Door pull
fredorosa(at)gmail.com
PostPosted: Sat Jul 02, 2011 9:01 am    Post subject: Door pull Reply with quote
Wondering what builders have done as an aid for closing an open door while sitting inside?
Al
Robert Reed
PostPosted: Sat Jul 02, 2011 2:30 pm    Post subject: Door pull Reply with quote
Al,
My first thought was to lift lots of heavy weight with one arm in order to lengthen it but when that didn't work I decided to install a flexible handle from a car.  I will still have to lift myself up some to grab it but it should make it a bit easier to pull it down. Being a bit on the short side I recognized that getting that door down was going to be interesting but the only thing I could ever come up with seemed like it would be more trouble that it was worth. I remember some old cars used to have a flexible loop type handle on the side posts. I haven't seen one in years but always thought it would be ideal if installed where it would hang down when the door was open but fold against the door when closed.
Hope to finally get back to work on the plane this year,
Bob Reed
To: kisbuilders <kis-list(at)matronics.com>
Sent: Sat, July 2, 2011 12:01:05 PM
Subject: Door pull
Al
[quote][b][b]
kentpyle(at)iland.net
PostPosted: Sat Jul 02, 2011 3:55 pm    Post subject: Door pull Reply with quote
Al, I made a 4" loop of webbing and screwed it into the bottom of the door. It sticks straight out and is easy to grasp. As I pull the door shut it sticks inside the airplane so it doesn't flap on the outside of the plane. Kent
bakerocb
PostPosted: Sat Jul 02, 2011 8:06 pm    Post subject: Door pull Reply with quote
7/2/2011
Hello Al, I have a short length (maybe 12 inches long) of nylon cord coming out of a hole on the inside of the fat part of each door. A knot on the outer end of the cord keeps the cord end from pulling out through the hole.
On the cockpit inner end of each cord I have a round wooden bead (maybe 5/8 inch in diameter) with a hole through the bead and a recessed portion in the hole for a knot on the end of each cord to keep the bead from coming off.
The cords hang down with the beaded ends within easy reach for pulling the doors down with the cord into the door closed position. Additional inward pull is also applied by pulling inward on the beaded cord end as the other hand moves the latch handle into the door pinned closed position. (A slight door inward wedging action is created when the door latch handle is moved into the pinned closed position by the door pin design.)
Then each cord is wrapped around the door latch handle knob a few times to both keep the cord out of the way and to add some additional insurance that the latch handle will not inadvertently move to the open position while in flight. (The primary means of keeping the door latches in the closed position is the Europa shoot bolt mechanism.)
For some cooling air one can taxi with an elbow holding the door open a bit while that same hand is used to hold the cord to keep the door from moving further open.
An additional consideration is that a person on the ground can force the door latch into the door unlatched position in an emergency rescue situation because the nylon cord will slip and unwind if enough force is applied to the exterior door latch handle.
I'd be happy to take and send or post some pictures if anyone is interested.
'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge."
[quote] From: ALFRED ROSA (fredorosa(at)gmail.com)
To: kisbuilders (kis-list(at)matronics.com)
Sent: Saturday, July 02, 2011 1:01 PM
Subject: Door pull
Al
wschertz(at)comcast.net
PostPosted: Sun Jul 03, 2011 4:15 am    Post subject: Door pull Reply with quote
Al,
I just reach up to the front of the door and pull it down, however I did install a small knob on the rear of the door, so that I can reach back and pull the rear of the door securely shut before engaging the pins with the Lyle Latch.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase one testing Completed
Sent: Saturday, July 02, 2011 12:01 PM
Subject: Door pull
Al
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
teds532(at)wk.net
PostPosted: Sun Jul 03, 2011 9:30 am    Post subject: Door pull Reply with quote
I BUILT MY CLOSING HANDEL INTO THE ARM REST THAT ALSO HIDES THE DOOR LOCKING SYSTEM.IT IS ON THE BUILDERS WEB SITE
jerzy_krasinski(at)sbcglo
PostPosted: Sun Jul 03, 2011 12:10 pm    Post subject: Door pull Reply with quote
I did not install anything, and I never had any troubles to reach the door.
