colleenandbrett(at)comcas Guest
Posted: Sun May 22, 2011 4:46 am Post subject: Avery Rudder Cable Fairing |
When installing the Avery Rudder Cable Fairing, does one still install the bolt / clamp to retain / locate the 3/8" diameter polyethylene tube as shown on drawing # 34 or does this fairing alone pushing against this tube provide sufficient retention?
Thanks.
Brett
Columbus, IN
RV-6AQ Installing the rudder cables
| | - The Matronics RV6-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Sun May 22, 2011 5:21 am Post subject: Avery Rudder Cable Fairing |
Brett, I installed both the clamp and fairing. More structurally sound and retains the poly tube much better than relying on the fairing alone.
Best Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Sent from my iPad
On May 22, 2011, at 7:43 AM, colleenandbrett(at)comcast.net (colleenandbrett(at)comcast.net) wrote:
Thanks.
Brett
Columbus, IN
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
John Brunke
Posted: Sun May 22, 2011 7:37 am Post subject: Avery Rudder Cable Fairing |
I second Jeff's installation. You would hate for something to jam back there someday if the tubing came loose.John Brunke
RV7QB slow build.
Saint Charles, IL
On May 22, 2011, at 8:20 AM, Jeff Orear wrote:
| Quote: | Brett, I installed both the clamp and fairing. More structurally sound and retains the poly tube much better than relying on the fairing alone.
Best Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Sent from my iPad
Thanks.
Brett
Columbus, IN
href="x-msg://31/3D%22http://www.matronics.com/Navigator?RV6-List%22">http://www.matronics.com/Navigator?RV6-List
href="x-msg://31/3D%22http://forums.matronics.com%22">http://forums.matronics.com
href="x-msg://31/3D%22http://www.matronics.com/contribution%22">http://www.matronics.com/contribution
Posted: Tue May 24, 2011 5:48 pm Post subject: Avery Rudder Cable Fairing |
Thanks for the responses!
I will install the clamp.
So, to take it a bit further, I am assuming that the fairing should not trap the 3/8" polyethylene tube against the fuselage skin so that the rudder cable can be removed with the fairing riveted in place. Thus, the 3/8" x 1 1/8" oval opening that I have made should be longer. Correct?
Thanks.
Brett Herrick
RV-6A Installing the rudder cables
Columbus, IN
Time: 08:37:59 AM PST US
Subject: Re: RV6-List: Avery Rudder Cable Fairing
John Brunke
RV7QB slow build.
Saint Charles, IL
alone.
Best Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Sent from my iPad
| Quote: | >
> Thanks.
> Brett
> Columbus, IN
Painless
Posted: Tue May 24, 2011 6:53 pm Post subject: Avery Rudder Cable Fairing |
I have that tube extending out into the fairing. The fairing is actually helping to direct the tube/cable toward the rudder horn. I guess if I had to remove the cable, six rivets drilled out and the fairing is off. To be honest, I doubt if I ever will need to remove those cables.
Jeff Orear
RV6A N782P
Peshtigo, WI
On May 24, 2011, at 8:44 PM, "Colleen and Brett Herrick" <colleenandbrett(at)comcast.net (colleenandbrett(at)comcast.net)> wrote:
[quote] Thanks for the responses!
Thanks.
Brett Herrick
Columbus, IN
From: John Brunke <jdoody727(at)comcast.net (jdoody727(at)comcast.net)>
Subject: Re: Avery Rudder Cable Fairing
John Brunke
RV7QB slow build.
Saint Charles, IL
alone.
Best Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Sent from my iPad
| Quote: | >
> Thanks.
> Brett
> Columbus, IN
RV6A N782P
Peshtigo, WI |
