BGray(at)glasair.org Guest
Posted: Thu Jul 07, 2011 12:51 pm Post subject: ADBS-B Out |
I posted this to the RV list and no one had any answers. How about you
guys?
Hi Guys,
I already have all the equipment I need for ADS-B Out for my Glasair
III. But it seems that in its rush to get the regulation out to the
public, the FAA did not provide any path for Experimental aircraft to
install/approve ADBS-B.
The FAA has published an advisory circular on the subject (AC 20-165)
that states ALL ADBS-B installations must be approved before use. It
then goes on to state that approval requires an STC. It also broadly
hints that all equipment must be TSO'ed. You all must know that STC's do
not apply to us. To add further confusion, I was told by my local FSDO
that all STC's for approval were not being accepted and that the only
way to get approval was from the original aircraft manufacturer. I asked
the FSDO if we (the home builder) were considered the manufacturer and
was told the FAA felt that it was the kit manufacturer. I called the
EAA, they were clueless.
So, it seems that you (or we) can't get there from here. Any one have
any ideas?
Here's the link to the AC,
http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC
ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument
Bruce
WWW.Glasair.org
rleffler
Posted: Thu Jul 07, 2011 1:17 pm Post subject: ADBS-B Out |
Work with your ADS-B vendor to assist you to work through the issues. It's
in their best interest as well as yours.
_________________ Bob Leffler
N410BL - Phase I
Posted: Thu Jul 07, 2011 2:02 pm Post subject: ADBS-B Out |
I wish it were that easy.
Garmin 530W TSO'ed
Garmin 330ES TSO'ed
RMI Microencoder Air Data Non-TSO'ed.
Garmin shrugged it's shoulders.
The stumbling block is going to be the air data system.
Unlike encoder certification by successfully completing a ground test,
there is NO ground/air testing protocol yet published for ADBS-B Out
approval.
Remember back in the early days of RNAV? You had to fly over known
landmarks and log the results to verify accuracy. That's what we need
here. But that would require ATC coordination.
Bruce
WWW.Glasair.org
r.r.hall(at)cox.net Guest
Posted: Thu Jul 07, 2011 5:09 pm Post subject: ADBS-B Out |
Based on this paragraph I don't think the AC applies to experimental, I could be wrong though.
1-2. Who This AC Applies to. This AC is for anyone who is applying for an initial type certificate (TC), supplemental type certificate (STC), an amended TC, or an amended STC for the installation and continued airworthiness of ADS-B Out equipment.
Since the TC STC area doesn't apply I think we are left without any guidance at this point.
Rodney
---- Bruce <BGray(at)glasair.org> wrote:
guys?
Hi Guys,
any ideas?
Bruce
WWW.Glasair.org
Flydad57(at)neo.rr.com Guest
Posted: Thu Jul 07, 2011 5:15 pm Post subject: ADBS-B Out |
I know I'm the manufacturer of my homebuilt experimental. It says so on my
airworthiness certificate and the data plate. You can put anything you want
in an E-AB. Don't know why ADS-B stuff would be any different. Just like a
transponder, no?
Bob Taylor
TigerCub N657RT
Sent: Thursday, July 07, 2011 4:47 PM
To: <aeroelectric-list(at)matronics.com>
Subject: ADBS-B Out
guys?
Hi Guys,
any ideas?
Bruce
WWW.Glasair.org
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27324 Location: Livermore CA USA
Posted: Thu Jul 07, 2011 6:32 pm Post subject: ADBS-B Out |
That's a good point. NavWorx, for example, ONLY sells non-TSO'd equipment so their only market is Experimental, right? Seems like they wouldn't have a business model if you couldn't install their ADS-B transceivers in your homebuilt...
Matt
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
At 02:09 PM 7/7/2011 Thursday, you wrote:
_________________ Matt Dralle
Posted: Thu Jul 07, 2011 6:41 pm Post subject: ADBS-B Out |
At 01:47 PM 7/7/2011 Thursday, you wrote:
| Quote: | I asked
This seems blatantly wrong. If I built an Experimental airplane of my own design from scratch, there is no question I am the manufacture of the aircraft.
To that end, on my RV-8, when I registered it, under "Model" I put "RV-8", under "Manufacture" I put "Matt Dralle (Van's Aircraft)".
Only the "Builder" (i.e. manufacture) of the aircraft can hold the Mechanics cert for my RV-8. Last time I did an inspection on it, *I* signed the log book off, not Van's Aircraft...
