psm(at)att.net Guest
Posted: Tue Jul 05, 2011 4:19 pm Post subject: Finally getting close to certification. |
My Zodiac is nearing inspection. It should happen before OSH but that
is in doubt. It is incredibly difficult to find someone to do the
inspection but I think I have solved that puzzle.
I did weight and balance today. My plane, N773PM, has a Jabiru engine,
center stick, dual brakes, dual throttles, wing lockers, nav lights,
strobes, no landing/taxi light. The instrument panel features dual
Dynons, SL-30, Aera 500, LRI, and transponder. Empty weight is 753.5
with CG at 311 aft of datum line (station 1790 on both wing leading
edges). My test flight calculated W & B with 24 gallons fuel and no
baggage is 1117.5 pounds and CG at 372 aft of datum.
Yes, I know . . . my passenger and baggage allowance calls for someone
really small . . . Maybe I should consider getting one leg amputated,
but then how would I apply rudders?
Do these numbers sound reasonable to those of you who have actual
experience with flying XL's?
Paul
Camas, WA
mhubel
Posted: Wed Jul 06, 2011 5:00 am Post subject: Finally getting close to certification. |
Paul,
I have almost exactly the same configuration. Empty mine is 749 lb
and the cg is at 287 mm (but with no RC servos it is hard to fly that
way). With full fuel (30 gal) and one pilot (160 lb) it is 1089 lb and
338 mm but then allowing for the empty fuel condition, the empty fuel CG
becomes 369 mm. Thus with a real pilot, I can never hit the forward CG
limit. I have always tried to keep the CG as far forward as possible to
allow some baggage capacity.
Note, I have the battery forward of the firewall and do not use the
Jabiru duel throttle arrangement, I have joined both throttle cables at
the TBI-40 carb.
On 07/05/2011 8:16 PM, Paul Mulwitz wrote:
engine, center stick, dual brakes, dual throttles, wing lockers, nav
lights, strobes, no landing/taxi light. The instrument panel features
dual Dynons, SL-30, Aera 500, LRI, and transponder. Empty weight is
753.5 with CG at 311 aft of datum line (station 1790 on both wing
leading edges). My test flight calculated W & B with 24 gallons fuel
and no baggage is 1117.5 pounds and CG at 372 aft of datum.
someone really small . . . Maybe I should consider getting one leg
amputated, but then how would I apply rudders?
Paul
Camas, WA
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com
978-443-3955
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
Posted: Wed Jul 06, 2011 6:39 am Post subject: Finally getting close to certification. |
Hi Mark,
Thanks for the information.
I started with the dual throttle design in the Jabiru-USA FWF kit and
redesigned it. I didn't like the way their design felt. My change was
to move the torque tube into the cabin and face the arms downward while
lengthening them. I also put the throttle controls and the carb heat
control on the cabin side rather than on the instrument panel. This
keeps all the throttle cables at about the same height as the
carburetor. My arms are not long enough to sit back in the seat and
rest my hand on the throttle. I am pleased with the smooth operation of
my modified throttles.
It looks like I will get my plane inspected on Thursday. The only issue
is the fact the DAR is not on the MIDO list of DARs. I guess time will
tell if this works or not.
Paul
On 7/6/2011 5:56 AM, Mark Hubelbank wrote:
Paul,
CG becomes 369 mm. Thus with a real pilot, I can never hit the forward
CG limit. I have always tried to keep the CG as far forward as
possible to allow some baggage capacity.
the Jabiru duel throttle arrangement, I have joined both throttle
cables at the TBI-40 carb.
> that is in doubt. It is incredibly difficult to find someone to do
> the inspection but I think I have solved that puzzle.
> features dual Dynons, SL-30, Aera 500, LRI, and transponder. Empty
> weight is 753.5 with CG at 311 aft of datum line (station 1790 on
> both wing leading edges). My test flight calculated W & B with 24
> gallons fuel and no baggage is 1117.5 pounds and CG at 372 aft of datum.
