Dennis Thate
Posted: Fri Jul 01, 2011 2:48 am Post subject: A safe idea? |
I've seen Kolb Firestars with aileron stops placed to prevent aileron movement beyond 15 degrees. What is the purpose of this device? Is this a safe idea?
43.15 KB |
4682 Time(s) |
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
by0ung(at)q.com Guest
Posted: Fri Jul 01, 2011 5:52 am Post subject: A safe idea? |
safe idea?
Dennis
I don't know a lot about aerodynamics,,,, but I would believe that beyond
that point the aileron would ace like a set of spoilers, and they could
stall and loose their ability, or their ability would be greatly reduced, to
create the desired results. if you can keep the air attached from the
wing to the aileron the effects would be greater, drag would increase as the
aileron travels beyond the point the air begins to separate.
boyd young
mkiii utah
Richard Pike
Posted: Fri Jul 01, 2011 7:14 pm Post subject: Re: A safe idea? |
In which case it would be better to relocate the lower aileron push rods closer to the pivot point as that will give you a lesser throw and also reduce the amount of pressure required to move the ailerons.
Like this: http://www.bcchapel.org/pages/0003/FSII%20ailerons.html
Kills 2 birds with one stone.
Richard Pike
MKIII N420P (420ldpoops)
Kip
