gregoryf.flyboy(at)comcas Guest
Posted: Tue Jun 07, 2011 3:59 am Post subject: Flap cross tube |
Kelv,
Thanks for the info! It sure does help.
My Port measurement from the closeout web to the inboard face of the FLAP
pin mounting plates is 75.125 (75 1/
STDB measurement is 74.875 (74 7/
Well, that makes a half an inch difference from your measurement, anyway. I
am stumped. If I assume 1/2 inch short for flap and maybe 1/4 inch for drive
tube, it still doesn't cover 1.75 to 2 inches, which is what it appears I
need to span the distance.
Thanks, that is the only reference for the flaps I have to compare to.
Greg
Greg
My flap cross tube on kit 497 is 44.6 inches as supplied by Europa
(untrimmed and without bearings).
My flap dimensions are shown below, measured from the closeout web between
the flap and aileron and the inboard face of the wing pin mounting plates.
Port 1908 mm or 75.2 inches
Stbd 1912 mm or 75.3 inches
Hope this helps.
Kelv Weston
Kit 497
kelv(at)kdweston.biz
Richard Wheelwright
Joined: 15 Sep 2008 Posts: 111 Location: Halifax, West Yorkshire, UK
Posted: Tue Jun 07, 2011 5:27 am Post subject: Flap cross tube |
It may be a silly Question, But have you rigged the wings with the flaps in place? I ask, because the flap drive pin slides into the flap cross tube as the flaps are retracted. If you are measuring with the flaps extended it would appear to be short.
I hope this helps. Sorry if you are ready know this
Richard Wheelwright
Sent: Tuesday, 7 June 2011, 12:55
Subject: RE: Re: Flap cross tube
--> Europa-List message posted by: "Greg Fuchs " <gregoryf.flyboy(at)comcast.net (gregoryf.flyboy(at)comcast.net)>
Kelv,
Greg
--> Europa-List message posted by: "Kelvin Weston" <kelv(at)kdweston.biz (kelv(at)kdweston.biz)>
Greg
Hope this helps.
Kelv Weston
Kit 497
href="http://www.matronics.com/Navigator?Europa-List" target=_blank>htp; -Matt
_________________ Richard Wheelwright
G-IRPW
First Flight 24th July 2013 |
Posted: Tue Jun 07, 2011 10:37 am Post subject: Flap cross tube |
Hi Richard!
Yes, with the flaps up. The wings are pinned with the main spar pins, but the lift pins are not in place. Could that be it? .Rocking the wings fore and aft, there does not seem to be much movement. There is no hole in the fuselage to accept the cross tube yet. I am looking ahead to try an see how things are going to fit in the future, and measurements have an eyeball factor, since things are not in line, and may be suffering some parallax. Currently trying to figure out some way to provide a slot in the quick-connect area for the wing spars to slide in, to make it easier to rig/derig (I don't think there is extra Tufnol in the kit for this, maybe HDPE will work..). ..Final say may well be after the wing is set in its permanent position with lift pins and cross tube installed through the fuselage.. I might use some plumb bobs (hanging from flap pin surface) for a better esitmate, later on today.
Thanks for your input,
Greg
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Richard Wheelwright
Subject: Re: Re: Flap cross tube
Richard Wheelwright
Kelvin Weston
Joined: 14 Apr 2010 Posts: 90 Location: Hampshire, UK
Posted: Tue Jun 07, 2011 11:37 am Post subject: Re: Flap cross tube |
Greg
I take it you have the flaps hinged to the wing.
If your flaps were too short, you would have had problems aligning the flap hinge arms with the wing hinge plates.
As the tip or outer flap arm FL3 mounts in the centre of the outboard flap hinge plates W21, any discrepancy in the length of the flap is visible at the flap root. The flap arm FL1 will be slightly out of line with the wing root hinge plate W18.
I know some are slightly out, I have looked at many Europas during my build and have seen the inboard flap hinge arm W19 bolted to both sides of the inboard wing plate W18. I have also seen some W19 arms with a double bend to achieve alignment.
If yours were reasonably lined up at the root hinge then the flaps are likely to be ok in length.
_________________ Regards
Kelv Weston
Kit 497
kelv@kdweston.co.uk |
Posted: Tue Jun 07, 2011 11:48 am Post subject: Flap cross tube |
I used some heavy nylon blocks cut into an L shape to guide the spar as it slides in, fixed into each spar hole.
