Mike Welch
Posted: Tue Jun 21, 2011 11:01 am Post subject: IvoProp current limiter -revisit |
Bob N,
Quite a while back I built and installed the IvoProp current limiter circuit you desgned.
By all account, it appears to work, with one significant exception; it cuts out very quickly
when cycling in either direction. In other words, the blades barely move at all.
Yes, the LEDs light up, and all other aspects of the circuit appear to function properly.
The only weakness is the extreme shortage of blade movement. I know the obvious, question
is; do we know if the blades are free to mover properly? As far as I know, yes, they
used to work just fine, prior to the installation of the current limiter circuit.
Bob, is it possible to "vary" the circuit's current limitation. Example....if the present resistors
that control the circuit's current to "top out" at such and such amps, would it be reasonable to
redesign the circuit to allow for 'differing" overloads. Do you get what I'm trying to say?
By watching the entire system (circuit, prop blades/motor, etc), the circuit appears to
operate as it was designed, except that it appears to cut out at 1, maybe 2 amps.
I have to run off to Minneapolis for a few days, but when I get back, I'll hook up a
highly accurate ammeter in the present arrangement, and see exactly how much current
shuts it off.
Any ideas, or suggestions are highly appreciated.
Thanks, Mike Welch
Posted: Tue Jun 21, 2011 11:28 am Post subject: IvoProp current limiter -revisit |
At 02:56 PM 6/21/2011, you wrote:
| Quote: | Bob N,
move at all.
Okay, just so folks know what we're talking about here's a recap
of the circuit and design goals for the system Mike has crafted:
http://aeroelectric.com/Pictures/Schematics/IVO-Prop_Pitch_Controller.pdf
Design goals:
Provide absolute current limit on the order of 9A:
Q114 is a power FET that saturates with bias
through R104, R105 and D109 when power is applied
through "M" connections that sense motor power.
Voltage drop across R117/R118 is monitored through
R116 causing Q115 to turn on when drop across the
R117/118 exceeds Vbe of Q115. This is approx .6
volts. When Q115 turns on, it starves Q114 of gate
drive and causes it to become a constant current
generator with calibration set by the combination
of R117/R118.
Any time the constant current loop is active,
LED D109 will be illuminated. D109 will flash
each time the prop pitch motor is energized
and the system becomes an active inrush current
limiter.
Limit the duration of the current limit mode to
100-200 mS whereupon the system goes open circuit
and removes power from the motor:
At any time the current limiter is active,
Q115 collector current through R105 will turn
on Q103 causing the collector to pull up to
the supply rail. This causes C112 to charge
through R106 until zener D110 conducts at about
8V. This event will occur approximately 120 mS
after onset of current limit.
When D110 conducts, it pulls the base of Q115
more positive causing the Q115/Q103 pair to
"latch up" not unlike an SCR. When the latching
event occurs, the collector of Q115 pulls to
a few millivolts above ground depriving Q114
of all gate drive.
Normal operation:
D109 will flash each time the motor control switch
is closed due to motor inrush current being
electronically limited. D109 will also flash a
bit longer (about 120 mS) when the prop pitch motor
reaches the mechanical stop and the current limit is
invoked.
As long as the prop pitch motor is powered
D108 will be illuminated. When the prop
pitch system reaches a mechanical limit and
the control switch is NOT relaxed, D019 flashes
for about 120 mS and D108 goes dark.
Releasing the motor control switch removes
power from the latching loop and discharges
C112 through R119, R104, BC junction Q103,
and R106.
The system spends so little time in I-limit
mode that Q114 does not require a heat-sink.
D109 and D108 staying on together indicates
a malfunction and the motor control switch
needs to be released within a second or so
to avoid over-heat damage to Q114.
| Quote: | Yes, the LEDs light up, and all other aspects of the circuit
I know, yes, they
limiter circuit.
