Help! 3300 rough running puzzle.
Goto page Previous  1, 2, 3  Next
jd(at)lawsonimaging.ca
PostPosted: Wed Jun 08, 2011 1:52 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
On 06/08/2011 05:03 PM, j. davis wrote:
If I push fairly hard on the bottom (push rod side) of each tappet I can compress the
lifter slightly, then it returns.
Actually, I just revisited my tappets. I put each cylinder at TDC and used my thumb to
push on each tappet. 10
of the 12 depressed just slightly, maybe 1/8". The two tappets immediately adjacent to my
'problem' cylinder (3), (number 1 intake,
number 5 exhaust) each fairly easily depressed about 1/4", maybe even 3/8". Does this mean
something bad? Seems coincidental that bthey are the adjacent tappets, although I can't
see how that would affect a different, adjacent, cylinder, but what do I know :")
Thanks again for all the advice, people!
Regards, J.
- Sonex #325 C-FJNJ, Jab 3300a, Prince P-Tip, Aerocarb
- former C-IGGY CH701 owner/builder, CH750 in progress
- see both (and more!) at http://cleco.ca
| J. Davis, M.Sc. (comp sci) |
| email: jd at lawsonimaging.ca |
| *NIX consulting, SysAdmin |
| http://cleco.ca |
Sometimes I... No, I don't.
--- Steven Wright
aerobiz1(at)gmail.com
PostPosted: Wed Jun 08, 2011 2:07 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
J.  If you are getting a leaky valve or possibly valve bounce, it will indeed effect other cylinders by disturbing the pressure waves of the incoming charges.  Remember, it is the negative and positive pressure waves that do the work, not as you would imagine a steady flow of fuel and air coming in and out of the cylinders.  I recently had a sticking exhaust valve that directly caused this particular 3300 to run on 3 cylinders, not just the one affected !
Worth a try - change out those valve springs....
Martin
On Thu, Jun 9, 2011 at 7:48 AM, j. davis <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)> wrote:
[quote]--> JabiruEngine-List message posted by: "j. davis" <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)>
If I push fairly hard on the bottom (push rod side) of each tappet I can compress the lifter slightly, then it returns.
Actually, I just revisited my tappets. I put each cylinder at TDC and used my thumb to push on each tappet. 10
of the 12 depressed just slightly, maybe 1/8". The two tappets immediately adjacent to my 'problem' cylinder (3), (number 1 intake,
number 5 exhaust) each fairly easily depressed about 1/4", maybe even 3/8". Does this mean something bad? Seems coincidental that bthey are the adjacent tappets, although I can't see how that would affect a different, adjacent, cylinder, but what do I know :")
Regards,  J.
| http://cleco.ca               |
                               --- Steven Wright
ine-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
PostPosted: Wed Jun 08, 2011 3:02 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
Martin
Thanks, Martin, but I have a hard time swallowing that at just 100 hours, and running fine
last fall, that I would
need to change out valve springs that are not broken. That would be a sad statement
regarding the Jabiru engine indeed.
Just doesn't make sense. I need some hard evidence
before I commit to start pulling heads off. Don't forget, it's currently running fine,
just the #3 plugs are sooty.
And leak-downs are fine, so no sticking valve as was your case. You may be right, but at
this point I'm not
convinced... I'm leaning toward the hydraulic lifters right now, hoping some more Jab
experts will chime in
(Pete, Roger, where are you when I need you ;')
do I know :")
Regards, J.
| email: jd at lawsonimaging.ca <http://lawsonimaging.ca> |
| http://cleco.ca |
--- Steven Wright
MS -
e -
Regards, J.
| http://cleco.ca |
I was walking down the street and saw a sign on a post. It
said: "Lost -- $50. If found, just keep it."
--- Steven Wright
PostPosted: Wed Jun 08, 2011 3:40 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
J - as it is running fine, I would tend to leave well enough along also.  But the fact that your adjacent valve springs are noticeably weaker must mean something.
The fact that it has only done 100 hrs is of little consequence in Jab world.  We had to rebuild 2 heads at 100 hrs, again at 200 hrs and replace all rocker bushes and pins at 250 hrs. So we are now using the LCH ones from Rotec.....
