Flying into the Europa Cub International fly in and A.G.M. a
houlihan(at)blueyonder.co
PostPosted: Sun Jul 03, 2011 1:55 pm    Post subject: Flying into the Europa Cub International fly in and A.G.M. a Reply with quote
Direct flights to Popham from the EU.
   Most of you planning to fly to the UK would normally come through a Customs airfield such as Lydd or Southampton. It is possible though to fly directly to certain airfields from the EU by giving notice to UK Customs a minimum 4 hours before arrival. Full details are in the document links below, but to summarise this is what you need to do:
 -         Minimum4 hours notification to UK Customs, you can file the day before if you wish
-         Fax +441708 862521 or email ncu(at)hmrc.gsi.gov.uk (ncu(at)hmrc.gsi.gov.uk)
-         Subject/header must include ‘GAR’, registration and destination airfield (eg: GAR,G-BXUM, Popham)
-         Aircraft details:
-             Registration,Type, Usual base, Owner/Operator, Crew Contact Telephone number, aircraft less than 8000kg – Yes, Has UK VAT been paid – Yes or No, Is aircraft in‘Free Circulation within EU – Yes (Normally for most of you I would assume!)
-         Flightdetails:
-             Departure/arrival airfield ICAO or name, Arrival time (UTC), UK County – Hampshire (for Popham), Reason for visit to EU – ‘Short term visit’
-         Crew/Passenger details:
-             Name,Date and Place of Birth, Nationality and Passport Number, whether Crew or Passenger
   The full document can be found at the HMRC site, together with the instruction sheet:-
 http://customs.hmrc.gov.uk/channelsPortalWebApp/channelsPortalWebApp.portal?_nfpb=true&_pageLabel=pageTravel_Forms&propertyType=document&id=HMCE_PROD1_029410
 http://customs.hmrc.gov.uk/channelsPortalWebApp/channelsPortalWebApp.portal?_nfpb=true&_pageLabel=pageTravel_Forms&propertyType=document&id=HMCE_PROD1_029412
Or search on Google with ‘HMRC GARform’.  An editable word version is attached .
All the best,
Dave Bosomworth
gar_flight_notification_blank_form.doc
 Filename:  gar_flight_notification_blank_form.doc
 Filesize:  261 KB
 Downloaded:  3294 Time(s)