$.02
Matt
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Fri Jul 08, 2011 5:30 am Post subject: ADBS-B Out |
I don't think this is totally true. I have a '56 172, CAR 3 certified, TSO's
are not a requirement for all the equipment since this is not required on
the TC. For instance a KX-170B radio.
Bill Greenley
RV-10 (waiting on wing kit delivery)
bakerocb
Posted: Fri Jul 08, 2011 6:43 am Post subject: ADBS-B Out |
7/8/2011
Hello Bruce Gray, It is unfortunate that you assigned ADBS-B Out to the
subject of your aeroelectric list post instead of ADSB-B Out. We may be
stuck with that now as the identification of this thread. (Do you suppose
the transposition of the letters "B" and "S" in that fashion was the result
of some Freudian slip on your part?)
Hello Bob Taylor, You wrote:
1) "I know I'm the manufacturer of my homebuilt experimental. It says so on
my
airworthiness certificate ..........."
Are you absolutely positive of this statement? Please recheck the FAA FORM
8130-7, SPECIAL AIRWORTHINESS CERTIFICATE for your EXPERIMENTAL - AMATEUR
BUILT aircraft. Maybe your initial airworthiness inspector made a mistake in
filling out that form. (Was the inspection done by a DAR?).
My FSDO issued certificate has N / A entered in both the NAME and ADDRESS
boxes of Block B MANUFACTURER. In Block D it has my name in the BUILDER box.
This makes it very clear that in the eyes of the FAA I am the BUILDER and
not the MANUFACTURER of my airplane. This is important because some 14 CFR
regulations (such as 91.411 (b) (1) for example) give prerogatives to the
manufacturer of an aircraft that are not given to the builder of an E-AB
aircraft.
2) "..... and the data plate."
This really proves nothing. Except for the applicable and limited amount of
information required on an E-AB aircraft data plate by 14 CFR 45.11 and
45.13 (Builder's Name, Model Designation, and Builder's Serial Number) one
may put anything else one chooses on that data plate. (One may note in
passing that in the data plate terminology used in 45.13 even an aircraft
manufacturer such as Piper or Cessna becomes a "Builder" rather than a
"Manufacturer".)
3) "You can put anything you want in an E-AB."
Not really. This gets to be a complex issue and your statement can not be
taken at face value.
Please see the introduction to the attached table MINIMUM INSTRUMENT AND
EQUIPMENT REQUIREMENTS FOR POWERED AMATEUR BUILT EXPERIMENTAL AIRCRAFT for
more insight into this issue.
4) "Just like a transponder, no?"
I would be inclined to agree. If the ADSB-B Out equipment has some sort of
TSO approval by the FAA why not go ahead and install it. If every builder of
E-AB aircraft had to comply with every word of every Advisory Circular that
were written, for the most part, by FAA employees that have not a clue about
the existence of E-AB aircraft, we would not have a single E-AB in the air.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
Time: 06:15:31 PM PST US
Subject: Re: ADBS-B Out
transponder, no?
Bob Taylor
TigerCub N657RT
 Download |
| Filename: |
ABEA_Minimum_Inst_Requirements_10.doc |
35 KB |
| Downloaded: |
252 Time(s) |
bakerocb
Posted: Fri Jul 08, 2011 7:28 am Post subject: ADBS-B Out |
7/8/2011
Hello Bruce Gray, You wrote:
1) "ADBS-B Out"
2) "...the FAA did not provide any path for Experimental aircraft to
install/approve ADBS-B." and "The FAA has published an advisory circular on
the subject (AC 20-165) that states ALL ADBS-B installations must be
approved before use."
Since many portions of 14 CFR and the supporting Advisory Circulars are
written by bureaucrats and approved by lawyers who do not have a clue
regarding the existence of E-AB (Experimental- Amateur Built) aircraft one
should not be surprised by lack of this path. (And maybe we should be
grateful that they did not attempt to provide one since it would probably be
nearly impossible to comply with.)
3) "I asked the FSDO if we (the home builder) were considered the
manufacturer and
was told the FAA felt that it was the kit manufacturer."
Please see my response to Bob Taylor on this issue.
It is unfortunate that we have gotten all wrapped around the axle regarding
the semantics of "builder" versus "manufacturer". I think that we should
call all kit providers just that, "Kit Providers". They are neither the
manufacturers nor the builders of E-AB aircraft. And the E-AB builder is
just that, the builder, not the manufacturer of his E-AB aircraft.
