Breaking nose pants
Lew Gallagher
PostPosted: Sun Jun 12, 2011 3:49 pm    Post subject: Breaking nose pants Reply with quote
Hey guys,
This will be the FOURTH (original and three replacements) nose wheel pants I've made. Apparently on hard landings, low tire pressure, whatever, the tire grabs the sides of the opening, curls them in and breaks off the tail of the pants.
I can see tire burn on the broken edges, so it must be that when the tire flattens, then rotates before it can reshape, it grabs the fiberglass. Note that the glass is not laid for structure (on a bias) and it's a clean break along the weave.
I've opened the width much more than Van's calls for this last time in hopes to eliminate the problem. I got tired of ordering a new blank, so this time I put the damaged one back together. Three layers of cloth on a bias along the inner seam, one on the outer, smoothed with resin/micro beads, primed and feathered in. I won't redo the paint job until we find out if it's a fix.
Anyone else find this to be a problem? I don't recall anyone posting this before. Let me know - Lew
 Filesize:  23.56 KB
 Viewed:  7602 Time(s)
 Filesize:  35.86 KB
 Filesize:  38.95 KB
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
Tim Olson
PostPosted: Sun Jun 12, 2011 4:05 pm    Post subject: Breaking nose pants Reply with quote
If you're not opened up at least 3/4", you'll find this can
happen. I haven't had it happen myself, but talked to
a few who had. Mine I can easily get my thumb in all the way
around...more in the back...maybe 1" or more behind the tire.
Tim Olson - RV-10 N104CD
On 6/12/2011 6:49 PM, Lew Gallagher wrote:
Gallagher"<lewgall(at)charter.net>
Hey guys,
-------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=342821#342821
http://forums.matronics.com//files/patch2_medium_109.jpg
http://forums.matronics.com//files/patch1_medium_104.jpg
http://forums.matronics.com//files/brkncone_medium_116.jpg
amekler
PostPosted: Sun Jun 12, 2011 4:21 pm    Post subject: Breaking nose pants Reply with quote
I just repaired mine (at) 130 hours. Only thing I found was a low tire
pressure- down to 20 lbs.I didn't think that was the cause(ie no hard
landings) I didn't see any rubber. I thought it was maybe due to FOD.
Alan
dlm34077(at)q.com
PostPosted: Sun Jun 12, 2011 5:00 pm    Post subject: Breaking nose pants Reply with quote
How much clearance between stationary tire and pant? Should be at least 1"
all the way around.
thane
PostPosted: Mon Jun 13, 2011 4:44 am    Post subject: Breaking nose pants Reply with quote
Yep, mine did that also. The 1st. time was from a firm landing with a
heavy airplane and aft c.g. It tore up the back bottom area of both main
wheel pants. A veteran RV builder had told me that my pants would
eventually be damaged if set up as per Vans instructions. So I redid them
and flattened off the bottom area in front of and to the rear of the tires,
giving them more ground clearance. Then I happily went off on an adventure,
and tore them up again because I had not provided enough clearance around
the tire area, so I fixed them again. I now have no issues, and thankfully,
I have not painted yet.
Thane
Working on finish kit: I hate fiberglass!!
Lew Gallagher
PostPosted: Mon Jun 13, 2011 3:34 pm    Post subject: Re: Breaking nose pants Reply with quote
Thanks for the validation, guys. Good to know it's not just Wes's -- bad to know that the plans call for 5/8" clearance and it wasn't on anyone's "gotcha" list.
I agree that it should be "at least 1" -- those still building, take note!
Later, - Lew
non-pilot
Fly off completed !
speckter(at)comcast.net
PostPosted: Mon Jun 13, 2011 3:46 pm    Post subject: Breaking nose pants Reply with quote
I have found over the years on several homebuilts, that keeping the tire
pressure up, say 50 or 60 pounds helps keep the tire from deforming and
scraping the pant.
Gary Specketer