Martin
On Thu, Jun 9, 2011 at 8:59 AM, j. davis <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)> wrote:
[quote] --> JabiruEngine-List message posted by: "j. davis" <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)>
Martin
Thanks, Martin, but I have a hard time swallowing that at just 100 hours, and running fine last fall, that I would
need to change out valve springs that are not broken. That would be a sad statement regarding the Jabiru engine indeed.
before I commit to start pulling heads off. Don't forget, it's currently running fine, just the #3 plugs are sooty.
And leak-downs are fine, so no sticking valve as was your case. You may be right, but at this point I'm not
convinced... I'm leaning toward the hydraulic lifters right now, hoping some more Jab experts will chime in
On Thu, Jun 9, 2011 at 7:48 AM, j. davis <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca) <mailto:jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)>> wrote:
   do I know :")
   --     Regards,  J.
   | J. Davis, M.Sc. (comp sci)    |
   | email: jd at lawsonimaging.ca <http://lawsonimaging.ca> |
   | *NIX consulting, SysAdmin     |
   | http://cleco.ca               |
                                  --- Steven Wright
   MS -
   e -
Regards,  J.
| http://cleco.ca               |
                               --- Steven Wright
MS -
e -
jwd3ca(at)gmail.com
PostPosted: Wed Jun 08, 2011 5:02 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
It's not the springs that are weaker, it's the lifters that compress easier. Yeah, its running smoothly now, but if those two plugs actually foul, that'll be bad...
also.
must
mean something.
replace
from
Rotec.....
Martin
will
the
pressure waves
air
exhaust valve
just
>> the one affected !
>> Martin
hours,
sad
currently
may be
hoping
<mailto:
tappet
>> I can
and
>> used my thumb
even
>> 3/8". Does
adjacent
>> tappets,
>> cylinder, but what
>> do I know :")
>> -- Regards, J.
>> | http://cleco.ca |
>> --- Steven Wright
>> MS -
>> e -
> Regards, J.
> | http://cleco.ca |
> --- Steven Wright
Sent from my Android tablet using K-9 Mail. Please excuse any typos! J.
PostPosted: Wed Jun 08, 2011 6:40 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
I've attached a picture of the plugs just to illustrate what I'm seeing. Don't be alarmed
that the others
look too lean, I was aggressively leaned at shut-down.
Thanks!
Regards, J.
| http://cleco.ca |
One time a cop pulled me over for running a stop sign. He
said, "Didn't you see the stop sign?" I said, "Yeah,
but I don't believe everything I read."
--- Steven Wright
 Filesize:  247.95 KB
 Viewed:  14258 Time(s)
zeprep251(at)aol.com
PostPosted: Wed Jun 08, 2011 7:06 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
J
Is it possible that you had a valve sticking? Maybe try an upper cylinder additive in your fuel,like Marvel .Very unlikely that a hydraulic lifter would cause a problem.Sticking valves are quite common in Continental engines.Good article in EAA Sport AV magazine this month.
G.
PostPosted: Wed Jun 08, 2011 7:21 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
They don't look lean to me.  Obviously you have never raced a 2-stroke....  Wink
Besides, you 'read' a plug by looking down the bottom of the insulator, not the firing end....
Still a mystery
Cheers
Martin
On Thu, Jun 9, 2011 at 12:36 PM, j. davis <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)> wrote:
[quote]I've attached a picture of the plugs just to illustrate what I'm seeing. Don't be alarmed that the others
Thanks!
Regards,  J.
| http://cleco.ca               |
                               --- Steven Wright
Lynn Matteson
PostPosted: Thu Jun 09, 2011 2:31 am    Post subject: Help! 3300 rough running puzzle. Reply with quote
Compared to yours, I'd need to wear sunglasses to read my plugs. : )
Lynn Matteson
Jabiru 2200, #2062
Prince prop (64 x 30, P-tip)
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with "Ramcharger" intake manifold...1111 hrs (since
3-27-2006)
Thanks!
Regards, J.