4) "I called the EAA, they were clueless."
I think that if you call the EAA and talk to or email Joe Norris
(jnorris(at)eaa.org) you will find out that it is not the EAA that is clueless,
but rather the FAA responses when the EAA attempts to query the FAA on our
behalf on many issues.
5) "So, it seems that you (or we) can't get there from here. Any one have
any ideas?"
If the ADSB-Out equipment that you have has some TSO markings on it, make
the best installation that you can and go fly it.**
**PS: I can recall a posting by an individual many years ago when GPS was
new. This builder attempted to comply with the then existing Advisory
Circular on GPS installations to obtain some FAA approval. He wound up
airborne with a terrified FAA bureacrat for an approval flight. The poor FAA
employee spent the entire flight looking out the windows waiting the the
inevitable mid air collision that was about to happen any second. The FAA
employee never looked at the GPS equipment.
That experience cured that builder of ever again trying to get any E-AB
aircraft equipment installation approved by the FAA.
Time: 01:51:50 PM PST US
Subject: ADBS-B Out
guys?
Hi Guys,
any ideas?
Bruce
WWW.Glasair.org
It could have well been a Freudian slip.
Anyway, someone mentioned Navworx on this thread.
According to the data in the regulation (14 CFR §92.225) those aircraft
equipped with Extended Squitter (1090 ES) must meet TSO-C166b, those
equipped with Universal Access Transceivers (UAT) must meet TSO-C154c.
How does on meet TSO standards without getting approval? Navworx is non
TSO'ed, therefore not legal to use.
Unless we crack this nut, in 2020 we will be denied the use of most
airspace.
Bruce
WWW.Glasair.org
Float Flyr
Posted: Fri Jul 08, 2011 10:18 am Post subject: ADBS-B Out |
I(s that not the reason for the 51% rule? To specifically make the builder
the manufacturer? The gathering of parts and the design is supposed to be
less than 50%.
One other thing, after selling a homebuilt aircraft, just check out who has
manufacturers' liability!
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
bakerocb
Posted: Fri Jul 08, 2011 8:34 pm Post subject: ADBS-B Out |
7/8/2011
1) "Every form that I filled out for my E-AB aircraft states that I am the
manufacturer (Taylor, Robert D.)."
A) Not true. See here, for example, FAA FORM 8130-6, APPLICATION FOR U. S.
http://www.faa.gov/documentLibrary/media/form/faa8130-6.pdf
Note that in Box 2 they ask for the AIRCRAFT BUILDER'S NAME (Make). The
instructions in FAA Order 8130.2F for filling out this form specifically
state that for an E-AB aircraft the name of the amateur builder is entered
in Box 2.
B) Please LOOK at your airplane's FAA FORM 8130-7 SPECIAL AIRWORTHINESS
CERTIFICATE and tell us exactly what was typed into the NAME and ADDRESS
boxes in Section B, MANUFACTURER and what was typed into the Section D,
BUILDER box by that FAA inspector from the Cleveland MIDO when he inspected
your airplane and created that form.
That will tell you (and us) in the eyes of the FAA who was the MANUFACTURER
(undoubtedly N / A) and who was the BUILDER (your name) of your airplane.
2) "My aircraft was not a kit."
Does not matter. Every E-AB aircraft, regardless of its initial source or
manner of creation, will have "TO OPERATE AMATEUR BUILT AIRCRAFT" in the
PURPOSE box of SECTION A, and the amateur builder's name in the BUILDER box
of Section D of that aircraft's FAA FORM 8130-7, SPECIAL AIRWORTHINESS
CERTIFICATE.
To: <bakerocb(at)cox.net>
Sent: Friday, July 08, 2011 10:41 PM
| Quote: | Every form that I filled out for my E-AB aircraft states that I am the
manufacturer (Taylor, Robert D.). The model is TigerCub. No, my
inspector was not a DAR. He was from the Cleveland MIDO office. My
aircraft was not a kit. It was built/manufactured by me.
Bob Taylor
TigerCub N657RT
Sent: Friday, July 08, 2011 10:40 AM
To: <aeroelectric-list(at)matronics.com>; <Flydad57(at)neo.rr.com>;
Subject: ADBS-B Out
> 7/8/2011
> result
> on
> my
> FORM
> in
> box.
