Fairing Construction - How to?
Goto page 1, 2  Next
Tim Olson
PostPosted: Mon Jun 20, 2011 8:17 pm    Post subject: Fairing Construction - How to? Reply with quote
I've seen references by a couple of builders (not RV-10) who've had
significant temperature improvements by putting a fairing over the
excess slot in the lower cowl, in front of the gear leg. On mine,
I made my slot maybe 3" forward of the leg fairing, so there's a
pretty significant hole there, and, the theory is, the air
coming in will hit the gear leg especially at higher angles of
attack, and flow into that hole, adding pressure to the lower
cowl, decreasing the differential between the upper and lower
cowl. Funny thing is, I had been pondering this before as
something that I thought would happen, but now that I've seen
references to someone getting significant temp improvement by
putting a fairing over that spot, I think I'd like to give it
a whirl.
So, I'd make kind of a curved wedge fairing that attaches
to the cowl to cover that slot and blend to the gear leg,
maybe leaving 1/2" or so gap behind the fairing in front
of the gear leg, to give room for flexing.
What kinds of good ideas can you think of though for how to
get a well shaped fairing? I can picture building a mold
on the cowl with clay and molding over it, and then using
that mold to create the new fairing. But I'm just not
sure what types of techniques would be best for building this
glass part....especially on a painted and flying and completed
RV-10? I'd want the angle to match well with the gear leg,
so taking the cowl off and doing it upside down would
seem to be tough.
Any ideas for me? I'm just not much of an artist with the
fiberglass.
Tim Olson - RV-10 N104CD
Strasnuts
PostPosted: Mon Jun 20, 2011 8:39 pm    Post subject: Fairing Construction - How to? Reply with quote
Tim,
I did this exact mod on mine. Mine was too close though so I opened up to
2.5 inches in front of the gear leg, otherwise when I land hard (ya right)
the front gear will flex far enough to hit it. Scott and I bounced the
plane from the prop and could easily hit the gear fairing before I opened
it. It makes lower cowl removal a breeze even by myself. I will take some
pics of it tomorrow and you can see if this is what you are talking about. I
have seven screws in mine. You can probably use less because that is how
many I used at first when it was a lot closer.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
robin(at)PaintTheWeb.com
PostPosted: Mon Jun 20, 2011 8:46 pm    Post subject: Fairing Construction - How to? Reply with quote
I will leave it to the glass experts to discuss the best techniques.
My question is; I assume you are talking / looking at "A" model RV's
and don't all non A model RV's have a fairings in this location
already? My 6A and 8A do?
I also vaguely recall a -10 builder making a spring loaded cover for
this location.
Re fiberglass tech. Have you seen all the FG work Speedy details on
his site? Maybe you can pick up some tricks from him?
http://www.rv-8a.net/
Including a cool inner nose wheel gear leg fairing.
http://www.rv-8a.net/2010Jun.htm
http://www.rv-8a.net/images/CoolingFairing20.JPG
And some goofy looking wheel pants fairings that got him A LOT of
extra speed. And now a new nose wheel fairing
Robin
Sent from my iPad2.
a whirl.
seem to be tough.
fiberglass.
Tim Olson
PostPosted: Tue Jun 21, 2011 6:07 am    Post subject: Fairing Construction - How to? Reply with quote
Sean,
Very interesting that you had to move it a whole 2.5"....I'm now
curious to see how that looks. It would seem to me that if
there were that much of a gap, it would still let in a lot of
air perhaps, at high angles of attack, but I can't visualize
it well enough. I'm going to have to draw it or do paper
cutouts and see. If you have photos, I'd love to see them.
Maybe it would be better if I attached a horizontal flat plate
to my leg fairing, just INSIDE the cowling...with some
appropriate bracing on top. That could then be allowed to
move fore and aft and as long as I built it with a tight gap to
the lower cowl, and maybe even put a weatherstrip around it,
it would stay sealed up, but from the inside. I would have
to draw it to maybe paint you a picture. It wouldn't
be as clean aerodynamically as a fairing, but it could serve
the goal of keeping air out of the slot, unless the pressure
would be so high that it would break the fiberglass "tongue"
that I'd have sticking off the gear leg.
Robin, I didn't realize that the 6A/8A have any fairing in that
spot. I did try the links you sent. Interesting...that one
funky fairing the guy built looks like it's actually up
INSIDE the cowl. I wonder why/how that works to do anything.
I'll have to peruse the page a bit more.
On 6/20/2011 11:37 PM, Seano wrote:
Tim,
to 2.5 inches in front of the gear leg, otherwise when I land hard (ya
right) the front gear will flex far enough to hit it. Scott and I
bounced the plane from the prop and could easily hit the gear fairing
before I opened it. It makes lower cowl removal a breeze even by myself.
