter getting home today I
> Thanks, Dan
RADIATING
RF
termination,
indiciative of
from a bad
radio
FAQ,
-Matt
Dralle, List Admin.
dalamphere(at)comcast.net Guest
Posted: Sat Jul 09, 2011 6:47 am Post subject: PTT buzz |
Dan,
This may be totally unuseful, but if you have the aux jacks installed
between the PS1000 (per PS's instructions) and radio, have you tried
disconnecting the intercom and plugging your headset and mike jacks into
those and tried the same experiment (with the dummy load)??
FWIW
Dave
Posted: Sat Jul 09, 2011 9:08 am Post subject: PTT buzz |
At 08:58 AM 7/9/2011, you wrote:
Okay, good data.
Describe the "buzz" . . . what does it sound like?
When listening to the 'buzzing' transmitter on
another radio, is the same noise heard there too
or is it just in your own headset? Does the intercom
have an auto-bypass function? In other words, if you
power down just the intercom, does the mic and phones
wiring default to direct connection with the transceiver?
If so, does the buzz go away in default mode?
enginerdy(at)gmail.com Guest
Posted: Sat Jul 09, 2011 12:15 pm Post subject: PTT buzz |
As Dave suggested, try a headset out in the 'aux jacks' that are directly connected to the radio (you did install them per the PS installation manual, right? Or as Bob suggested, putting the intercom in bypass mode. The PM1000 II should do that when turned off. This should cut the problem in half. Here are two troubleshooting approaches that might work, given the result:
1) Headset directly into the radio is noisy:
Have you checked the supply voltage across the radio while transmitting and while not transmitting? That is, with the meter probing the supply voltage *at the radio*, grounded to the power ground *at the radio*. Transmitting is a high-power activity, so it's possible that it's causing a big voltage sag that the radio doesn't appreciate. This could be due to wire resistance in both the supply AND ground wires. What is important is what the radio 'sees' while transmitting.
2) Headset directly into the radio is clean:
Another possibility is that the power ground to the radio isn't significant enough, causing a noise voltage to be 'seen' on the audio at the intercom. This is difficult to explain, but you could experiment by connecting an extra ground wire at the radio and finding an additional ground point: the avionics ground, the intercom power ground, one of the fast stack commons... This would help the power supply electrons get to where they want to go without 'pushing' other signals around.
Just to double-check, but you're not doing the test while connected to a battery charger?
--Daniel
On Jul 9, 2011, at 8:58 AM, Dan Billingsley wrote:
Dan B
Posted: Sat Jul 09, 2011 5:25 pm Post subject: PTT buzz |
Okay, good data.
The buzz has changed in pitch since removing the antenna. It used to be a medium pitch (as far as notes go say a C)and oscillating. Now that the dummy load is in place the buzz dropped to say a G (much lower) almost a growel. I don't want to hold the key down too long (to determine if still oscillating) as I don't want to overload the dummy...You pick which dummy as it can go either way at this point :>)
| Quote: | When listening to the 'buzzing' transmitter on
When the antenna was connected, yes, I did transmit the buzz as the wife heard it on the HT. I would hear her loud and clear and she reported the buzz.
Does the
| Quote: | intercom
you
phones
transceiver?
Although the other guys here have indicated this intercom should have a bypass, I just went out and turned off the intercom and tried it. I cannot hear myself talk and hear nothing when I key the mic. I have gone into the radio and turned down several things, so tomorrow I will look into this a bit further. I did have the FastStack designed to operate a comm 2 (so it has another out). My plan was to eventually run my hand held as a backup and they gave me a switch to go back and forth. I have tried taking my Comm1 harness out of the comm1 jack and moved it to Comm 2. I flipped the switch and still got the buzz.
Will get back to you tomorrow on this one when I explore a bit more.
Thanks for the help,
Dan
FAQ,
-Matt
Dralle, List Admin.
Posted: Sat Jul 09, 2011 5:30 pm Post subject: PTT buzz |
Daniel, thanks for the ideas. I will be trying them tomorrow. Today I was chasing parts (this I'm convinced is = to 3/4 of the build). No, not connected to a charger...the battery shows full charge.
Dan B
--- On Sat, 7/9/11, Daniel Hooper <enginerdy(at)gmail.com> wrote:
while transmitting.
--Daniel
> Thanks,
> Dan B
FAQ,
-Matt
Dralle, List Admin.
tim2542(at)sbcglobal.net Guest
Posted: Sat Jul 09, 2011 9:49 pm Post subject: PTT buzz |
Just a quick note Dan, the intercom will only default Comm 1. If this
is com 2 it will not work with the Audio panel power off.
FWIW, TIm
Posted: Sun Jul 10, 2011 5:04 am Post subject: PTT buzz |
1. If this
FWIW, TIm
Thanks Tim...good to know that.
Dan
FAQ,
-Matt
Dralle, List Admin.
Posted: Sun Jul 10, 2011 8:11 am Post subject: PTT buzz |
So I believe I may have narrowed it down to two possibilities if not both of
them adding to the issue...
1. I turned the intercom off and tried to transmit...I still got the buzz and it
is oscillating. My wife heard it broadcast on the HT and I heard her loud and
clear when she talked to me. I have not measured the voltage across the radio as
it is being keyed yet, however, my Dynon 100 indicates I my system voltage
(BATT) is at 11.3V. So Daniel, this may be part of it.
2. As I was reading the Intercom install manual I found this entry interesting:
Electrical Noise IssuesWARNING: You must use separate shielded cables for
the microphone and headphone jacks. Combining
these two wires WILL cause loud oscillations and degrade
the intercom function. The oscillation is caused
by the cross-coupling between the large headphone
signal and the small microphone signal.
So, realizing that the intercom is currently bypassed, should this warning still
be of concern? Remember I mentioned in a previous post that the headphone and
mic jacks were sent too short, so I cut them off behind the panel and spliced
them with Cat-5 cable. These jacks terminate behind the co-pilot.