> CFR
> aircraft.
> of
> one
> "Manufacturer".)
> for
> of
> of
> that
> about
> air.
> to
> From: "Robert Taylor" <Flydad57(at)neo.rr.com>
> my
> want
> like a
> transponder, no?
> Bob Taylor
> TigerCub N657RT
bakerocb
Posted: Sat Jul 09, 2011 5:24 am Post subject: ADBS-B Out |
7/9/2011
Hello Noel Loveys, You wrote:
1) "To specifically make the builder the manufacturer?"
I don't understand why people are straining to be considered the
"manufacturer" of a product (namely one single E-AB aircraft) in the eyes of
the FAA.**
When one looks at the totality of the FAA definitions, and the FAA
regulations based on those definitions, it is absurd to consider the amateur
builder of a single E-AB to be the "manufacturer" of that aircraft. Let run
through a brief audit trail of what applies:
A) First, can an individual building an E-AB become a manufacturer? The
answer is, yes. See the definition of a Person from 14 CFR 1.1 General
Definitions here:
"Person means an individual, firm, partnership, corporation, company,
association, joint-stock association, or governmental entity. It includes a
trustee, receiver, assignee, or similar representative of any of them."
Now let's extract some definitions from FAA Order 8120.2G. You can look at
it here:
http://www.faa.gov/documentLibrary/media/Order/8120.2G.pdf
B) Second, what does a manufacturer do? See here:
"o. Manufacturer. A person as defined by 14 CFR part 1, Definitions and
Abbreviations, who causes a product or article(s) to be produced. A
manufacturer may be a PAH or a supplier to a PAH."
C) Third, what does it mean to produce a product or article(s).
"s. Produce. To manufacture, or cause to be manufactured, a product or
article(s)."
D) Fourth, how does one go about having approval to produce a product or
article? See here:
"u. Production Approval. A document issued by the FAA to a person that
allows the production of a product or article in accordance with its
approved design and approved quality system, and can take the form of a PC,
a PMA, or a TSO authorization."
E) So all the individual person building an E-AB needs to formally become
the manufacturer of that procuct, instead of being the builder of an E-AB,
is to get the FAA to issue him a PC, a PMA, or a TSO authorization. In order
to get the needed document from the FAA he can start by reading FAA Order
8120.2G -- Go for it!
2) "One other thing, after selling a homebuilt aircraft, just check out who
has
manufacturers' liability!"
Do you really think that the semantic distinction between suing the
"builder" or the "manufacturer" of an E-AB would stop some vulture lawyer
from initiating a lawsuit? Or would have any affect on the outcome of such a
law suit?
**PS: Apparently some E-AB aircraft builders feel that being the
"manufacturer" of that aircraft, rather than just the "builder" will give
them some special manufacturer's privileges such as that granted in 14 CFR
91.411 (b) (1) for example.
Really? Take a look at what it takes for even an approved aircraft
manufacturer to perform all the tests required by 91.411 and see how many
individual E-AB builders would have the equipment and expertise to perform
those tests even if given permission to do so.
Time: 11:18:02 AM PST US
Subject: RE: ADBS-B Out
less than 50%.
Noel
Posted: Sat Jul 09, 2011 9:41 am Post subject: ADBS-B Out |
Now I'm really confused.
How can the FAA consider the Kit Manufacturer the "Manufacturer"?
I know of no kit manufacturer who has a PC, PMA, TC, or Production
Approval. What they may have is a letter that their kit meets the 51
percent rule.
Bruce
WWW.Glasair.org
bakerocb
Posted: Sun Jul 10, 2011 5:49 am Post subject: ADBS-B Out |
7/10/2011
Hello Bruce, You wrote: "What they may have is a letter that their kit meets
the 51
percent rule."
That is correct. Let's take another look at some of the paragraphs that I
extracted from:
PC, a PMA, or a TSO authorization."
Note that paragraph o does not have the word "only" between the words "may"
and "be".
Also paragraph u does not have the word "only" between the words "can" and
"take".
There is nothing in the regulations or FAA Order 8120.2G that prohibit the
FAA Administrator from using the word "manufacturer" in the letter that
informs the kit provider, and prospective kit purchasers, that his kit meets
the major portion rule.
Some additional comments on this specific issue:
1) Since the FAA writes the various types of documents based upon their
authority in the US Code they get to choose the wording (subject to public
review of draft regulations) in those documents.