I will take some pics of it tomorrow and you can see if this is what you
are talking about. I have seven screws in mine. You can probably use
less because that is how many I used at first when it was a lot closer.
PostPosted: Tue Jun 21, 2011 6:40 am    Post subject: Fairing Construction - How to? Reply with quote
Yes Stan (Speedy) was trying to smooth out the airflow in the lower cowl area and realized that with all the hardware down there (gear leg, engine brace etc...) that the outlet area of his 8A was much more congested than the underside of an RV-8. Plus Stan is really trying to get some speed out of that bird and is looking for it every place he can. As you know gaining speed is incremental but his best results have come from adding what is essentially HUGE wheel pant intersecting gear leg fairings that removes the sharp angle between the gear leg and wheel pant. I think he gained something like 5 Knots with that modification. Stan is very nice. I am sure you could call him for just about anything construction related.  Sorry about the crappy links I was working off my ipad.
All that being said you were not talking about added speed but increased cooling. How about testing your theory with wide tape before fabricating some fairing?
Robin
On Tue, Jun 21, 2011 at 10:04 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Sean,
[quote] --> RV10-List message posted by: "Seano" <sean(at)braunandco.com (sean(at)braunandco.com)>
Tim,
Tim Olson
PostPosted: Tue Jun 21, 2011 7:03 am    Post subject: Fairing Construction - How to? Reply with quote
I was thinking of doing it with tape. Should be pretty
painless that way. I may even be able to tape in a wedge
of cardboard for a fairing if I wanted. It's worth the
effort I'm sure. I just figured I'd get the supplies,
because I'm sure I'll end up doing something if it works,
and I have a small window where I'm motivated. Smile
It's too fun to fly, and hard to convince yourself
you want to modify something...especially fiberglass.
On 6/21/2011 9:38 AM, Robin Marks wrote:
[quote] Yes Stan (Speedy) was trying to smooth out the airflow in the lower cowl
some fairing?
Robin
Sean,
<mailto:sean(at)braunandco.com>>
Tim,
opened up
hard (ya
fairing
myself.
what you
closer.
rbibb
PostPosted: Tue Jun 21, 2011 10:39 am    Post subject: Fairing Construction - How to? Reply with quote
Tim:
Go to VAnsairforce site and search for posts by Dan Horton (DanH). He is
the man on fiberglass construction. Read his tutorials on making fairings.
He makes it look easy....
Richard Bibb
571-379-3290 mobile
indigoonlatigo(at)msn.com
PostPosted: Tue Jun 21, 2011 1:51 pm    Post subject: Fairing Construction - How to? Reply with quote
Seems like making a actuating aluminum scoop would be a cleaner installation than putting an intake in that area.
If one is hell bend on making a vent, use duct tape as a parting agent between the painted cowl and the fabicated part.
Laminate up some foam, a heavy density blue foam or Spider foam works great. You can adhere the foam to the Duct tape with Bondo.
Shape it with saws, cheese grader, rasps, files or what every suits your fancy.
Hand sand it with 80 grit down to 180. Blow off dust with compressed air. laminate with microballons.
Shape and sand again.
Laminate with several layers of glass and resin, a satin weave would work best on the compound angles. Let cure.
Hollow out the foam with tools or spill fuel on a foam that desolves.
WaLLAAA!
[quote] From: rbibb(at)tomet.net
Subject: RE: Fairing Construction - How to?
Date: Tue, 21 Jun 2011 14:35:43 -0400
Tim:
Lew Gallagher
PostPosted: Tue Jun 21, 2011 2:21 pm    Post subject: Fairing Construction - How to? Reply with quote
Hey John,
Maybe I misunderstood, but I think the idea is to close off that area, not create an intake. Otherwise, good fiberglass fun stuff!
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
PostPosted: Tue Jun 21, 2011 3:03 pm    Post subject: Fairing Construction - How to? Reply with quote
Silly me creating things for the sake of creation and not for reason.
I was thinking that he wanted to create a venturi and was hoping to suck more air in through the front end by having a more direct route for air going out the back end.
Sealing it would be even easier, just make a spring loaded device that retracts when the gear leg pushes on it.
Subject: Re: RV10-List: Fairing Construction - How to?
Date: Tue, 21 Jun 2011 18:18:08 -0400
.ExternalClass .ecxhmmessage P {padding-bottom:0px;padding-left:0px;padding-right:0px;padding-top:0px;} .ExternalClass BODY.ecxhmmessage {font-family:Tahoma;font-size:10pt;} Hey John,
Later, - Lew
nukeflyboy
PostPosted: Wed Jun 22, 2011 1:41 pm    Post subject: Re: Fairing Construction - How to? Reply with quote
Just a minor point: Tim, you say "the theory is, the air
cowl". It doesn't work that way. You have to decrease the pressure at the outlet, increasing the differential pressure. It is differential pressure that drives the flow. Think of it this way - if the pressure was the same top and bottom there would be no driving force, no flow.