> Paul
> Camas, WA
mhubel
Posted: Wed Jul 06, 2011 7:14 am Post subject: Finally getting close to certification. |
Paul,
Best of luck on the inspection. It should be a very straight
forward process. The advantage of using the same airframe and engine
others have. Let us know when you are ready to test it.
On 07/06/2011 10:36 AM, Paul Mulwitz wrote:
Hi Mark,
was to move the torque tube into the cabin and face the arms downward
while lengthening them. I also put the throttle controls and the
carb heat control on the cabin side rather than on the instrument
panel. This keeps all the throttle cables at about the same height as
the carburetor. My arms are not long enough to sit back in the seat
and rest my hand on the throttle. I am pleased with the smooth
operation of my modified throttles.
issue is the fact the DAR is not on the MIDO list of DARs. I guess
time will tell if this works or not.
Paul
> Paul,
> lb and the cg is at 287 mm (but with no RC servos it is hard to fly
> that way). With full fuel (30 gal) and one pilot (160 lb) it is 1089
> lb and 338 mm but then allowing for the empty fuel condition, the
> empty fuel CG becomes 369 mm. Thus with a real pilot, I can never hit
> the forward CG limit. I have always tried to keep the CG as far
> forward as possible to allow some baggage capacity.
>> datum.
>> Paul
>> Camas, WA
Mark Hubelbank
2 Clock Tower Place
Suite 555
mhubel(at)nemon.com
978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
Posted: Wed Jul 06, 2011 7:29 am Post subject: Finally getting close to certification. |
Hi Mark,
I've been doing taxi testing for about a week now. Several little
problems have come up. The most alarming was a leak in the hose
connecting the oil cooler to the engine. That is fixed now but I still
need one more test run to make sure I got rid of the last little drip
between the filter and engine fitting. Other problems include a
vibration in the instrument panel that has temporarily been fixed with a
folded piece of cardboard jammed between the panel and the center
console. I also needed to add some spray lubricant to the plastic block
on the nose gear column to make the steering more smooth.
I'll try to report actual flight testing as it happens. On the first
flight I really want to learn what engine RPM is needed for level flight
at 70 KIAS with no flaps. This should be my standard pattern entry
configuration. I plan to use full flaps - which in my case is around 20
degrees - for both takeoff and landing. The plane is sufficiently
overpowered that 20 degrees flaps on takeoff should only serve to make
the ground run very short.
Paul
On 7/6/2011 8:11 AM, Mark Hubelbank wrote:
Paul,
> Hi Mark,
> Paul
>> Paul,
>> hit the forward CG limit. I have always tried to keep the CG as far
>>> nav lights, strobes, no landing/taxi light. The instrument panel
>>> datum.
>>> Paul
>>> Camas, WA
mhubel
Posted: Wed Jul 06, 2011 8:29 am Post subject: Finally getting close to certification. |
Paul,
Understood,
Have you been following all the issues with the oil cooler hose on
the jabiruengines forum? The -6 hoses and fittings as supplied by jabiru
are marginal, At some point you will probably want to replace them all
and the oil adapter plate. I went over kill and did -10 but -8 is
probably adequate.
While I am not a professional test pilot, if you have enough runway
(3000 feet??) , I would suggest using no flaps on the first takeoff and
landings. Flaps on the 601 causes a strong nose down tendency and you
can run out of trim. Keep it simple.
At full flaps, the climb rate is lower, you are being exposed for a
longer time to the period where one can not return to the runway if
there is a engine problem. Speaking of engine problems, be prepaired to
reduce throttle slightly if at full throttle climb, the engine starts to
run rough, the Bing carb is noted for doing funny things.
I would also suggest some wheel off taxi tests. Just enough speed
to get the wheels up then let it back down. Just in case there some
strange problem in the control linkage, being 1 foot from the runway can
save a lot.
Just note that on my first flight, I encountered an aerilon trim
problem, it only showed near stall - on landing.