The green LED should be illuminated when the
pitch motor is being commanded and the system
is NOT in a current limited mode. If the
motor hits the stop and current spikes, the current
limit mode kicks in. The green LED should dim or
go dark . . . the amber LED should illuminate
saying that current limiting operation is in
effect. One should release the switch quickly
after the amber LED comes on.
| Quote: | By watching the entire system (circuit, prop blades/motor, etc),
maybe 2 amps.
Had you tested this before? With the values selected
for R117 and R118, current limit should be on the
order of 10 amps. If your 'stalled' current is
2A, then the current limit is kicking in MUCH to
low.
| Quote: | I have to run off to Minneapolis for a few days, but when I get
how much current
shuts it off.
Good lick. But be cautious about this measurement.
The TIME that the Q114 can stand to run at 10A
(140 watts) is limited by the size of heat-sink it
enjoys. Normal operations will have you releasing
the switch within a second or so of having the amber
light come on so when things are working right, a
large heat-sink is not needed. Experimental measurements
are another matter. Be quick.
| Quote: | Bob, is it possible to "vary" the circuit's current
Yes but . . . this does not appear to be the
root cause of symptoms you're observing.
Dennis Glaeser
Joined: 10 Jan 2006 Posts: 53 Location: Rochester Hills, Michigan
Posted: Tue Jun 21, 2011 5:15 pm Post subject: IvoProp current limiter -revisit |
Bob and Mike,
I have been using Bob’s circuit on my IVO and it works flawlessly. It’s a simple and foolproof way to protect the gear train that drives the blade pitch mechanism.
When I finished the circuit, Bob asked if I had access to an oscilloscope in order to verify it’s operation. One of my EAA chapter members has one and we captured the traces per Bob’s specs. Perhaps Mike could do the same thing and that might provide a clue as to what is (or isn’t) happening.
Bob’s description says that when the current limit is reached, D108 (amber LED) flashed for 120 ms and D109 (green LED) goes dark. In my implementation, the amber LED stays lit as long as I hold the switch (the motor stops) – the green LED does go dark. I don’t know if that is significant, but thought I’d mention it. When the motor is running, the green LED is on, but the amber LED is off (except for the flash at startup).
If there is anything I can do to help, just let me know.
Dennis Glaeser
Mike Welch
Posted: Tue Jun 21, 2011 5:59 pm Post subject: IvoProp current limiter -revisit |
Thank you for the highly informative description of the circuit. I know to keep the
toggle switch testing very brief, however, I did mount the FET on a 1 1/2" X 2" piece
of aluminum for a heat sink. The heat sink, and complete circuit is contained in a
neat plastic box.
After I get back from my mini-vacation, I'll do my best to test the circuit...carefully.
I also verify the correct LEDs are lighting as you described.
Thanks a bunch, I'll get back ya early next week.
Mike Welch
PS. Do they have fish in Minnesota?
Posted: Tue Jun 21, 2011 6:24 pm Post subject: IvoProp current limiter -revisit |
At 09:12 PM 6/21/2011, you wrote:
| Quote: | Bob and Mike,
Bob’s description says that when the current limit is reached, D108 (amber LED) flashed for 120 ms and D109 (green LED) goes dark. In my implementation, the amber LED stays lit as long as I hold the switch (the motor stops) – the green LED does go dark. I don’t know if that is significant, but thought I’d mention it. |
You bet. I'd forgotten how that thing was supposed to work.
Q103/Q115 form a time-delayed latching switch that switches
ON as soon as C112 charges up enough to cause D110 to
go into conduction. Once the latch triggers, Q115 is held
on 'saturated' until power is removed.
| Quote: | | When the motor is running, the green LED is on, but the amber LED is off (except for the flash at startup). |
So the amber LED flashes at start up indicating that
the current limiter did its job while the motor spins
up. When the system hits mechanical stops, the led
will light again when current limit becomes active.
A few milliseconds later, the latch trips and the
motor current goes to zero. Green led goes dark.