2) When the bureaucrats and document approving lawyers wrote FAA Order
8120.2G they did not have the existence of E-AB (Experimental - Amateur
Built) aircraft or kit creators in their mind. (A very common situation
through out the FAA.)
3) There were a number of english language words available to that FAA
letter writer to describe the kit creators. Words such as "creators",
"assemblers", "manufacturers", and, my favorite word when writing on this
subject to avoid confusion with the builder who actually turns the kit into
an airplane, "providers". It seems logical for the writers to use the common
generic word "manufacturer", without creating any greater implication of the
word, when referring to the kit providers.
4) The power of the Administrator (and of the individuals within the FAA
acting on his behalf) is pretty complete, he can use the words that he
chooses to mean what he wants them to mean.
5) In a sense the type of letter to the kit provider that you refer to could
be considered a form of Production Approval thereby making the kit provider
a PAH (Production Approval Holder), but the FAA makes an effort to avoid
using the word "approval" regarding E-AB aircraft since there are no
published standards available to measure any E-AB approval against. (Before
people leap up to point out that indeed some approval requirements are
placed on E-AB aircraft I invite them to read again the Introduction to the
attached table MINIMUM INSTRUMENT AND EQUIPMENT REQUIREMENTS FOR POWERED
AMATEUR BUILT EXPERIMENTAL AIRCRAFT.)
5) So the use of the word "manufacturer" in the letters that you write of to
the kit provides should not create a significant problem or needed source of
confusion. And it certainly does not bear directly on the issue of whether
in the eyes of the FAA the builder of an E-AB meets the criteria of being a
"manufacturer" wherever that term is used throughout the FAA written
regulations.**
**PS: I would appreciate it if any E-AB builders who want to be considered
"manufacturers" would identify to us the specific regulation(s) that they
think would benefit them by this categorization.
Time: 10:41:13 AM PST US
percent rule.
Bruce
WWW.Glasair.org
 Download |
| Filename: |
35 KB |
| Downloaded: |
279 Time(s) |
Posted: Sun Jul 10, 2011 11:47 am Post subject: ADBS-B Out |
Just to close the loop regarding some comments I made the other day, my
paperwork does not indicate that I am the "manufacturer". My bad. It DOES
show the MAKE of my aircraft to be a Taylor, Robert D.. That's what lead me
to think it said I was the manufacturer. I was not looking to be the
maufacturer in order to gleen some advantage via the regulations, I just
thought (mistakenly) that that was what the paperwork said.
Regardless the above, I do think that I can put whatever equipment I wish
into my aircraft.
Bob Taylor
TigerCub N657RT
Sent: Sunday, July 10, 2011 9:46 AM
To: <aeroelectric-list(at)matronics.com>; <BGray(at)glasair.org>
Subject: ADBS-B Out
| Quote: | 7/10/2011
meets
the 51
percent rule."
extracted from:
"may"
and "be".
"take".
meets
into
common
the
could
provider
(Before
the
to
of
a
regulations.**
to
percent rule.
Bruce
WWW.Glasair.org
bakerocb
Posted: Mon Jul 11, 2011 3:55 am Post subject: ADBS-B Out |
7/11/2011
Hello Robert Taylor, You wrote:
1) "...... my paperwork does not indicate that I am the "manufacturer". My
bad."
Thank you for your response and for confiming that information.
2) "....... I do think that I can put whatever equipment I wish into my
aircraft."
Almost true, but see these words extracted from the introduction to the
attached table:
"However, depending upon other portions of the FAR's, some items in certain
circumstances must not only be installed in experimental amateur built
aircraft, but must interface properly with ATC (Air Traffic Control)
equipment, other aircraft, or other entities external to the aircraft.
Altitude encoders, Transponders, communication radios, exterior lighting,
some IFR navigation equipment, and ELT's (Emergency Locator Transmitters)
are examples of such equipment."
If equipment that must interface properly with entities external to the
aircraft has been installed in the E-AB aircraft and the FAA requires
equipment markings (such as a TSO), or, alternatively, testing to prove
proper functioning, and the equipment installed does not interface properly,
or is not properly marked, or has not been tested to the FAA's satisfaction,
then they can demand that the aircraft not operate with that equipment.
Time: 12:47:06 PM PST US
into my aircraft.
Bob Taylor
TigerCub N657RT
 Download |
| Filename: |
35.5 KB |
| Downloaded: |
1241 Time(s) |
