jeffrey-j-paris(at)excite Guest
Posted: Tue May 17, 2011 1:44 pm Post subject: Electrical Problem with Ray Allen Indicator? |
Hey Zentih Guys,
Quick question- I have got bothRay Allen aileron and elevator trim on my CH601XLB, which work off a Ray Allen G205 hand grip, before the mods the system worked fine ,however, now that I'm back to test flying and de-bugging I have a problem with my elevator servo. The elevator indicator won't come on line and indicate, my trims work well, however, I must have made a bad connection somewhere and I just can't seem to find where it is. I have sent the indicator back to Ray Allen's and it came back saying that the indicator was fine and I am now completely lost and wonder if anybody else has any experience with his sort of mishap.
I fully admit that I'm not that comfortable with all things electric andother than continuity tests and checking for voltage I really don't have the electrical savvy to determine what is wrong. Thanks for your time and considerstion.
Jeff Paris N196ZP CH601XLB Rochester, NY
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Tue May 17, 2011 2:02 pm Post subject: Electrical Problem with Ray Allen Indicator? |
Jeff--
Even though Ray Allen indicated all is well ,you might try pushing on the faceplate of the indicator. I've had two units become intermittent, with this symptom, after about a year of use. I found out that they had a bad set of boards years ago. I assume that since you wired it correctly once, you probably did it correctly the second time.
Good luck
George May
Zodiac 601XLB 912s ---392hrs
Date: Tue, 17 May 2011 17:40:11 -0400
Subject: Electrical Problem with Ray Allen Indicator?
Hey Zentih Guys,
target=_blank>http://www.matronics.com/Navigator?Zenith-List
ttp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
Posted: Tue May 17, 2011 2:54 pm Post subject: Electrical Problem with Ray Allen Indicator? |
| Quote: | | Based on my notes on the RAC position sender and display (the LED version, not the "pointer" version) this is what you can measure with a volt meter: with the sender connected the display moving the sender from one extreme to another you should see the voltage on the green wire vary from 0.21 to 1.25 volts. -- Craig |
psm(at)att.net Guest
Posted: Tue May 17, 2011 5:07 pm Post subject: Electrical Problem with Ray Allen Indicator? |
Hi Jeff,
I'm afraid it is just a case of verifying continuity on the wires from the servo to the indicator. If you have developed a short you can find it by buzzing from each of the leads to ground and battery voltage.Â
If all else fails you can run fresh wiring from the indicator to the servo and wherever else it goes.
Good luck,
Paul
XL getting close - just installed all the placards and working on seat cushion.
On 5/17/2011 2:40 PM, Jeffrey J Paris wrote: [quote] Hey Zentih Guys,
Â
Â
I fully admit that I'm not that comfortable with all things electric andother than continuity tests and checking for voltage I really don't have the electrical savvy to determine what is wrong. Â Thanks for your time and considerstion.
Â
Thruster87
Posted: Tue May 17, 2011 10:14 pm Post subject: Re: Electrical Problem with Ray Allen Indicator? |
After 15hrs TT [last week] my Aileron Ray Allen LED indicator stopped working as well.Elevator LED indicator working just fine so far.Bit of a pain in the neck as mine are located on the center panel and access requires removal.Keep us posted on what the end results are Cheers Alan