Amber LED stays lit.
So my earlier admonition about being quick on the switch
to avoid overheating Q114 is all wet. The time-delayed
shut-down latch protects Q114.
If there is anything I can do to help, just let me know. |
You just did. Thanks!
If there's enough interest in this device, it could
be packaged up nicely in a box like this:
[img]cid:.0[/img]
Since you guys did all the development and proof of concept
work, it would only take a couple hours to package it up
and add it to the product line. We could also make this
a DIY project and sell the ECB, case and connector hardware.
49.66 KB |
11963 Time(s) |
dsleepy47
Posted: Tue Jun 21, 2011 6:45 pm Post subject: IvoProp current limiter -revisit |
I will take 2
Deems
[img][/img]
_________________ dsleepy47
N1491R |
Mike Welch
Posted: Tue Jun 21, 2011 7:21 pm Post subject: IvoProp current limiter -revisit |
Thanks for the responses, guys. I really wish I had more time to try and figure it out
right now, but I'll have to wait until next Monday or so, after I get back.
I went out and did a quick cycle or two of the circuit, and the LEDs appear to turn on and off
as Dennis describes. The pitch motor obviously is twisting the prop blades, but the whole
thing still seems to be working exactly as it should, except it only has a one second range,
from switch on to circuit off, maybe at most, two seconds!
I did see that if I keep switching in the same direction, over and over, I can get the opposite
direction to stay "lit" longer, getting it to twist for 3-4 seconds. I even kept "pressuring it",
and the 10A circuit breaker popped. I reset it, and everything still worked fine...just briefly.
I'll know more after I get back.
Thanks, Mike W
Posted: Tue Jun 21, 2011 8:15 pm Post subject: IvoProp current limiter -revisit |
At 11:17 PM 6/21/2011, you wrote:
| Quote: | Thanks for the responses, guys. I really wish I had more time to
Okay, if your 10A breaker popped, the motor/gearbox
combo is drawing way too much current . . . for reasons
as yet unknown. The limiter may well be doing what
it was designed to do. Try taking it out of the circuit
as described earlier and then measure the current.
At 10:42 PM 6/21/2011, you wrote:
| Quote: | I will take 2
Deems
noted. thanks.
n801bh(at)netzero.com Guest
Posted: Wed Jun 22, 2011 5:41 am Post subject: IvoProp current limiter -revisit |
I can add some insight into why the device might be inconsistant....
I run the Ivo Prop on my V-8 experimental. I switch back and forth from the regular Magnum series tapered blades to the Paddle blades depending on if I am cruising or hitting the back country strips where leading edge protection in needed. Both are cut down to 76" dia. The regular magnum ones twist alot easier then the paddle ones simply because of the mass of the blades. Maybe one person has the tapered blades and the device works great and the other guy had the paddle blades and that makes it trip the circuit ????. I do find the idea you guys are crafting quite novel and useful. With a BIG disclaimer, I admit I am old school and on my experimental I run a non shunted ammeter gauge. Yeah, I know possible radio noise but I crafted my install using as many safeguards as I could and my set up is bone quiet... I like the idea of a quick glance to see if my charging system is working or not. Voltmeters are good but it takes a moment to do the math and the ammeter shows instantly whether I am keeping up with the load or not.. My choice, I know........ The best part of the ammeter gauge is when I change pitch I can look at the gauge and see the neddle deflection. Slight movement shows it is twisting the prop. When I get to the end of the travel, which is pretty easy to guess when that happens, I see the major needle deflection, which is indicative of a locked rotor, then I know I am at my stop. If I don't quickly get off the switch, in about 2 seconds the Ivo provided CB will trip. Also keep in mind during the blade bending event the greatest load is when the prop is at each end of its twisting. The load on the motor is not linear at all throughout the entire range so that needs to be taken into consideretion.. IMHO. .02 cents worth.<G>
Ben.
Ben Haas
N801BH
www.haaspowerair.com