As for the flap tube, like you I had doubts the tube was long enough, it ended it being too long. Rig your wings
Then go ahead and cut the slots for the hinge mounts in the underside of the fuse so you can get the four holes lined up.
I used a heavy cord for the alignment that was a neat fit in the bolt holes and basically pulled it tight with tension provided by a 5kg weight
This way you don’t have to “eyeball” the centre of the holes for correct alignment and even if you move something a little by accident the tension
On the cord is enough to keep the alignment correct on the two inner hinges as the outer two are already fixed in place
craig
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Greg Fuchs
Sent: Wednesday, June 08, 2011 4:33 AM
Hi Richard!
Yes, with the flaps up. The wings are pinned with the main spar pins, but the lift pins are not in place. Could that be it? ..Rocking the wings fore and aft, there does not seem to be much movement. There is no hole in the fuselage to accept the cross tube yet. I am looking ahead to try an see how things are going to fit in the future, and measurements have an eyeball factor, since things are not in line, and may be suffering some parallax. Currently trying to figure out some way to provide a slot in the quick-connect area for the wing spars to slide in, to make it easier to rig/derig (I don't think there is extra Tufnol in the kit for this, maybe HDPE will work..). ..Final say may well be after the wing is set in its permanent position with lift pins and cross tube installed through the fuselage.. I might use some plumb bobs (hanging from flap pin surface) for a better esitmate, later on today.
Greg
Richard Wheelwright
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 0123456789
Checked by AVG - www.avg.com
06/07/11
Posted: Tue Jun 07, 2011 2:10 pm Post subject: Flap cross tube |
Kelv,
| Quote: | I take it you have the flaps hinged to the wing.
Yes
I did indeed use FL3 as the reference in positioning the flap laterally.
Only about 1/4" of flange needed to be cut off the outboard side of the flap
to center FL3 between the dual flap hinge plates. I had no problem lining up
any of the hinge arms. Most lined up with zero flexing. The inboard most
hinge arms may have had a very very slight flex. It was almost perfect. I
cannot remember which side of the w18's the hinge arms bolted up to, but
both wings were symetric at the root. While setting them up, I remembered
that some builders used S-curves. I was happy to see everything line up. I
would probably re-make the flap end, before s-curving the hinge arm (just my
opinion).
As you say, it intuitively appears at least, that they are not considerably
short for sure. Little shorter than your measurement though. Thanks for
those! Still hoping for a few more measurements to compare to..
Greg
Posted: Tue Jun 07, 2011 2:43 pm Post subject: Flap cross tube |
Hi Craig,
Maybe the flap tube clearance is too close a call to make at the moment. Might have to shelve that thought for now, as one of those things that can't be looked into until later when other things are finalized.
Sounds like a good technique with the cord for setting up the hinge mounts on the fuselage. When potting in the center flap hinge arm a few years ago (on the same axis as the outer hinge arms), I used the lightest stuff I could get my hands on, to eliminate droop. That turned out to be monofilament fishing line. A small toothpick-like stick, which was tied to the line, had plenty of friction to hold itself in place under tension, on the back side of the hinge, with the line going through the exact center of the holes on the outer edges of the flap. Used eyeball and painted the fishing line in the area it went through the holes, to achieve good visibility. Not sure how that technique will work with the fuse hinge arms though, due to accessibility and parallax error. I might have to visit your technique, it sounds pretty good.
I am heading down to pick up some HDPE right now and am hoping it will work at least as well as nylon. I think someone else here had good results. Afraid glue won't stick to either like it does with TUFNOL, though. Might put them on the top side of the spar hole too. Hopefully, it will help one-person attempts to align the wing pins so many times. How did you anchor in the nylon blocks, a number of screws and some glue around the edges of the block? New thread could be started here...almost (prob too short).
Greg F
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of craig
Sent: Tuesday, June 07, 2011 12:46 PM
craig
Hi Richard!
Yes, with the flaps up. The wings are pinned with the main spar pins, but the lift pins are not in place. Could that be it? ...Rocking the wings fore and aft, there does not seem to be much movement. There is no hole in the fuselage to accept the cross tube yet. I am looking ahead to try an see how things are going to fit in the future, and measurements have an eyeball factor, since things are not in line, and may be suffering some parallax. Currently trying to figure out some way to provide a slot in the quick-connect area for the wing spars to slide in, to make it easier to rig/derig (I don't think there is extra Tufnol in the kit for this, maybe HDPE will work..). ..Final say may well be after the wing is set in its permanent position with lift pins and cross tube installed through the fuselage.. I might use some plumb bobs (hanging from flap pin surface) for a better esitmate, later on today.