Jerzy
To: kis-list(at)matronics.com
Sent: Sat, July 2, 2011 5:29:42 PM
Subject: Re: Door pull
Al,
Bob Reed
Subject: Door pull
Al
[quote][b][b]
bakerocb
PostPosted: Tue Jul 05, 2011 8:11 pm    Post subject: Door pull Reply with quote
4/5/2011
Hello Al, Attached are two pictures of my KIS TR-1 door pull system.
Picture 0548 is taken with the copilot's door partially open (for picture taking purposes). When the door is fully open the string and ball hanging down makes it still possible to reach the ball and pull the door down and then the bottom end of the door inward for latching purposes.
Picture 0553 is taken with the copilot's door closed and the string wrapped over the handle and then around the handle knob to both keep the string out of the way and provide additional assurance that the handle will not inadvertently move to an open position. A little bit of bees wax rubbed on the string from time to time provides just the right combination of stiffness and stickyness.
Notice the taper on the end of the locking pin. This provides a wedging closed effect. The aluminum bracket that the pin goes into holds a nylon disc with a hole in it that the locking pin actually comes into contact with. The nylon disk provides a lubricating effect so that I don't have aluminum rubbing against aluminum during the pin locking movement.
This system has worked perfectly for over 336 hours.
To: bakerocb(at)cox.net (bakerocb(at)cox.net)
Sent: Sunday, July 03, 2011 9:03 AM
OC, good to hear from you. Yes, send some pictures if it's not too much trouble.
Bob, good to hear you're getting back to finishing the project. What's left to do?
Al
On Sun, Jul 3, 2011 at 12:05 AM, <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
Subject: Door pull
Al
 Filesize:  1022.15 KB
 Viewed:  9848 Time(s)
 Filesize:  854.93 KB
Robert Reed
PostPosted: Wed Jul 06, 2011 7:09 am    Post subject: Door pull Reply with quote
Come on Al, we live in a time when nothing is simple and only complex solutions are acceptable. Nothing that simple could possibly work, don't you know that?
I like it, but then again, I am just a simpleton.
Bob Reed
To: ALFRED ROSA <fredorosa(at)gmail.com>; "KIS-LIST, MATRONICS" <kis-list(at)matronics.com>
Sent: Tue, July 5, 2011 11:10:24 PM
4/5/2011
Subject: Re: KIS-List: Door pull
Al
Subject: Door pull
Al
PostPosted: Wed Jul 06, 2011 9:25 am    Post subject: Door pull Reply with quote
Are you're referring to OCs pull string solution?  It's simple all right and effective.  Only thing is it doesn't look aeronautical with it's homespun
materials.  Iv'e decided to try an aluminum pull grip riveted to the door.  Will post a picture.
Al
On Wed, Jul 6, 2011 at 11:08 AM, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
[quote] Come on Al, we live in a time when nothing is simple and only complex solutions are acceptable.  Nothing that simple could possibly work, don't you know that?
Bob Reed
From: "bakerocb(at)cox.net (bakerocb(at)cox.net)" <bakerocb(at)cox.net (bakerocb(at)cox.net)>
To: ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)>; "KIS-LIST, MATRONICS" <kis-list(at)matronics.com (kis-list(at)matronics.com)>
4/5/2011
Al
To: kisbuilders
Subject: Door pull
Al
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
Robert Reed
PostPosted: Wed Jul 06, 2011 2:32 pm    Post subject: Door pull Reply with quote
Yes, I was but then I told you I was a simpleton.  <BG>
Date: Wednesday, July 6, 2011, 12:25 PM
Al
Bob Reed
4/5/2011
Al
7/2/2011
bakerocb
PostPosted: Thu Jul 07, 2011 3:47 am    Post subject: Door pull Reply with quote
7/7/2011
Hello Al, You wrote: ".... it doesn't look aeronautical....."