On 07/06/2011 11:27 AM, Paul Mulwitz wrote:
Hi Mark,
still need one more test run to make sure I got rid of the last little
drip between the filter and engine fitting. Other problems include a
a folded piece of cardboard jammed between the panel and the center
block on the nose gear column to make the steering more smooth.
flight at 70 KIAS with no flaps. This should be my standard pattern
entry configuration. I plan to use full flaps - which in my case is
around 20 degrees - for both takeoff and landing. The plane is
sufficiently overpowered that 20 degrees flaps on takeoff should only
serve to make the ground run very short.
Paul
> Paul,
>> Hi Mark,
>> and redesigned it. I didn't like the way their design felt. My
>> change was to move the torque tube into the cabin and face the arms
>> downward while lengthening them. I also put the throttle controls
>> and the carb heat control on the cabin side rather than on the
>> instrument panel. This keeps all the throttle cables at about the
>> same height as the carburetor. My arms are not long enough to sit
>> back in the seat and rest my hand on the throttle. I am pleased
>> with the smooth operation of my modified throttles.
>> Paul
>>> <mhubel(at)nemon.com>
>>> Paul,
>>> 1089 lb and 338 mm but then allowing for the empty fuel condition,
>>> the empty fuel CG becomes 369 mm. Thus with a real pilot, I can
>>> never hit the forward CG limit. I have always tried to keep the CG
>>> as far forward as possible to allow some baggage capacity.
>>>> do the inspection but I think I have solved that puzzle.
>>>> Empty weight is 753.5 with CG at 311 aft of datum line (station
>>>> 1790 on both wing leading edges). My test flight calculated W & B
>>>> with 24 gallons fuel and no baggage is 1117.5 pounds and CG at 372
>>>> aft of datum.
>>>> leg amputated, but then how would I apply rudders?
>>>> Paul
>>>> Camas, WA
Mark Hubelbank
2 Clock Tower Place
Suite 555
mhubel(at)nemon.com
978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
Posted: Wed Jul 06, 2011 10:54 am Post subject: Finally getting close to certification. |
Hi Mark,
No I've not been following Jabiru issues. I didn't even know there was
a list for that subject. My hose problem was certainly caused by a poor
job on my part assembling the hose. I also had leaks through the
threads on one of the fittings due to poor loctite application and, to a
lesser degree, the fact I had turned the fitting in its threads when
fooling around with the leaky hose fitting.
What is the cause or impact of the hose size on the oil cooler fittings?
The field I use is quite short for a public paved runway. It is Grove
Field (1W1). I think the total runway is 2400 feet and there are very
tall trees a few hundred yards from the normal departure end of the
runway. I have been flying a Tecnam Echo Super that always requires
flaps on takeoff. It still uses only a few hundred feet ground roll and
climbs like a banshee. I have also spent a lot of time flying C-182s
which won't get off the ground without flaps. I guess my preference is
to use at least 1/2 flaps for takeoff. I don't have a good way to
measure how much flaps I have except for the stops at none and max so I
was thinking full flaps would be a good choice.
I have no intention of returning to the runway if I lose the engine at
low altitude. I might try to do that if I have achieved significantly
more than pattern altitude. That would happen with the Tecnam long
before I finished turning cross-wind. The Jabiru powered Zodiac has
similar wing loading to the Tecnam and 30 percent more power. I am
expecting exhilarating climb performance.
One trick I learned many years ago from my favorite instructor is to
leave the engine settings alone until reaching at least 500 AGL. It
turns out nearly all engine problems happen when changing the power setting.
I appreciate the comments about trim. That is one area I can only
discover on the first flight.
I don't understand why the engine would run rough on full throttle. The
hint to reduce power sounds like a real gem. Before my first flight I
plan to follow the advice of one of the guys on my field. He is in the
habit of ferrying old planes around the country and tries a pretend
pattern flight with the brakes set and the wheels chocked. This means
running full throttle for a minute or two followed by cruise power,
power reduction for approach and increasing power again for a go around
simulation. His experience is around 1 in 10 planes that have been
sitting around for a few years show bad behavior with this test.
