Baffle advice
rleffler
PostPosted: Wed Jun 29, 2011 5:04 pm    Post subject: Baffle advice Reply with quote
I ran into a couple “opportunities” at the hangar this evening that I’m soliciting opinions while I research for solutions. The first issue is that the rear support brace for the baffle and one of the fuel tubes want to occupy the same space. Since the fuel injector fuel lines were installed at Lycoming, I’m not quite sure how to proceed. I’m concerned that if I attempt to bend the fuel line up, I may put a crease in the line. I’m not sure if I should be concerned that with the other five cylinders are all horizontal in the same plane, if this line is elevated to get over this bracket. Another option I thought about was to cut a slot in the bracket and isolate the fuel line with a grommet. I haven’t referenced 43.13 yet to see what guidance it may provide.
The next issue probably falls in the category of me doing something wrong or not doing the obvious. What’s the secret to get this baffle mounted without severely bending it?
Any suggestions are appreciated.
25 days and counting……
bob
 Filesize:  619.35 KB
 Viewed:  10181 Time(s)
 Filesize:  593.99 KB
 Filesize:  608.27 KB
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
pitts_pilot(at)bellsouth.
PostPosted: Wed Jun 29, 2011 5:40 pm    Post subject: Baffle advice Reply with quote
If it were me, I'd mark the baffle where the tubing is, cut a 1/2 quarter size bite out of the bracket. Clean up the edges and re-install the bracket. I'm not there yet, so don't know if I'll have the same problem.
Linn
On 6/29/2011 8:55 PM, Bob Leffler wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Kellym
PostPosted: Wed Jun 29, 2011 6:59 pm    Post subject: Baffle advice Reply with quote
Your best guidance is Lyc SB 342E, page 25, a specific diagram of where
the lines are required to be, per AD 2008-14-07 Lycoming Engines
(formerly Textron Lycoming Division, AVCO Corporation): Amendment 39-15602.
I won't get into the debate as to whether it is a requirement for
experimentals.
Main concern with those lines is weakening the fitting joints at either
end and ensuring they are adequately supported so that they don't work
harden from vibration. You can gently bend in the middle, keeping
bending forces away from the ends as long as you keep large radius. I
wouldn't worry about elevation. The fuel is under 4-10 psi in those
lines, generally. I agree with Linn's advice, to first try to remove
enough of the baffle support to allow the line to remain in the location
Lycoming placed it.
Kelly
PS, I can email you the SB direct if you need it.
provide.
bob
Kelly McMullen
KCHD
robin(at)PaintTheWeb.com
PostPosted: Wed Jun 29, 2011 7:44 pm    Post subject: Baffle advice Reply with quote
Along with the aforementioned solution is the possibility to add another adel clamp to further stabilize the tube as it bypasses the bracket.
Robin
flysrv10(at)gmail.com
PostPosted: Thu Jun 30, 2011 1:32 am    Post subject: Baffle advice Reply with quote
Cut the bracket.
do not archive.
<image007.png>
<image008.png>
<image009.png>
bob
aerosport1
PostPosted: Thu Jun 30, 2011 4:15 am    Post subject: Baffle advice Reply with quote
Bob make a nice half round cut out in the bracket. I had to cut mine out for my Ignition coil.
See link
http://cdn-3-service.phanfare.com/images/external/7068012_3161550_64301362_Web_3/0_0_c6e7e93ae7bc906cc3c993621baec8f6_1
[b]Geoff Combs[/b]
President
[b]614-834-5227p[/b]
614-834-5230f
www.aerosportmodeling.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Wednesday, June 29, 2011 8:55 PM
Subject: Baffle advice
bob
 Filesize:  73.13 KB
 Viewed:  10153 Time(s)
 Filesize:  67.26 KB
 Filesize:  80.28 KB
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
drfred(at)suddenlinkmail.
PostPosted: Thu Jun 30, 2011 5:07 am    Post subject: Baffle advice Reply with quote
I cut a slot in mine right where you show. Rounded the hole. no problems 3+ years.
Dr Fred
515FW.
Tim Olson
PostPosted: Thu Jun 30, 2011 5:08 am    Post subject: Baffle advice Reply with quote
Same here:
http://www.myrv10.com/N104CD/engine/20051107/RV200511060004.html
http://www.myrv10.com/N104CD/engine/20051107/RV200511060007.html
The bracket will be fine.
Tim Olson - RV-10 N104CD
See link
**Geoff Combs**
President
**614-834-5227p**
614-834-5230f
www.aerosportmodeling.com <http://www.aerosportmodeling.com>
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bob Leffler
*Sent:* Wednesday, June 29, 2011 8:55 PM
*To:* rv10-list(at)matronics.com
*Subject:* Baffle advice
bob
rleffler
PostPosted: Thu Jun 30, 2011 6:09 pm    Post subject: Baffle advice Reply with quote
Here’s the final result. There’s about 1/8” gap between the fuel line and the bracket. I may take a little more off, just for a safety margin.
<![endif]--><![if !vml]>[img]cid:image002.png(at)01CC3771.2580EC60[/img]<![endif]> \s <![endif]-->
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
Sent: Thursday, June 30, 2011 5:28 AM
Subject: Re: Baffle advice
Cut the bracket.
 Filesize:  600.33 KB
 Viewed:  10131 Time(s)
Bob Leffler
N410BL - Phase I
PostPosted: Fri Jul 01, 2011 9:48 am    Post subject: Baffle advice Reply with quote
That still looks too close to me.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Bob Leffler
Sent: Thursday, June 30, 2011 7:01 PM
Subject: RE: Baffle advice
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob Kermanj
Cut the bracket.
 Filesize:  602.61 KB
 Viewed:  10110 Time(s)
rleffler
PostPosted: Fri Jul 01, 2011 3:56 pm    Post subject: Baffle advice Reply with quote
There’s more of a gap than it looks in the picture.  With that said, I plan on opening the gap from 1/8” to ¼”.
bob
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Friday, July 01, 2011 1:45 PM
Robin
Cut the bracket.
 Filesize:  602.61 KB
 Viewed:  10105 Time(s)
Bob Leffler
N410BL - Phase I
AV8ORJWC
PostPosted: Fri Jul 01, 2011 5:01 pm    Post subject: Baffle advice Reply with quote
You can take a rubber grommet of the correct I.D., cut it cross-sectional from the center out to the circumference to insert over the injector line and slide it right over the modified bracket. That will give you correct separation and dampening.
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of Bob Leffler
Sent: Fri 7/1/2011 4:48 PM
bob
Robin
[img]image001.png[/img]
Cut the bracket.
 Filesize:  602.61 KB
 Viewed:  10101 Time(s)
