Posted: Wed May 25, 2011 11:29 am Post subject: Program Letter |
So does 8130.2G apply to those of us that were issued Special Airworthiness Certificates under 8130.2F or not?
Mark
jgriffint28(at)cox.net Guest
Posted: Wed May 25, 2011 11:40 am Post subject: Program Letter |
I recently talked to my FSDO about changing my 300 mile limits. He is a
helpful guy and sent me a copy of what the new op limits look like on
someone elses plane. In it, the program letter must list who is responsible
for maintenance for the plane. He also asked me for a printed maintenance
program. I have included a copy. Check paragraph 3.
Jim Griffin
| Description: |
 Download |
| Filename: |
N54GT.doc |
| Filesize: |
80.5 KB |
| Downloaded: |
500 Time(s) |
Posted: Wed May 25, 2011 11:58 am Post subject: Program Letter |
Yep. It also was a copy of operating limitations on an aircraft that received it's Special Airworthiness Certificate after 8130.2G came out.
My Operating Limitations don't say a lot of what is contained in your example.
So, does that mean I need to ask the FAA for a NEW set of operating limitations?
I would not think so, but I am asking for guidance from people who's job it is to know.
Mark
cjpilot710(at)aol.com Guest
Posted: Wed May 25, 2011 12:06 pm Post subject: Program Letter |
Hmmmm
Hmmmmmmmmmmm. For 56 years I've lived under the CARs FARs under the CAA & now FAA. At no time ever have the regs ever been "clear". It was sort of a life long fantasy that someday I would "know it all" and be able to quote to the less experienced around me that "this means that because it says so". Alas no such luck. The very science of flight has not change (lift, drag, power etc) since the Wrights figured it out, but regs - - - - -. So at some point I'll be turning in my medical, than pondering the roots of grass overhead. And above that will be my younger cohorts pondering - - - not the wonder of flight - - - but the inconsistency of the GDMF FARs.
Jim "Pappy" Goolsby
In a message dated 5/25/2011 3:40:47 P.M. Eastern Daylight Time, jgriffint28(at)cox.net writes:
[quote]I recently talked to my FSDO about changing my 300 mile limits. He is a
Jim Griffin
Posted: Wed May 25, 2011 12:07 pm Post subject: Program Letter |
I neglected to add that the program letter must be in the plane. Refer to
previously sent attachment.
Jim Griffin
Posted: Wed May 25, 2011 2:02 pm Post subject: Program Letter |
What's all the hoop La? Make a copy and put it in the airplane.
Doc
Posted: Wed May 25, 2011 2:26 pm Post subject: Program Letter |
No Hoopla. Put the copy in your airplane and DOC! DON'T DO ANY TAIL SLIDES EITHER!
Mark
Posted: Wed May 25, 2011 2:37 pm Post subject: Program Letter |
I agree. It does not say you have to carry your Program Letter. That
is why I posted it so as to compare to the new 8130.2G.
Dennis
On 5/25/2011 2:25 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14
64E wrote:
Yes, but that does not say you have to carry your Program Letter Dennis. It says you have to carry your OPERATING LIMITATIONS in the aircraft.
Just FYI, under the OLD rules .... I contacted the EAA and the local FAA, the Montana FAA, the Seattle FAA and all of them said you did NOT have to carry your program letter with you. I am sure you were told that you did have to.
It falls into the "whatever you feel is right category" and it also fell into "who interprets the rules" category.
On the other hand, the new rules you just posted are a whole different thing. I read them, they seem quite clear! That said, I never EVER take what ANYONE says on the Yak List regarding rules and regulations as gospel. Even when I read things myself! I always ask for second opinions, third opinions, and even FORTH opinions! I always dig very deeply when it comes to rules.
I sent your quote to the EAA Government Division (Randy Hanson) for confirmation or interpretation. As I said, what you posted seems very clear and is a definite change in policy and adds a new requirement to all of us. But I'll still be interested in what the EAA says.
Mark
Nope! Only the OL's that you have presently.
Dennis
On 5/25/2011 2:26 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14
Mark
Posted: Wed May 25, 2011 2:40 pm Post subject: Program Letter |
Here is how the EAA Govt. Liason Division interprets these rules. These people talk to those that MAKE the rules, not to local FISDO's that INTERPRET the rules.
Thus I consider the EAA to be the best experts available unless you know someone in Washington DC that works for the FAA.
And the answer the EAA writes below is EXACTLY why I took this issue up the chain to get a better understanding.
What Dennis wrote is of course absolutely correct... he just didn't mention 8130.2G, paragraph 4107
And Dennis, I also (respectfully once more disagree when you mention that any changes made to CURRENT Operating Limitations will result in you now being required to fall under 8130.2G, and thus get a whole NEW set of Operating Limitations.
New Airworthiness Certificate .... yes. 8130.2G applies, and you will get all new Operating Limitations and ... you will be required to carry your Program Letter with you, etc.
Removal of an Operating Limitation from an EXISTING list of Operating Limitations attached to an EXISTING Experimental Airworthiness Certificate written under 8130.2F .... NO!
Mark Bitterlich
p.s. For a complete understanding read the response from the EAA contained below.
Posted: Wed May 25, 2011 2:52 pm Post subject: Program Letter |
Roger that.
The only thing I wanted to know really was: "Does this apply to me".
Answer so far: "No it does not".
Sad thing is that if I ever get another Experimental Exhibition aircraft, that requires a new Special Airworthiness Certificate, it most definitely will.
SIGH!
Mark
Posted: Wed May 25, 2011 2:58 pm Post subject: Program Letter |
Ok.
I was wrong. The light bulb just went on.
Dennis, you are/were absolutely correct.