Thanks again,
Paul
On 7/6/2011 9:26 AM, Mark Hubelbank wrote:
| Quote: | Paul,
Understood,
jabiru are marginal, At some point you will probably want to replace
them all and the oil adapter plate. I went over kill and did -10 but
-8 is probably adequate.
runway (3000 feet??) , I would suggest using no flaps on the first
takeoff and landings. Flaps on the 601 causes a strong nose down
tendency and you can run out of trim. Keep it simple.
a longer time to the period where one can not return to the runway if
to reduce throttle slightly if at full throttle climb, the engine
starts to run rough, the Bing carb is noted for doing funny things.
can save a lot.
don.honabach(at)pcperfect Guest
Posted: Wed Jul 06, 2011 11:49 am Post subject: Finally getting close to certification. |
| Quote: | > I don't understand why the engine would run rough on full throttle
The Jabiru/Bing Carb is sensitive to intake air turbulence and/or heavily biased air going into the carb. In 601HDS installs at least, the intake elbow is tight and at WOT you'll get air turbulence and/or biased air through the carb and ultimately to the cylinders which will cause a roughness that tends to only occur at WOT as the fuel mixture becomes un-balanced at this point.
Most folks fix this by installing an internal divider into the carb intake elbow. Some solve it by rotating the carb a bit, and some do both or just get lucky.
In the end, it is just a good thing to know it exists and if you encounter it, just pull back the throttle a bit and you the engine should go back to 'purrrring mode' and then you can tinker with it on the ground and ultimately find a way of improving the air intake path.
Hope this helps -- good luck on your first flight.
Don
Posted: Wed Jul 06, 2011 1:02 pm Post subject: Finally getting close to certification. |
Hi Don,
Thanks for the info.
I spoke to Pete Krotje about this issue at Sun n Fun (Tornadoes n Mud?)
earlier this year. He suggested replacing the SCAT tube with a rubber
right angle and gave me the source for these parts. I did that. I
suppose that means I am immune from this problem. Right? (Ha Ha)
I am looking forward to my first flight about as much as I might look
forward to having a root canal. I really expect it to go well, but all
these years of wondering about the integrity of the XL have not yet worn
off. Perhaps I will feel much better after I get it in the air and
grease a few landings.
Paul
Don
Posted: Wed Jul 06, 2011 1:12 pm Post subject: Finally getting close to certification. |
Hey Paul,
FWIW, for me, I had the issue with both parts (SCAT and rubber part he is talking about).
Don
daveaustin2(at)primus.ca Guest
Posted: Wed Jul 06, 2011 4:55 pm Post subject: Finally getting close to certification. |
Paul,
Get in the cockpit and fly the bloody thing..
Dave Austin
Posted: Wed Jul 06, 2011 5:06 pm Post subject: Finally getting close to certification. |
Thanks, Dave.
I'm just waiting for an airworthiness certificate right now. With luck
I will have that by tomorrow night. Then it is just a matter of finding
some nice weather.
Believe it or not I already have liability insurance with no checkout
required. I didn't think I could find such a thing, but I asked and the
guys at Regal found it for me. I could have gotten hull insurance too,
but the price was very high and $1000 less if I had 10 hours in type. I
figure I will have a lot more than that in a couple of months.
Paul
On 7/6/2011 5:52 PM, Dave Austin wrote:
| Quote: | Paul,
Dave Austin
Posted: Wed Jul 06, 2011 5:07 pm Post subject: Finally getting close to certification. |
Thanks, Don.
I had heard there was a problem with the carb input hose, but I had not
heard how it shows up. I don't think I would have guessed it appears at
full throttle and goes away if you back off a little.
I really appreciate the advice all of the list members are giving me.
Paul
On 7/6/2011 2:12 PM, Don Honabach wrote:
| Quote: | Hey Paul,
Don
Posted: Thu Jul 07, 2011 3:42 am Post subject: Finally getting close to certification. |
Hey Paul,
That was meant as positive encouragement!
