brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sat May 13, 2006 7:31 am Post subject: OV module for CJ6A generator |
Blitz was going to be the guinea pig for the new OV protection module
for the CJ6A generator system. Unfortunately his schedule hasn't
worked out to install it in his airplane so I am looking for someone
else who is willing to install this in their airplane.
The module is really quite simple in that it operates a relay to
disconnect the generator's field and taking the generator off-line
should the module detect an over-voltage situation, i.e. bus voltage
in excess of 32V for more than 100 ms. (The 1/10 second delay is to
keep transients from accidentally triggering an OV event.)
Installation is quite simple. There is a module, a relay, an
indicator lamp, and a test/reset switch. The only modification that
needs to be made to the aircraft wiring is to cut the field lead
somewhere and connect the cut ends to two of the relay terminals. If
this is done with knife-splices then the module may be removed and
the generator system returned to stock configuration in only a few
minutes. There are only a couple of other connections to the
electrical system, power and ground, so the installation is really
quite non-invasive.
The production kit is probably going to go for $150 or more so here
is your chance to get one for free. If you are willing to come to the
Sacramento area with your aircraft I will install it for you. If not,
I will be happy to send you the module and then do my best to hold
your hand through the process over the phone.
I would like to do this within the next three weeks as I will be
leaving for an extended trip starting June 8. (I am heading for the
USVI for my son's HS graduation and then wandering about the US on
holiday until OSH, after which I will be returning to the People's
Republic of California.)
Please reply to me directly as I do not subscribe to the yak-list.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
"Five percent of the people think.
Ten percent of the people think they think.
Eighty-five percent of the people would rather die than think."
---Thomas A. Edison
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
CZ
Posted: Fri Aug 21, 2009 8:09 am Post subject: Re: OV module for CJ6A generator |
Hello,
Is this US voltage regulation module for CJ currently available?
chriszimmer2002(at)yahoo.com