So whatever it is that you are constructing, it needs to increase the delta P if you want more cooling flow.
Dave Moore
RV-6 built and sold
RV-10 built and flying
Tim Olson
PostPosted: Wed Jun 22, 2011 1:59 pm    Post subject: Fairing Construction - How to? Reply with quote
That's my point exactly. just think in terms of
having ram air coming in the main cowl holes,
and now you have ram air coming in the lower cowl
through that slot. You could end up with very little
differential pressure. If you seal that forward
facing hole in front of the gear, then you won't
get any INCOMING air into the lower cowl, from
ram air. The only air that will go into the lower
cowl will be the stuff that came in from the
upper chamber, after passing through the
cylinders and oil cooler.
So we're talking about the same thing. leaving
that slot open as-is, is the same as not putting
those rubber seals around your airbox snorkel...you'd
be forcing air into the cowl down there, and that
would wipe out your pressure differential between
the upper and lower cowl...or at least reduce
it.
I'm just trying to maximize that differential by
getting rid of one more place that shouldn't
get forced air rammed into it.
Dave Moore
RV-6 flying
RV-10 QB - Need to start panel
Rest almost done
Breathing too much fiberglass dust
http://forums.matronics.com/viewtopic.php?p=343813#343813
rene(at)felker.com
PostPosted: Wed Jun 22, 2011 2:05 pm    Post subject: Fairing Construction - How to? Reply with quote
Dave I think you miss read what Tim said. The problem is that the hole is
there now, with no fairing, and thus there might be an increase in pressure
in the lower cowl at higher angles of attack. It is my understanding that
he is trying to build a fairing that will redirect the airflow and thus
decrease the pressure in the lower cowl. I tried the same thing by putting
a deflector on the back of the lower cowl. I saw no improvement so I took
it off. I can't wait to see if Tim has any success with putting a fairing
on the opening. During hot summer climbs I need all the cooling I can get.
Rene' Felker
N423CF
801-721-6080
jcumins(at)jcis.net
PostPosted: Wed Jun 22, 2011 4:54 pm    Post subject: Fairing Construction - How to? Reply with quote
Ok I guess I will step in here. I use to own a Cardinal and heat issues and
drag issues on the 1968 cardinal version was very normal. The lower cowl
has a very large opening on the back edge. Thus causing a very large ram
air affect adding to the pressure in the lower cowl. Thus lowering the
differential pressure. Thus poor cooling and
Increased drag. The fix was a large fairing that was attached to the cowl
to close up the hole, a aero dynamic air exit, thus majorly lowering the
lower cowl pressure and increasing the differential pressure. And it added
5-7 knots to the cruise speed.
Looking at how tight the RV-10 cowl is, if I was a betting man. I think
working on enlarging the air exit area, and somehow making sure the slot
where the gear leg resides preventing any air from increasing the lower cowl
pressure from ram air. Reshaping the lower firewall with a fairing, to cut
the friction of the air exiting the cowl and helping the air make the 90
degree to go out the bottom cowl exit.
I am not sure about how affective the slots I have seen people installed in
the lower center portion are either . Maybe more slots are needed. Only
problem is the slots also I suspect are not that affective due to the high
speed air rushing over them building a boundary layer, and causing a
restriction to the air trying to exit out the slot them self's.
One more Cardinal trick that really worked well to assist in cylinder
cooling was to increase the distance between the aft cylinder fins and the
aft baffling. We would insert small strips of 1/8 to 3/16 pieces of
Baffling material between the cylinders and the aft baffling material
opening that distance just a bit and it really made a very large difference
in cylinder temps
Just a few thoughts.
Anyone want to chime in on this.
I am going to have this same discussion with engineer friend and see what
his thoughts are about the best way to increase the differential pressure.
Between the top and bottom of the cowl.
John Cumins
40864 Dimpling wing skins SB Wings.
nukeflyboy
PostPosted: Wed Jun 22, 2011 6:12 pm    Post subject: Re: Fairing Construction - How to? Reply with quote
You are right - I misread what Tim is trying to do. I suspect that the gear can flex quite a bit so you need to account for it. Have you thought of using some kind of rubber or soft material? It would have to be stiff enough to withstand the air pressure without deflecting but would allow the gear leg impact without damaging anything. Something like those thick silicone gaskets with a slit in it for gear movement. It could stay in place even when removing the lower cowl and could be glued on the inside of the cowl.