If anyone has, you have done everything to get it right. But at some point you have to, not stop
listening to all the "what could happen" stuff that comes at you, but make a decision to fly based
on your knowledge that you've built it the best that could be.
Just for fun, I can't rmember if yours is tail dragger or trike, but I was advised strongly at first
flight for the Spitfire (taildragger) do not attempt to do hops on the runway. That's the way to
lose directional control and wrap it up in a ball. High speed taxies are the same. If it doesn't
yaw or do something wierd as you lift off, go for the circuit.
Enjoy.
Dave Austin
Posted: Thu Jul 07, 2011 4:55 am Post subject: Finally getting close to certification. |
Hi Dave,
I feel encouraged! I am just a nervous type when it comes to flying.
That is nothing new for me. Of course, it is peaked by planning a first
flight of a plane built by an amateur (me).
My Zodiac has tricycle gear.
I do not plan to do hops on the runway. I don't want to do any landings
- even after a flight of just a few feet -- until I have had a chance to
get the feel of the plane in landing configuration and stall speeds,
etc. at high altitude. My first flight should take at least a half hour
- probably longer. I want to get a reading on indicated stall speeds -
both clean and dirty - and try forward slips both clean and dirty before
attempting any approaches. I also want to do some gentle turns such as
the type needed from base leg to final. A bonus would be learning the
power setting for level flight at 70 KIAS for traffic pattern entry.
I've been flying a Tecnam Echo Super for the last two years. I found it
really likes to be at exactly 52 KIAS with full flaps when it is time to
flare for landing. If it is slower than that it just slams into the
runway no matter what the pitch. If faster it floats forever. (It
stalls at 38 KIAS dirty.) I plan to try this same speed for the Zodiac
landing, but would be delighted to hear what others use. Also the best
glide speeds for the Echo are around 70 clean and 60 dirty. Since the
Zodiac has nearly exactly the same wing loading I expect it to have
similar key speeds. (I am used to using Knots rather then MPH.)
I just started a first-cut checklist for my Zodiac. I didn't use one at
all with the Echo. It was such a simple plane I really didn't need
one. The Jabiru engine rather than Rotax and low wing vs. high wing
makes a number of issues to check like carb heat, electric fuel pump,
and fuel tank selection. The Rotax powered Tecnam Echo has a gravity
feed fuel system and no air box as well as no vacuum pump. Both planes
have Dynon based instrument panels so there is no need to set and
monitor a DG. To get the Echo going all you need to do is set the
altimeter and radios, set take-off flaps (there is a line marked TO on
the readout) and do a quick mag check. You could put a checklist for
that plane on the back of a fortune cookie insert.
I have an appointment with a DAR for 1:00 this afternoon. If all goes
well I will have an airworthiness certificate tonight. That seems a bit
risky because of issues with the MIDO and their DAR list, but I won't
bore everyone here with FAA politics. I'm just hoping it all works out OK.
Then my biggest problem planning my first flight is determining who to
invite to watch and/or help. I have offered the opportunity to my wife
and at least one EAA chapter member has expressed great interest in
helping. My first choice would be to just do it without anybody else
involved.
Paul
On 7/7/2011 4:39 AM, Dave Austin wrote:
<daveaustin2(at)primus.ca>
Hey Paul,
point you have to, not stop listening to all the "what could happen"
stuff that comes at you, but make a decision to fly based on your
was advised strongly at first flight for the Spitfire (taildragger) do
not attempt to do hops on the runway. That's the way to lose
the same. If it doesn't yaw or do something wierd as you lift off, go
for the circuit.
Enjoy.
Dave Austin
Posted: Thu Jul 07, 2011 5:09 pm Post subject: Finally getting close to certification. |
Thanks guys,
Well, there's DARs and then there's DARs and never the twain shall meet.
