bgill1(at)charter.net Guest
Posted: Tue Jun 21, 2011 5:55 pm Post subject: AFS Engine Monitor - % Power info |
I am still fine tuning all the settings during phase one. One area that I am
not sure about is the % horsepower settings entered. I have the engine
manual and using the chart "sea level and altitude performance data
IO-540-D.." have tried to derive the required data for input..
Required inputs: For various RPM settings: MAP 55% and MAP75% settings -
Also the HP delta at different altitudes.
I have extracted some MAP numbers at the two HP settings from the charts and
it seems more like educated guesses than good info and not really sure how
to get the HP delta numbers. If someone has the info readily available, I
would really appreciate sending the data for reference. More importantly if
there is some info available on how best to generate the numbers from the
manual - it would be greatly appreciated. Feeling pretty ignorant at the
moment...
I didn't see anything in the archives relative. If you want to pm me at
bgill1(at)charter(dot)net it would be appreciated.
Byron
N253RV Phase one..
Posted: Tue Jun 21, 2011 6:16 pm Post subject: AFS Engine Monitor - % Power info |
If your AFS is and EM only, the %HP doesn't work yet - they haven't finished
the software to get altitude in to the equation from your GPS.....
%HP was one of the features that convinced me to go with AFS....I have since
upgraded it to SP with s processor and new screen and %HP now works - as it
can get altitude from the SP altimeter....
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Wed Jun 22, 2011 3:29 am Post subject: Re: AFS Engine Monitor - % Power info |
Byron,
Have you input the settings from the manual?
If you don't have the problem expressed by recapen, then if you have an IO-540 the settings are in the manual.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Posted: Wed Jun 22, 2011 4:59 am Post subject: AFS Engine Monitor - % Power info |
Got it.
Just downloaded updated manual and now the tables are included.
Thanks for the reply,
Byron