Lynn
Kitfox IV-Jabiru 2200
N369LM
Lynn Matteson
PostPosted: Thu Jun 09, 2011 2:41 am    Post subject: Help! 3300 rough running puzzle. Reply with quote
Rocker arm bushings at 237 hours, along with "cross-swapping" the
rocker shafts to introduce the previously unused bearing
surface....nope, time doesn't mean Jack S - - t to a Jabiru. But get
it right and it's a nice engine...that is, IF you have solid lifters.
Sorry, but that's my opinion. Jabiru tried to fix something that
wasn't broken, and should have put their engineering expertise into
some other areas of the engine instead of listening to advice from
crybabies who didn't like adjusting valves.
Lynn Matteson
Jabiru 2200, #2062
3-27-2006)
Martin
Martin
Lynn
N369LM
Thom Riddle
PostPosted: Thu Jun 09, 2011 2:57 am    Post subject: Re: Help! 3300 rough running puzzle. Reply with quote
Any chance you have an air flow blockage in the #3 cylinder intake tube?
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Thu Jun 09, 2011 4:50 am    Post subject: Help! 3300 rough running puzzle. Reply with quote
Hi Thom...
hmmm, not sure how that would happen, but wouldn't that *lean* the mixture to #3?
Regards, J.
| http://cleco.ca |
If the pen is mightier than the sword, in a duel I'll let
you have the pen!
--- Steven Wright
matronics(at)rtist.nl
PostPosted: Thu Jun 09, 2011 5:31 am    Post subject: Help! 3300 rough running puzzle. Reply with quote
> Riddle"<riddletr(at)gmail.com>
Hi Thom...
mixture to #3?
The mixture would lean if there's a leak in the intake runner which
would add air to the mixture. If it is blocked, the cylinder would get
the right mixture, but perhaps insufficient to ignite?
PostPosted: Thu Jun 09, 2011 6:38 am    Post subject: Help! 3300 rough running puzzle. Reply with quote
> Hi Thom...
The mixture would lean if there's a leak in the intake runner which would add air to the
mixture. If it is blocked, the cylinder would get the right mixture, but perhaps
So the suggestion is to remove the intake tube to check for blockage? I'm trying to
imagine a scenario that would result
in a blocked intake tube... what could the blockage consist of? What might I find inside
there?
Regards, J.
| http://cleco.ca |
A friend of mine is into Voodoo Acupuncture. You don't
have to go. You'll just be walking down the street,
and...........ooooohhhhhh, that's much better...
--- Steven Wright
dons701
PostPosted: Thu Jun 09, 2011 8:09 am    Post subject: Re: Help! 3300 rough running puzzle. Reply with quote
Hi J.
I thought your response, quoted below, to an earlier question was interesting. How did you set the gaps on both coils ? I found more accuracy in setting the gaps on both coils by using two pieces (approx 1"x3") of brass shim stock .010", the minimum setting. First clean the rust or other corrosion off coils and magnets. Once the brass shims are in place, coil mounting bolts can be loosened to allow coils to have full contact with the curved magnets, a shim sandwich so to speak. This assures the curvature of the coils and magnets are uniform to each other along with keeping the proper gap. Lock the coil mounting bolts. You will find it hard to pull your shims out. Rotate the engine to satisfy yourself that there is no interference. Store the shims in the tool box.
Lastly, IF you removed the coils, did you make sure the coil insulating washers were in place? I would hate to think that the coils just got hot to a point of weakness such that the first cylinder to miss fire was number 3. Sometimes a weak ignition will show up on one cylinder (hardest to fire) first before the others. I have read in other posts where gaps were cleaned and reset to solve ignition issues when the owner thought they were ok. Some of your other plugs seem a bit dirty, like weak ignition to me. Sorry for the dissertation on gap setting but if it helps you or anyone, great....Don B
""Yeah, forgot to state it explicitely, but of course I set the air gaps when I re-installed
the spider.Also
magic markered the magnets to witness any potential future contact""
Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop
PostPosted: Thu Jun 09, 2011 9:05 am    Post subject: Help! 3300 rough running puzzle. Reply with quote
On 06/09/2011 12:09 PM, dons701 wrote:
Hi J.
Exactly how I do it, except I use business card strips (after verifying that they are
indeed .010). One day I'll pick up some brass shim stock,
but the card stock works well...
Didn't remove the coils, but did do a resistance check on their primaries and secondaries,
and they were all in range.