If you change your Operating Limitations in ANY way, that means you also are going to HAVE to obtain a new Special Airworthiness Certificate because the dates on the two documents MUST MATCH! Darn it, I hate when that happens, but I do pride myself on at least being able to stand up and admit when I screw up.
So... you change the Operating Limitations, you must get a new Airworthiness Certificate along with it, and since it ALSO is new, 8130.2G will probably apply.
I say "probably" because I don't even trust my own judgment when it comes to FAA regulations, and I am not going to bother the EAA anymore with this.
Mark Bitterlich
Posted: Wed May 25, 2011 3:17 pm Post subject: Program Letter |
And you know what? It just never ends. Just when I thought I had made a mistake, I might have been wrong.
Read this:
8130.2G says:
(37) When an aircraft's home base is changed or there is a transfer of ownership, the
new owner/operator will take any or all of the following actions within 30 days:
(a) Submit a new program letter to the geographically responsible FSDO.
(b) If an approved inspection program is specified in these operating limitations,
submit a copy to the geographically responsible FSDO. The gaining FSDO will not change the
previously approved program unless it can be substantiated that the previously approved program
no longer meets FAA requirements.
(c) The gaining FSDO will not require the aircraft's airworthiness certificate or
operating limitations to be reissued, unless the aircraft requires Phase I test flight operations.
So, I would read that to mean that they won't change the Operating Limitations.
The whole thing is a crock of dog poop. Who knows for sure WHAT anything means.
Good luck... Mark's out of this one. ENOUGH already. I quit.
Posted: Wed May 25, 2011 3:56 pm Post subject: Program Letter |
Mark, it just means that the whole Exp exhibition thing is a confusing mess
even to the FAA. According to 37{c} I don't need new Op limits if I sell the
plane or move, but if I ask to have the Op limits changed [no 300 mile
limit] then the program letter and maintenance provision will be included.
Whew!
Jim Griffin
Posted: Wed May 25, 2011 4:45 pm Post subject: Program Letter |
For almost 18 years now we've never needed an approved inspection
program. The Group III over 800 HP did and so did the jets. But never
the aircraft in the under 800 hp group. Maybe our friendly EAA can shed
some light on why this is necessary now for the Group 2 (formally Group
III under 800 HP). Doesn't make sense.
Dennis
mess even to the FAA. According to 37{c} I don't need new Op limits if
I sell the plane or move, but if I ask to have the Op limits changed
[no 300 mile limit] then the program letter and maintenance provision
will be included. Whew!
Jim Griffin
Posted: Wed May 25, 2011 5:09 pm Post subject: Program Letter |
Jim,
I read the new OL's completely and I don't see anything that says you
have to submit a printed maintenance program to the FAA for the group
your aircraft is certificated in. I do see a maintenance
program/inspection program requirement for the larger airplanes and jets
as specified in paragraph 29. But not for Group 2. Am I missing
something or is your FSDO guy crossing Group boundaries?
As for the requirement to list in the program letter who is responsible
for the maintenance of the airplane, that should not be an issue. Most
everyone will list themselves unless they have a mechanic that does the
work for them.
Dennis
On 5/25/2011 2:36 PM, Jim Griffin wrote:
[quote] I recently talked to my FSDO about changing my 300 mile limits. He is
a helpful guy and sent me a copy of what the new op limits look like
on someone elses plane. In it, the program letter must list who is
responsible for maintenance for the plane. He also asked me for a
printed maintenance program. I have included a copy. Check paragraph 3.
Jim Griffin
Posted: Wed May 25, 2011 5:19 pm Post subject: Program Letter |
Jim,
From 8130.2G, Group 2 definition which clearly gives the example of a
Yak 52 in the group at the bottom of the group, it says:
(f) Must be in compliance with the manufacturer’s or country of origin’s
maintenance, and/or inspection programs (if provided).
(g) If the manufacturer or country of origin does not provide an inspection
program, the aircraft must have an annual condition inspection that
meets the scope and detail of
14 CFR part 43, appendix D.
Since the manufacturer has not provided maintenance and/or inspection
program, the requirement defaults to paragraph (g), which is the same
old stuff we've always had. ie: Condition inspection that meets the
scope and detail of 14 CFR 43, Appendix D.
to previously sent attachment.
Jim Griffin
Jetj01(at)aol.com Guest
Posted: Wed May 25, 2011 5:52 pm Post subject: Program Letter |
I just got my new OL and AC last week from the Dallas FSDO for Yak 50. Experimental Exhibition, Group 2. No maintenance program required and actually very pleased with both my new Operating Limits as well as the FAST and great service at the FSDO.
Jj
On May 25, 2011, at 8:06 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net> wrote:
Jim,
I read the new OL's completely and I don't see anything that says you have to submit a printed maintenance program to the FAA for the group your aircraft is certificated in. I do see a maintenance program/inspection program requirement for the larger airplanes and jets as specified in paragraph 29. But not for Group 2. Am I missing something or is your FSDO guy crossing Group boundaries?
As for the requirement to list in the program letter who is responsible for the maintenance of the airplane, that should not be an issue. Most everyone will list themselves unless they have a mechanic that does the work for them.
Dennis
> I recently talked to my FSDO about changing my 300 mile limits. He is a helpful guy and sent me a copy of what the new op limits look like on someone elses plane. In it, the program letter must list who is responsible for maintenance for the plane. He also asked me for a printed maintenance program. I have included a copy. Check paragraph 3.
> Jim Griffin
Posted: Wed May 25, 2011 6:50 pm Post subject: Program Letter |
Dennis, I used your response in a letter I just sent to my FSDO in OK City.
I will let you know his response. Like I said, he is a helpful guy and this
may be a teachable moment for him as well.
Jim Griffin
