grosseair(at)comcast.net Guest
Posted: Sun Jun 26, 2011 7:50 am Post subject: Diodes on Relays |
I understand about using diodes to protect the contacts on contactors,
but I'm wondering why we don't typically use them on smaller
electro-mechanical relays in the 20-40 amp range such as
http://www.newark.com/jsp/search/productdetail.jsp?SKU=34M8970
Is it the lower current? If so what's the point where you do or don't
need a diode across the coil contacts?
John Grosse
Posted: Sun Jun 26, 2011 8:03 am Post subject: Diodes on Relays |
At 10:46 AM 6/26/2011, you wrote:
contactors, but I'm wondering why we don't typically use them on
smaller electro-mechanical relays in the 20-40 amp range such as
don't need a diode across the coil contacts?
No hard and fast rule. The diode, or any other "spike suppression"
device is really an energy management tool. EVERY inductive
device has a potential for returning a bundle of stored energy
back into the system when the energizing source of current is
broken.
In some cases, that energy has the potential for (1) causing
anomalous behavior in some other system, (2) erosion of
contacts for the controlling switch, (3) damage to the
controlling solid state device . . . or some combination
of the three.
There are many cases where none of these risks are significant
and spike suppression is not part of the design. Except for
rare instances involving close control of relay operating
speed, ANY of the legacy spike suppression techniques is
useful to the task . . . and if you're in doubt, it doesn't
hurt to add it.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
Posted: Sun Jun 26, 2011 11:52 am Post subject: Diodes on Relays |
I understand about using diodes to protect the contacts on contactors, but I'm wondering why we don't typically use them on smaller electro-mechanical relays in the 20-40 amp range such as
Is it the lower current? If so what's the point where you do or don't need a diode across the coil contacts?
broken.
A little elaboration . . .
EVERY conductor of electrons has some predictable
and measurable inductive AND capacitive component . . .
even a lowly chunk of wire running from point A to
point B. For wires the value of capacitance to any
adjacent conductors manifests in PICO farads per
foot. Inductance for a 10' length of 22awg wire is
in the neighborhood of 30 NANO henries per foot.
Neither characteristic's magnitude large enough
to be significant storage reservoirs of energy.
Now, wind say 50' of 30AWG wire around a core
and put it inside the shell of a contactor to
operate the armature and the ability to store energy
takes a quantum jump. Fabricating two conductors
of significant area on either side of a dielectric
material and that too creates a huge increase in
capacitance along with an ability to store energy.
Playing the energy management game in any system
of interactive components is a juggling act. The
goal is to (1) understand significant sources of
rogue energy, (2) identify potential risks for
letting that energy roam free in the wild and (3)
deducing what techniques are most practical for
keeping risks to vulnerable systems within reason.
In some cases you can never corral all the errant
energy, in some cases you design potentially
vulnerable systems to shrug off potential
antagonists at or below certain levels.
In other words, craft a full-up system where
there is a comfortable band of separation between
ability to withstand versus ability to control
the deleterious exchange of energy between systems.
Small relays controlled by ordinary switches
do not represent a cost of ownership/service
life issue . . . so the designer may choose
to leave energy mitigation devices off the
bill of materials. At the same time, that
exact same combination of inductance and switch
might produce transients that are antagonistic
to the performance of some high-speed digital
system . . . but if the designers of systems
at high risk for interference are doing their
job, risks generated by the occasional operation
of a switch on the panel are accommodated by
design. See:
http://tinyurl.com/ybhvxal
My assertion for 'no hard and fast rules' was
not intended to minimize the need for understanding
exactly how all the ingredients for your particular
recipe come together. The competent observer
will take note of that 'hiccup' in display being
coincident with operating the switch and then
decide if there is value in changes to the recipe
to correct the phenomenon. He will also note that
some switch is demonstrating a poor service
life and do something about it . . .
http://tinyurl.com/3k6he9s
Bob . . . [quote][b]
fvalarm(at)rapidnet.net Guest
Posted: Sun Jun 26, 2011 12:45 pm Post subject: Diodes on Relays |
I've recently discovered that the 20 amp relays that B&C sells have non-polarity sensitive coil terminals. Does this mean that there are (steering) diodes already built into the relay? And if so, do these same diodes take care of the small inductive spike on release?
Bevan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Sunday, June 26, 2011 12:49 PM
Subject: Re: Diodes on Relays
broken.
design. See:
Bob . . . [quote]
Bob McC
Posted: Sun Jun 26, 2011 6:02 pm Post subject: Diodes on Relays |
Bevan;
MOST small relays are NOT polarity sensitive. For the most part, the only ones that are, are the ones containing spike suppression diodes or LED indicators. The relay coil itself doesn’t care about polarity.
The B&C relays are most likely generic basic relays without any sort of diodes such as the ones linked to by John at the start of this thread.
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of B Tomm
Sent: Sunday, June 26, 2011 4:43 PM
Subject: RE: AeroElectric-List: Diodes on Relays
Bevan
Subject: Re: AeroElectric-List: Diodes on Relays
broken.
design. See:
Bob . . . | Quote: | | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c - The AeroElectric-List Email Forum - | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 4
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sun Jun 26, 2011 9:24 pm Post subject: Diodes on Relays |
At 08:57 PM 6/26/2011, you wrote:
| Quote: | Bevan;
Correct. The only relay I used to sell that did
have the built in diode was a starter contactor . . .
and it was available either way. There was some
notation like 'coil suppression' stamped on the
bottom of the one with a diode.
I'm aware of no relays other than mil-spec devices
and a few 'upper crust' industrial relays that
commonly sport the built in suppression.
[img]cid:.0[/img]
This one clearly does not . . .
[img]cid:.1[/img]
While the schematic on the enclosure for this one shows
a diode and clear (+) mark for the coil polarity.
If the relay you have in hand DOES include coil
suppression, then it will be clearly marked as such
in some manner on the outside. Otherwise, relay
coils are not polarity sensitive.
108.1 KB |
5103 Time(s) |
47.5 KB |
5103 Time(s) |
sprocket(at)vx-aviation.c Guest
Posted: Mon Jun 27, 2011 7:17 am Post subject: Diodes on Relays |
I’ve successfully used these automotive types with built-in supression (resistors):
http://search.digikey.com/scripts/dksearch/dksus.dll?Keywords=255-2161-ND&site=US&WT.mc_id=tbr_srch&WT.mc_ev=click
Also available with diodes, but the resistor type is polarity insensitive.
Vern
From: Robert L. Nuckolls, III (nuckolls.bob(at)aeroelectric.com)
Sent: Sunday, June 26, 2011 10:21 PM
Subject: RE: Diodes on Relays
| Quote: | Bevan;
MOST small relays are NOT polarity sensitive. For the most part, the only ones that are, are the ones containing spike suppression diodes or LED indicators. The relay coil itself doesnÂ’t care about polarity.
[img]cid:4D7B85A593F2463C8EA61888B6BDC03B(at)Sprocket[/img]
[img]cid:CDFAA29602B54E8BBB7E7AA3B1D4A9CD(at)Sprocket[/img]
Checked by AVG - www.avg.com
Version: 10.0.1388 / Virus Database: 1513/3728 - Release Date: 06/26/11
108.1 KB |
5087 Time(s) |
47.5 KB |
5087 Time(s) |
