Install time for safety trim
robertbrunk(at)me.com
PostPosted: Wed Jun 22, 2011 5:00 am    Post subject: Install time for safety trim Reply with quote
I am having safety trim installed and my avionics man never did this one before. How long should it take. I have victory grips and a toggle switch to control the copilot activation. Robert N661G 300Hrs.
Robert Brunkenhoefer
Sent from my Apple iPad
Tim Olson
PostPosted: Wed Jun 22, 2011 5:18 am    Post subject: Install time for safety trim Reply with quote
I'd say it takes.....as much time it takes to complete it.
You now own an experimental, and your plane is probably
not identical to ANY other RV-10. Your wiring isn't
the same, your connectors may not be the same, where the
wires need to be connected wouldn't be the same,
and everything. It could take a couple hours, if you
had everything laid out for them, and convenient
connections, and had an accurate and clean wiring
diagram for them to follow. It could take them
a couple days, if they aren't provided with anything
to go on. I think it took me maybe 2-4 hours, but
I knew exactly where I was going to mount the box,
and knew which wires I was going to tap, and knew
where I was going to get power from, and mount the
panel switch.
So there's no real way to say....the actual wiring
is simple. The plane they have to wire it into
might not make it so simple.
Tim Olson - RV-10 N104CD
bgill1(at)charter.net
PostPosted: Wed Jun 22, 2011 9:00 am    Post subject: Install time for safety trim Reply with quote
I did mine in around 2 hours including mounting board and switch- but I was replacing another trim relay board so all the wires were there and I had excellent wire schematics from the panel builder (Stein). As Tim mentioned there are lots of variations in design and build. Running new wires etc would lengthen the operation significantly.
Byron
N253RV - Phase One
robertbrunk(at)mac.com
PostPosted: Wed Jun 22, 2011 11:44 am    Post subject: Install time for safety trim Reply with quote
Thank you for the input. Robert
Byron
N253RV - Phase One