Good point...
Plugs are new (and gapped) with about an hour on them so far...
Which part of my response did you find interesting, exactly?
Thanks, Don.
the spider.Also magic markered the magnets to witness any potential future contact""
Regards, J.
| http://cleco.ca |
All of the people in my building are insane. The guy above
me designs synthetic hairballs for ceramic cats. The lady
across the hall tried to rob a department store... With
a pricing gun... She said, "Give me all of the money in
the vault, or I'm marking down everything in the store."
--- Steven Wright
dons701
PostPosted: Thu Jun 09, 2011 10:30 am    Post subject: Re: Help! 3300 rough running puzzle. Reply with quote
Hi J
To respond in order, when you checked the coil resistances were the coils hot? Resistance goes up with temp. increase....Plug color or how dirty they are, new or otherwise is a function of mixture and the completeness of combustion supplied by the ignition. You could buy a pair of NGK Iridium Plugs which require less juice to fire and install them in the #3 cyl for experimentation. They worked for me at .025" gap no antisieze on threads per NGK.
.""Also magic markered the magnets to witness any potential future contact""
What i thought was interesting...
Just wondering if you had seen evidence of contact before as quoted above. Thought the plugs looked dirty indicating a possible over all ignition problem thats all. Everyone knows that your problem could become their problem in the future, hope the solution can be found and reported here, keep trying.....Don B
Zenith 701 #76120
PostPosted: Thu Jun 09, 2011 2:54 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
On 06/09/2011 02:30 PM, dons701 wrote:
Hi J
Cold. The Jab maintenance manual doesn't specify a temperature at which to test, so I'm
assuming they mean cold.
Check.
Just wondering if you had seen evidence of contact before as quoted above and thought the plugs were dirty indicating a possible over all ignition problem thats all. Everyone knows that your problem could become their problem in the future, hope the solution can be found and reported here, keep trying.....Don B
No, not personally, but I've read of coils destroyed by contact, don't know how/why that
happened, but I like to just be able to give a quick
glance to ensure that my black magic marker is intact and unscathed ;') Just for the
comfort factor...
As an aside, I discovered that my 'soft' lifters just needed filling. Spun the engine with
no plugs, watched oil pressure climb. After that, they were just like the others. One more
possibility ticked off as not the cause. There must be a definitive and scientific reason
for these two sooty plugs,
still hunting ;'(
Regards, J.
http://cleco.ca
My aunt gave me a walkie-talkie for my birthday. She says
if I'm good, she'll give me the other one next year.
--- Steven Wright
PostPosted: Thu Jun 09, 2011 3:18 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
J - given that your two plugs are sooty rather than wet, I would hazard a guess that the mixture is too rich rather than the plugs not firing.  Have you tried twisting the carb a few degrees off centre ?
Martin
On Fri, Jun 10, 2011 at 8:49 AM, j. davis <jd(at)lawsonimaging.ca (jd(at)lawsonimaging.ca)> wrote:
-->  JabiruEngine-List message posted by: "dons701"<burdon1(at)comcast.net (burdon1(at)comcast.net)>
Hi J
Cold. The Jab maintenance manual doesn't specify a temperature at which to test, so I'm assuming they mean cold.
Check.
No, not personally, but I've read of coils destroyed by contact, don't know how/why that happened, but I like to just be able to give a quick
glance to ensure that my black magic marker is intact and unscathed ;') Just for the comfort factor...
As an aside, I discovered that my 'soft' lifters just needed filling. Spun the engine with no plugs, watched oil pressure climb. After that, they were just like the others. One more possibility ticked off as not the cause. There must be a definitive and scientific reason for these two sooty plugs,
still hunting ;'(
Regards,  J.
http://cleco.ca
                               --- Steven Wright
MS -
e -
vvkidd(at)mindspring.com
PostPosted: Thu Jun 09, 2011 4:38 pm    Post subject: Help! 3300 rough running puzzle. Reply with quote
Not sure that this could be your problem but I had a similar problem with a C172.
Found that the hose coupling between the two halves of the intake manifold had slipped and was admitting air into the manifold thus changing the mixture.
Victor Kidd
Page 2 of 3