Dave Moore
RV-6 built and sold
AV8ORJWC
PostPosted: Wed Jun 22, 2011 6:44 pm    Post subject: Fairing Construction - How to? Reply with quote
Chiming in just for the thrill of mixing it up. The lower cowl is an
area of High Pressure in the region of laminar flow. The Upper deck has
lower pressure flowing over it to the windshield where everything can
break loose. Given Tim's desire to reduce problems inherent with the
STOCK Vans nose gear leg. Louvers in the lower cowl do not assist the
Delta T/Delta P equation. High Pressure in the top deck. Lower
pressure and need for enhanced outflow in the lower deck. The firewall,
assorted added obstructions and the gear leg work against the efficient
flow of High pressure air over the cooling fins and an effective
extraction of heat and energy laden airflow. Correct sizing of the High
pressure deck, along with well designed flow characteristics of the High
Pressure deck lend themselves to caressing the airflow out of the
stagnant lower deck and efficiently into the slipstream of the lower
cowl.
LoPresti makes a living selling the concept of changing the amount of
airflow out of the lower deck (Cowl Flaps) and into the slipstream.
There is a whole body of data from Deems, Robin and others on the use of
James plenums and dealing with airflow and oil temp control. Is there
someone who can quantifiably support more louvers in the high pressure
area aid additional extraction of air coming from the High Pressure
Deck?
Showplanes is said to be working on an improved cowl. Maybe OSH '11 is
the year to keep a watchful eye open.
The Cardinal baffling idea was used by both Cirrus and GAMI to assist
Continental engines in those aft cylinders. It increase high pressure
flow into the lower pressure chamber. That chamber has high pressure
laminar flow waiting for more louvers to mix up the dynamic flow. Maybe
Kelly can chime in from Arizona. I am an advocate of a high pressure
chamber designed specifically for enhanced flow which has individual
cylinder fins mounted to direct the need flow over the exhaust valve and
cooling fins of each cylinder. Those who have used manometers might
understand my desire. More louvers, too simple to understand but
popular no less.
John - OSH '11
PostPosted: Wed Jun 22, 2011 7:33 pm    Post subject: Fairing Construction - How to? Reply with quote
As a -10 (and 8A) James cowl & plenum owner (read: disgruntled) I can tell
you that the single best modification we made for reducing high CHT's and
Oil Temps was the addition of 4 louvers on the underside of the cowl. Not
ideal but by that point we were willing to try anything. The temps are all
manageable now just passing 225 hours TTSN.
I can say with little hesitation that the stock Vans cowl with standard
baffling is currently the proven best option for proper cooling, running
LOP etc... I have been in relatively close contact with the nice folks at
Showplanes. They are getting closer but not at production stage yet. Am I
going to be a guinea pig twice? Hard to know but my long range plans are
to replace the James cowl at some point. (yes John I remember you want it
for testing...)
Unless you are one that enjoys severe migraines and tinkering vs. flying,
consider using stock cowl till there is a proven alternative.
Robin
Albert Gardner
PostPosted: Thu Jun 23, 2011 6:52 am    Post subject: Fairing Construction - How to? Reply with quote
I have had to lengthen the slot on the lower cowl for the gear leg to allow
the lower cowl to be removed. I have an Aerocomposits 3 blade prop and the
lower cowl has to drop straight down in order to clear the spinner when
removing it. Even with the longer slot forward of the gear leg I still pull
down the tail to allow the front gear to drop down as far as possible.
Albert Gardner
N991RV
Yuma, AZ
 Filesize:  21.49 KB
 Viewed:  17488 Time(s)
RV-9A N872RV
RV-10 N991RV
Albert Gardner
I suffered from hi oil temps and adding a second oil cooler among other
things solved most of the problem, but the final solution was to add an
opening on each side under the oil coolers on the bottom cowl to allow more
exit air. Temp in Yuma yesterday was 113, temp in hell was 112, so yes, Yuma
is hotter than hell.
Albert Gardner
N991RV
Yuma, AZ
 Filesize:  20.98 KB
RV-9A N872RV
RV-10 N991RV
Tim Olson
PostPosted: Thu Jun 23, 2011 7:16 am    Post subject: Fairing Construction - How to? Reply with quote
That slot is pretty close to your gear leg.
Sean said he moved his 2.5" forward of the leg or
so, because the leg flexed forward under load,
and he wanted it to not hit that filler plate.
Do you find any evidence of hitting it?
If you don't, then that's exactly what I'm hoping
for....minimal gap between the leg and the cowl.
And, if you really wanted it tighter, with
a gap that tight, you could put a rubber
flap seal around it too if you wanted.
Just want to know if you've ever seen it hit.
Albert Gardner
N991RV
Yuma, AZ
Goto page 1, 2  Next
Page 1 of 2