Greg
Richard Wheelwright
06/07/11
0 [quote][b]
Posted: Wed Jun 08, 2011 4:03 am Post subject: Flap cross tube |
I used two counter sunk screws through the block with nyloc nuts and washers underneath
Greg F
Posted: Wed Jun 08, 2011 11:04 am Post subject: Flap cross tube |
Ok, thanks for the help
Greg F
rparigoris
Posted: Wed Jun 08, 2011 11:47 am Post subject: Re: Flap cross tube |
Hi Greg
On page two I have details of spar ramp install:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=31838&g2_page=1
Boy some portions were thin on my spar ramps, I liked using Tufnal and Reduxing it in place. I used a router to get close and then a belt sander to complete the fitting.
I found that making ramps for wing spar bushings and cowbell entrances really helped out a lot and will keep the aluminium bushings in good shape in addition to putting much less loading on the cowbells since the aluminium bushings will no longer hang up on them.
I had an accelerated cockpit module. After a few trial attempts to rig the wings the starboard cowbell broke looke. It was only Reduxed in place with less than stellar scuff sanding. I reinstalled doing a much better scuff sanding job and installed first ply of fiberglass wet out with Redux, then peel plied. Then subsequent plies of glass were wet out with Aeropoxy. The aluminium aileron bracket I used same technique, first ply Redux wet glass and peel ply, subsequent plies glass wet with Aeropoxy. Heating the Redux with a heat gun once it is on the glass helps to more easily wet out. Redux wet glass sticks much more better to steel or aluminium than Aeropoxy wet glass.
Ron Parigoris
Posted: Thu Jun 09, 2011 1:59 pm Post subject: Flap cross tube |
There a lot of pics and great wing pin/flap documentation there, Ron! It
will take me awhile to go through it with my micro-tooth comb
| Quote: | Boy some portions were thin on my spar ramps, I liked using Tufnal and
Noted. Just in case I cannot get HDPE or nylon spacers to work...where did
you get your extra Tufnol? ..Apologies if this has been discussed already
on the server.
| Quote: | I found that making ramps for wing spar bushings and cowbell entrances
I will look into this.
Greg
rparigoris
Posted: Thu Jun 09, 2011 3:57 pm Post subject: Re: Flap cross tube |
Hi Greg
I purchased Tufnal from my favorite company www.mcmaster.com
Search:
pheonelic
page 3585 to 3589
I probably selected the more easily to machine LE linen grade on page 3585 part#6842K22.
BTW I used G-11 for the ceiling panel (removable) it is very slightly more dimensional stable than G-10. I forget it was either 1/16" or possible 1/13". You can probably find details on my gallery. It was half the thickness of the factory supplied panel but way more dimensional stable. The one sold to me by the factory was polyester and after I fitted it, it warped way out of shape. that said i think they now supply epoxy resin glass panels?
I use G-1o for many tasks in europa build. It is fiberglass instead of paper or linen. kinda like mil spec circuit board material. it bonds well with redux or Aeropoxy. I used it for mass balance guides and many other instances. It is sold in tubes and solid rods and machines OK.
Ron Parigoris
Posted: Fri Jun 10, 2011 2:58 am Post subject: Flap cross tube |
Ron,
Ha-Ha, Always surmised Tufnol and Phenolic were the same, just wasn't
positive. Thanks!
I never got a ceiling panel from the company, but am planning removable,
resizable, remake-able and reposition-able panels, all held on (the sides)
with the plastic knobby type super strong Velcro-like strips. That will give
infinite upgrade potential. Was planning on using 3mm plywood, but will have
to look at this Garolite G10/G11. Sounds kind of handy. If they are as light
as the 3mm plywood with fiberglass over it, I'm on board.
Greg Fuchs, A050
rparigoris
Posted: Fri Jun 10, 2011 9:26 am Post subject: Re: Flap cross tube |
Hi Greg
"I never got a ceiling panel from the company, but am planning removable,
as the 3mm plywood with fiberglass over it, I'm on board."
I have conduits run to ceiling:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=27687
Lots of stuff on the ceiling panel:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=31607
The G-11 weighs less than the one supplied from Factory. The problem I see with using wood covered with glass is it is much thicker than the G-11 and you need to push door seal over the edge. For certain you can work around that, but the G-11 is so thin it is a non issue.
Ron Parigoris
