lwinger
Posted: Tue May 31, 2011 8:23 am Post subject: Instrument panel access |
My forward top skin is in one piece, but I would like to be able to have easy access between the firewall and instrument panel in the future. I realize that I can use U-clips and R&R the whole piece, but I'm really looking for something like an access hole or two.
What has worked for you? Pictures would be appreciated.
Larry Winger
CH650/Corvair
Mods done, engine installed, ready to wire
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
georgerace
Posted: Tue May 31, 2011 8:42 am Post subject: Instrument panel access |
Larry is there something on my web site that would be of help?
www.mrrace.com/Products/
If not I could design and build to your specifications.
George
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Larry Winger
Sent: Tuesday, May 31, 2011 12:19 PM
To: zenith-list(at)matronics.com; zenith601-list(at)matronics.com
Subject: Instrument panel access
Larry Winger
CH650/Corvair
| Quote: | | http://www.matronics.com/Navigator?Zenith601-List | 0123456789
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
psm(at)att.net Guest
Posted: Tue May 31, 2011 8:55 am Post subject: Instrument panel access |
Hi Larry,
I cut large rectangular "Inspection holes" in the top skin. Each one covers nearly one half of the skin with a couple of inches margin from the edges (I think). Inspection plates are typical ZAC design with about 12 nutplates and the same #10 screws as other ones.
I probably have pictures somewhere but I am busy right now (eating lunch). If you would like to see them please let me know.
Paul
XL upgrade complete - reassembling wings to fuselage.
On 5/31/2011 9:19 AM, Larry Winger wrote: [quote]My forward top skin is in one piece, but I would like to be able to have easy access between the firewall and instrument panel in the future. I realize that I can use U-clips and R&R the whole piece, but I'm really looking for something like an access hole or two.
Larry Winger
CH650/Corvair
Posted: Tue May 31, 2011 9:17 am Post subject: Instrument panel access |
Here is a picture that gives you the general idea . . .
[img]cid:part1.09040407.04040600(at)att.net[/img]
Paul
On 5/31/2011 9:52 AM, Paul Mulwitz wrote: | Quote: | Hi Larry,
Paul
On 5/31/2011 9:19 AM, Larry Winger wrote: | Quote: | My forward top skin is in one piece, but I would like to be able to have easy access between the firewall and instrument panel in the future. I realize that I can use U-clips and R&R the whole piece, but I'm really looking for something like an access hole or two.
Larry Winger
CH650/Corvair
58.53 KB |
14710 Time(s) |
lwinger
Posted: Tue May 31, 2011 9:49 am Post subject: Instrument panel access |
Thanks, Paul. Any special reinforcement?
Larry
On Tue, May 31, 2011 at 10:13 AM, Paul Mulwitz <psm(at)att.net (psm(at)att.net)> wrote:
| Quote: | Here is a picture that gives you the general idea . . .
Paul
| Quote: | Hi Larry,
Paul
Larry Winger
CH650/Corvair
58.53 KB |
14710 Time(s) |
Tustin, CA
jaybannist(at)cs.com Guest
Posted: Tue May 31, 2011 9:57 am Post subject: Instrument panel access |
Larry,
Here is what I did. I used electrician's rubber tape instead of the silicone sealant for a gasket. I had that panel off many, many times working out bugs in the wiring.
Jay
115.49 KB |
14710 Time(s) |
127.66 KB |
14710 Time(s) |
163.15 KB |
14710 Time(s) |
 Download |
| Filename: |
InstrAccess2.pdf |
53.99 KB |
| Downloaded: |
712 Time(s) |
lwinger
Posted: Tue May 31, 2011 10:21 am Post subject: Instrument panel access |
Thanks, Jay. As always, you are a great resource.
Larry
On Tue, May 31, 2011 at 10:53 AM, Jay Bannister <jaybannist(at)cs.com (jaybannist(at)cs.com)> wrote:
[quote]Larry,
Jay
Tustin, CA
Posted: Tue May 31, 2011 10:29 am Post subject: Instrument panel access |
Posted: Tue May 31, 2011 10:54 am Post subject: Instrument panel access |
It looks like my last message got corrupted, so here it is again . . .
On 5/31/2011 11:26 AM, Paul Mulwitz wrote:
| Quote: | Hi Larry,
I don't remember for sure, but I might have put a skin weight u
channel on the bottom of the top skin apex. This would stiffen the
attachment to the firewall a little. It probably doesn't matter much
since the inspection plates are firmly fastened to the skin and
replace the skin that was cut out.
One trick I did was to put fuse blocks on the channel going to the
bottom of the instrument panel. I decided that if a fuse blew in
flight it was not time for the pilot to try to trouble shoot the
problem. With the big inspection holes it is easy to get to the fuses
when the plane is on the ground.
Paul
KC7HFA
Joined: 05 Jul 2007 Posts: 11 Location: Southern Oregon
Posted: Wed Jun 01, 2011 7:32 am Post subject: Instrument panel access |
'In God We Trust'
Will be on every e-mail I send out from now on
because, I don't want to lose our right to say it!.
I used nut plates and made the bulk of the top panel as the access panel. I cut the two small pieces that are in front of the canopy hinge off and secured them as permanent pieces, but the rest of the panel comes off with screws around the edge of the panel. Worked great when one of the brake lines started leaking at the master cylinder and I had to repair the leak and re-bleed the brakes. It also gives me complete access to the entire instrument panel. The negative to this installation is that I must pull the top of the engine cowl off prior to the removal of the instrument inspection panel. There are no extra supports, as it’s screwed all the way around the panel. This method gives a lot of flexibility and makes the annuals easier.
Ron Asbill
N601ZX
601XL - 3300 Jabiru
Flying with 120 hours
'In God We Trust'
_________________ Ron Asbill
N601ZX - CH-601 XL
Jabiru 3300
Completed and Flying!~ 150 Plus hours |
Posted: Wed Jun 01, 2011 8:00 am Post subject: Instrument panel access |
l took a look at the airplane and discovered I did indeed put a
reinforcement on the strip between the two large holes in the top skin.
It is a U-channel that is riveted (A5 - 40 pitch) under the top of the
panel and running all the way from the firewall to the instrument
panel. It is made from .025 aluminum with a 2 inch web and 3/4 inch
flanges. This supports the small handle used to help get in and out of
the plane while the inspection plates are not in place.
Paul
On 5/31/2011 11:51 AM, Paul Mulwitz wrote:
> Hi Larry,
lwinger
Posted: Thu Jun 02, 2011 6:12 am Post subject: Instrument panel access |
Thanks to everyone for the great ideas and practical tips. I'm ready to cut some more aluminum!
Larry Winger
On Tue, May 31, 2011 at 9:19 AM, Larry Winger <larrywinger(at)gmail.com (larrywinger(at)gmail.com)> wrote:
Larry Winger
CH650/Corvair
arget="_blank">http://www.matronics.com/Navigator?Zenith-List
tp://forums.matronics.com
| [b]
Tustin, CA
