STRATUS/Soob EA-81 Cooling?
andynfultz(at)bellsouth.n
PostPosted: Mon Jun 20, 2011 7:52 pm    Post subject: STRATUS/Soob EA-81 Cooling? Reply with quote
This one is for those of you running a STRATUS or other Subaru EA-81 on your AVID or KF. What are
your water temps running on take off climb, cruise climb and at cruise? At
what RPM are you running with the temp numbers you are seeing? I'm just a
little concerned with the temps I'm seeing. 180 before take off and then on
climb out I'm seeing the temp go over 200 pretty quick. If I keep it in a
climb 5000 RPM it'll continue to rise to 215 till I pull the power back to
about 4000 and level off and then it will only come back down to around 200
after a while. If I increase the RPM I'll see the temp start to rise again
even if I stay level. OK I'm listening.
Andy F.
7.1 hours since I got my airworthiness last tuesday
Fox5flyer
PostPosted: Tue Jun 21, 2011 4:19 am    Post subject: STRATUS/Soob EA-81 Cooling? Reply with quote
Hi, Andy. Obviously, unless you use a thermostat, the engine temps are directly affected by outside ambient temps. Higher oat means higher engine temps. With mine, at about 70 oat, I warm up to 150f for takeoff and generally by 2k agl engine temps increase to about 195 where they stay when I level off for cruise. I have my radiator enclosed with adjustable rear cowl flap so that I have some control over engine temps. On hot days I keep an eye on the climb temps as they can creep up to 215 or even higher. When that happens I just level off for a little while, then climb some more. I rarely get more than 4k agl anyway, so it isn't a problem here in Michigan. The temps you indicate do not seem extremely high to me. Adding throttle increases power and power produces heat so it's normal for the temps to rise somewhat. Of course, no two experimental aircraft setups are the same so, if it is a big concern, you might take a look at yours to see what you can do to scavenge more heat out of the cowling/radiator.
Deke
S5/NSI Subaru/CAP
470TT
lcfitt(at)sbcglobal.net
PostPosted: Tue Jun 21, 2011 6:38 am    Post subject: STRATUS/Soob EA-81 Cooling? Reply with quote
Andy,
First my disclaimer - I know nothing specifically about the Subaru installation - but I would like to offer some ideas from other applications. I have helped build two airplanes and am in my second Kitfox IV build. I understand that the later model Kitfoxes with internal radiators have suffered at times from inadequate cooling. I am currently helping with a Series V with a 7 FWF set-up. It has an internal radiator and I have been told that the reason for the larger - by at least a factor of 2 - radiator was to help with cooling, as with earlier models that was an issue. As I looked over the installation, it became pretty obvious that the cowl inlet area providing cooling air to the radiator is considerable larger than the outlet area. Switch to the Lancair IV I helped with. Given that it is an air cooled engine, and arguably quite different, what follows might not totally apply, but when builders of this airplane found cooling problems, the solution was to decrease - yes decrease - the inlet area. This provided a lower pressure within the cowl and more smooth, slower flowing air over the fins which picked up more heat.
With the 7 FWF on the V build, the total outlet area under the cowl is about 110 in. Sq. The inlet to the radiator is a NACA duct that expands to the area of the radiator which is about 103 in. sq. Add to that 15 and 17 in. sq. for the oil cooler and the openings on each side of the spinner and the inlet area to the entire cowl is 135 in. sq. The general rule of thumb for air cooled is a 1.5 to 1 ratio outlet to inlet. The Kitfox has it not quite exactly reversed. I think what is happening in the Kitfox is the inadequate outlet is simply acting like a dam and the cooling air is simply bypassing the cowl openings seeing essentially a partially blocked hole. The Speedster radiator shroud I had on my first Model IV had the inlet to outlet ratio pretty much like what the Lancair folks found to work best.
All this is opinion, but it may give some suggestions on where to look regarding possible solutions.
Lowell
Sent: Tuesday, June 21, 2011 5:16 AM
To: Kitfox List (kitfox-list(at)matronics.com)
Subject: Re: STRATUS/Soob EA-81 Cooling?
Deke
S5/NSI Subaru/CAP
470TT
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
kirkhull(at)kc.rr.com
PostPosted: Tue Jun 21, 2011 1:24 pm    Post subject: STRATUS/Soob EA-81 Cooling? Reply with quote
My stratus stays at 190 but it also has a thermostat I do have to watch the oil temps though
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Andy Fultz
Sent: Monday, June 20, 2011 10:48 PM
Subject: STRATUS/Soob EA-81 Cooling?
Andy F.
Fox5flyer
PostPosted: Wed Jun 22, 2011 2:49 am    Post subject: Re: STRATUS/Soob EA-81 Cooling? Reply with quote
Agree with Lowell completely. Good advice. I used the same ratio for my scoop/fairing and it has worked fine for my purposes. Another thing, if I can add to Lowell's post, ensure that no air (zero) can escape around the radiator. What I mean is that if you enclose it (best, IMO), do not leave any gaps anywhere for air to bypass it, because that is exactly what the air will do. It is like water and will take the easiest path. It is extremely important to have high pressure at the inlet and low pressure at the outlet, otherwise the air will just bypass the whole thing and very little cooling will result. The best way to achieve this is a simple "lip" on the outlet side which will create a suction. This combined with the high pressure in front will drag lots of air through the rad. Better yet is to make that lip controllable.
I'm attaching some photos to illustrate what I'm talking about.
Good luck,
Deke
S5/Soob
[quote="lcfitt(at)sbcglobal.net"]Andy,
Lowell
Deke
S5/NSI Subaru/CAP
470TT
 Filesize:  217.06 KB
 Viewed:  4303 Time(s)
 Filesize:  232.5 KB
 Filesize:  251.58 KB
