tc
Joined: 25 Mar 2010 Posts: 11 Location: Woodbridge, VA (fly KHEF)
Posted: Fri Jun 24, 2011 8:03 am Post subject: Replace / Repair Rocket Exhaust Pipe & Replace / Repair (?) |
Normal 0 false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> st1\:*{behavior:url(#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
N85TP, HR II, completed 1996, now lives at Manassas, VA, Regional.
I'm new guy to Rocket and couple problems showing up on my first annual:
1. Warped flange on the aft left section of the cylinder #6 exhaust pipe -- causing exhaust leak.
It’s the original pipe, believe John Harmon’s early design (have asked him about it) – bad section is on right side of attached photo.
Anybody know if / how I can get replacement part, or maybe a great welder who could remove / replace the flange? Other ideas?
2. Original fiberglass 15” dia. Spinner’s prop hub front plate is damaged; it’s 10 5/8” dia., attached inside spinner with four screws and to Hartzell prop hub with four bolts. Attaching photo. Ideas for who to contact for a replacement?
Tim Carey
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Rocket-List |
155.66 KB |
3512 Time(s) |
42.22 KB |
3512 Time(s) |
_________________ Tim Carey
Dulles Aviation, Inc., Manassas, VA
USAF, Retired |
smokyray(at)rocketmail.co Guest
Posted: Fri Jun 24, 2011 12:02 pm Post subject: Replace / Repair Rocket Exhaust Pipe & Replace / Repair (?) |
Tim, I removed my original exhaust and installed a Larry Vetterman system, much improved and worth every penny.He may also be able to help with repair,,although once removed my old system had cracks I couldn't see until off airplane. Replacing improved performance as well.
Spinner bulkhead, try aircraft spruce. FYI. A Cessna 310 spinner will R&R perfectly.
Smokey
Formerly HR2
Now RVX
On Jun 24, 2011, at 11:00, careytn(at)comcast.net (careytn(at)comcast.net) wrote:
[quote] Normal 0 false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> st1\:*{behavior:url(#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
Tim Carey
<IMG 0194 web size.jpg>
<IMG_0198 (Small).JPG>