I am not the least bit offended by your comment.
It does tend to reenforce an opinion I have that people are divided into two categories. Upon encountering something new the first category asks themselves only: "How does it work?" The second category asks themselves only: "How does it look?"
I am definitely in the first category. You (and my wife) are in the second category. The world requires both categories of people otherwise we would live in a very functional, but maybe unattractive world, or a beautiful, but useless world.
PS: I hope that your arms are long enough to reach your aluminum handle to start pulling the doors closed from a fully open position. I look forward to seeing your picture.
Sent: Wednesday, July 06, 2011 1:25 PM
Al
Robert Reed
PostPosted: Thu Jul 07, 2011 6:45 am    Post subject: Door pull Reply with quote
By the way OC, I hope you realize that I was giving you a complement in my off-handed way. I think your solution is really in keeping with the KIS concept that we seem to sometimes forget.
Bob Reed
To: kis-list(at)matronics.com; robertr237(at)att.net; ALFRED ROSA <fredorosa(at)gmail.com>
Sent: Thu, July 7, 2011 6:45:58 AM
7/7/2011
Hello Al, You wrote: ".... it doesn't look aeronautical...."
Al
[b][b]
PostPosted: Thu Jul 07, 2011 7:08 am    Post subject: Door pull Reply with quote
That's too black and white OC. I firmly believe that form follows function, however that form has to be
beautiful (if possible).  I think both are achievable.   Photos on the way.
Al
galinhdz(at)gmail.com
PostPosted: Thu Jul 07, 2011 7:50 am    Post subject: Door pull Reply with quote
FWIW I think it is a GREAT design, especially how well it "flows". Surprised)
Galin
On Thu, Jul 7, 2011 at 10:07 AM, ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
Al
PostPosted: Thu Jul 07, 2011 7:58 am    Post subject: Door pull Reply with quote
Al, you have a bulge on the lower part of the inside door frame. You can drill from the bottom and put and alumiumn wire handle through the holes. This makes an nice loop to grab onto. It has worked for me for 175 hours. Kent
PostPosted: Thu Jul 07, 2011 10:22 am    Post subject: Door pull Reply with quote
[img]cid:ii_13105cc9df67a57e[/img]Here is my solution to a door pull. A piece of angle aluminum riveted to the door frame.  It requires getting off your ass
to reach but it gives a very good grip to hold door tightly shut while engaging the lock pins with the crank handle.
My plane has rear wing boarding so the outside handle is on the right side of the door.  The crank drives a spur gear
which engages teeth in the square rod pin.  One complete turn locks or unlocks the door.  A thumbscrew fits a hole to
lock the crank handle in the closed position.
 Filesize:  220.14 KB
 Viewed:  9829 Time(s)
bakerocb
PostPosted: Thu Jul 07, 2011 11:24 am    Post subject: Door pull Reply with quote
7/7/2011
Hello Al, Thanks for the picture and the explanation -- a very neat installation.
PS: I note with pleasure your use of the Torx (6 lobe) drive, countersunk, flat head, stainless steel machine screws from Microfasteners. It helps to justify the long effort that I put into having those screws created and available to our homebuilding community.
Sent: Thursday, July 07, 2011 2:22 PM
Subject: Door pull
[img]cid:D3BE398151794E02BC1B1D47AC9EA11F(at)TCS21920[/img] Here is my solution to a door pull. A piece of angle aluminum riveted to the door frame. It requires getting off your ass
 Filesize:  220.14 KB
 Viewed:  9824 Time(s)
PostPosted: Thu Jul 07, 2011 7:48 pm    Post subject: Door pull Reply with quote
I use a lot of those microfastener screws on my airplane. Surprised)
neat installation.
PM
Subject: Door pull
</mail/s/?view=att&th=131061237b8db666&attid=0.1&disp=emb&zw>
position.