I got my plane certified this afternoon. It turns out there are
"Manufacturing" DARs that report to the MIDOs and "Maintenance" DARs
that report to FSDOs. The ones you want for an E-AB inspection are
Maintenance DARs. If you are manufacturing type certificated planes you
need Manufacturing DARs. They cost a lot more and have much busier
schedules. I went the wrong way asking the local MIDO for an inspection
instead of the local FSDO. It all worked out in the end, but this is a
mistake I made that others can learn from.
My inspection took about three hours. The last of the hours was just
doing paper work. It was quite painless. The DAR found a few small
things that should be corrected before I fly the plane, but they were
really small. In one case there was an edge to a piece of skin that was
not smooth and he suggested running some sandpaper or a file over it.
Another case was some wires in the engine compartment he was afraid
might rub on adjacent metal parts.
There was one interesting discussion that everyone can gain from. He
asked me if I had done engine testing from both tanks, and the answer
was no. He suggested I do some taxi testing from the other tank and
then clean out the gascolator before flying the plane. This was great
advice. I have read several accident reports about fuel starvation
because of manufacturing trash (chips, etc.) in the fuel system that
could have been removed before flight.
I don't know exactly when I will be able to get the plane in the air,
but it will be a few days for sure. I have to put it all back together,
fix the squawks, and do the engine testing from the other tank.
Paul
XL - now a real airplane
On 7/7/2011 11:07 AM, Don Honabach wrote:
I second that
Don
vvkidd(at)mindspring.com Guest
Posted: Thu Jul 07, 2011 5:31 pm Post subject: Finally getting close to certification. |
Congrats.
Victor Kidd
N922VK CRW WV
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Fri Jul 08, 2011 8:12 am Post subject: Re: Finally getting close to certification. |
Paul,
Congratulations on getting your certification. I hope your first flight is as enjoyable as mine was. I will only add one caution about the responsive pitch control and how I personally witnessed a fellow 601XL builder almost conclude his first flight quite prematurely. When the elevator comes in trail, at around 35 MPH or so, pull the stick back another 1-2 inches and hold it there. Upon rotation, hold it there like a rock and don't move it until your are a good 100" above the ground. This other pilot popped the stick back at rotation speed, was a bit surprised at the fast pitch rate and pushed back down, slamming on the runway, pulled back again, and this time remained airborne. I have the video and it still scares me to watch it today.
Now don't let me scare you. You will surely learn and get used to the pitch response quickly during your phase 1 flight testing. The first rotation is not the place you want to be surprised.
Now to 2nd Mr. Austin's remarks, get in the cockpit and fly the bloody thing..
Dave
_________________ David Gallagher
Cincinnati, OH area |
Posted: Fri Jul 08, 2011 1:08 pm Post subject: Finally getting close to certification. |
Hi Dave,
Thanks for the advice. It sounds very good but I'm afraid I just don't
fly the way you described.
My style of flying is to use the controls to get the attitude I want
without paying any attention at all to how much force or movement I
experience on the controls. I think I can translate your excellent
advice to my style of flying by saying I should raise the nose for
take-off (rotate) and hold it in that position. That is the way I
normally fly any plane. The only difference is the visual image I get
from one plane to another. Some take off without any pitch change while
others raise the nose a "couple of fingers".
I spent a few hours this morning replacing all the inspection panels and
other stuff that was removed for the inspection. I still need to do
another round of taxi testing including using the other fuel tank,
running the engine up to full power and holding it there for a couple of
minutes (if it doesn't get too hot), checking carb heat and doing a
magneto check. After all that I need to clean out the gascolator. Then
it is really time for me to find nice weather and do the first flight.
I really appreciate all the comments I have been getting from list
members and also pilots at my field. I'm sure all will go well. It is
not a big surprise that I am a little bit nervous over all this. I
would be more worried if I wasn't.
Paul
Camas, WA
On 7/8/2011 9:12 AM, DaveG601XL wrote:
| Quote: | Paul,
Dave
David Gallagher
601 XL/Jabiru 3300
First flight 7/24/08
Upgraded 3/19/10
