Albert Gardner
Posted: Fri May 13, 2011 8:00 am Post subject: iPad |
| Quote: | | For those of you using an iPad – what sort of mounting is working out well? I’m thinking of buying the Sporty’s Flight Gear iPad Kneeboard ($39.95) and wonder if anyone else is using it. I’ve also thought about a RAM hard mount but wonder if that would get in the way. Albert GardnerN991RVYuma, AZ |
_________________ RV-9A N872RV
RV-10 N991RV |
flysrv10(at)gmail.com Guest
Posted: Fri May 13, 2011 9:06 am Post subject: iPad |
I am using Ram mount. I posted a couple of pictures that you might search for. Ram mount also said they would show my mount on their website. I can sen you pictures later if you need them.
Rob Kermanj
On May 13, 2011, at 11:57 AM, "Albert Gardner" <ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)> wrote:
[quote] | Quote: | For those of you using an iPad – what sort of mounting is working out well? I’m thinking of buying the Sporty’s Flight Gear iPad Kneeboard ($39.95) and wonder if anyone else is using it. I’ve also thought about a RAM hard mount but wonder if that would get in the way. Albert GardnerN991RVYuma, AZ
ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
ums.matronics.com">http://forums.matronics.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
Deems Davis
Posted: Fri May 13, 2011 9:39 am Post subject: iPad |
Al, If it's the one that I'm thinking of (It opens up like a folder) save your time, it's way too big to use in the RV10. I sent mine back.
Deems
On 5/13/2011 8:57 AM, Albert Gardner wrote: [quote] <![endif]--> <![endif]--> | Quote: | For those of you using an iPad – what sort of mounting is working out well? I’m thinking of buying the Sporty’s Flight Gear iPad Kneeboard ($39.95) and wonder if anyone else is using it. I’ve also thought about a RAM hard mount but wonder if that would get in the way. Albert GardnerN991RVYuma, AZ
Deems Davis[b]
Albert Gardner
Posted: Fri May 13, 2011 9:47 am Post subject: iPad |
Rob: can't find the pics on RAM's web page. Could you send them when you get a chance?
How do you like flying with the iPad?
Albert
On May 13, 2011, at 10:02 AM, Sohrab Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
[quote]I am using Ram mount. I posted a couple of pictures that you might search for. Ram mount also said they would show my mount on their website. I can sen you pictures later if you need them.
Rob Kermanj
On May 13, 2011, at 11:57 AM, "Albert Gardner" <[url=mailto:ibspud(at)roadrunner.com]ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)[/url]> wrote:
RV-10 N991RV |
amekler
Posted: Fri May 13, 2011 9:56 am Post subject: iPad |
I have the knee board strap.it is ok. i'm looking to mount mine under the throttle quadrant at an angle on the tunnel but worried about the temp. the ipad can shot down if it gets too hot.
Alan
n668G
On Fri 05/13/11 11:57 AM , "Albert Gardner" <ibspud(at)roadrunner.com> wrote:
[quote] | Quote: | For those of you using an iPad – what sort of mounting is working out well? I’m thinking of buying the Sporty’s Flight Gear iPad Kneeboard ($39.95) and wonder if anyone else is using it. I’ve also thought about a RAM hard mount but wonder if that would get in the way. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Albert GardnerN991RVYuma, AZ [/b] | [b]
Posted: Fri May 13, 2011 9:58 am Post subject: iPad |
I personally like keeping mine free. I use a normal kneeboard for writing down clearances and frequencies and stuff like that (on paper), and use the ipad for maps, airport info and plates. I have an armrest between the front seats and I usually either keep the ipad on the armrest or on my lap. I put it on the glare shield a couple of times and it quickly overheats, which renders it unusable until it cools down. Not going that anymore. When I want to put it away I put it inside the armrest or hand it to the copilot to hold while I fly the plane. If it isn't mounted in/on the panel, I can't think of a good place to fix it in the plane where it wouldn't be in the way.
YMMV
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On May 13, 2011, at 11:57 AM, Albert Gardner wrote:
| Quote: | | Quote: | For those of you using an iPad – what sort of mounting is working out well? I’m thinking of buying the Sporty’s Flight Gear iPad Kneeboard ($39.95) and wonder if anyone else is using it. I’ve also thought about a RAM hard mount but wonder if that would get in the way. Albert GardnerN991RVYuma, AZ
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
Albert Gardner
Posted: Fri May 13, 2011 2:39 pm Post subject: iPad |
Deems, did you find a better solution? Maybe I’ll just use it like Jesse Saint does. I’m using Foreflight at the moment but I see on Flight Guide’s webpage that they have a GPS Antenna addon and sounds like they are planning moving map and weather with their App. Might see some interesting stuff at Oshkosh this year.
Albert
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis
Sent: Friday, May 13, 2011 10:36 AM
Subject: Re: iPad
Deems
On 5/13/2011 8:57 AM, Albert Gardner wrote: | Quote: | | For those of you using an iPad – what sort of mounting is working out well? I’m thinking of buying the Sporty’s Flight Gear iPad Kneeboard ($39.95) and wonder if anyone else is using it. I’ve also thought about a RAM hard mount but wonder if that would get in the way. Albert GardnerN991RVYuma, AZ |
| Quote: | | -- Deems DavisAlbert Gardner | 01 - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b]Albert Gardner[/quote]2
RV-10 N991RV |
Posted: Fri May 13, 2011 3:34 pm Post subject: iPad |
I will take some with my phone and send them to you tomorrow when it is light outside.
I love flying with the iPad. Cannot imagine ever carrying charts again. The only problem is direct sunlight. It is not bad enough for me to consider any other tablet or charts.
I just ordered the anti glare Tim recommended and will know soon if it works. My neighbor bought an anti glare locally so we can compare. I will let the list know how. They compare.
Rob Kermanj
On May 13, 2011, at 1:44 PM, Albert <ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)> wrote:
[quote]Rob: can't find the pics on RAM's web page. Could you send them when you get a chance?
Albert
On May 13, 2011, at 10:02 AM, Sohrab Kermanj <[url=mailto:flysrv10(at)gmail.com]flysrv10(at)gmail.com (flysrv10(at)gmail.com)[/url]> wrote:
| Quote: | I am using Ram mount. I posted a couple of pictures that you might search for. Ram mount also said they would show my mount on their website. I can sen you pictures later if you need them.
Rob Kermanj
On May 13, 2011, at 11:57 AM, "Albert Gardner" < (ibspud(at)roadrunner.com)[url=mailto:ibspud(at)roadrunner.com]ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)[/url]> wrote:
Tim Olson
Posted: Fri May 13, 2011 4:42 pm Post subject: iPad |
I did my iPad 2 and it took me a while. You have to NOT at all
put any kinks in the plastic with a fingernail or other, don't
flex it to the point of kinking locally. Have NO dust around,
and when it fails to go on dust free, wash it in a spray of
warm water and shake it off and apply it and squeege it on
with something flat like a credit card. It took me 3 or 4
tries to get it fairly good this time, because i couldn't
keep enough dust away. You can pick the dust off the sticky
back when its wet. It can be frustrating, but, once you get
it on, it works really well and is very strong.
Tim Olson - RV-10 N104CD
On 5/13/2011 6:32 PM, Rob Kermanj wrote:
| Quote: | I will take some with my phone and send them to you tomorrow when it is
light outside.
Rob Kermanj
> you get a chance?
> Albert
> Sent from my iPad
> <<mailto:flysrv10(at)gmail.com>flysrv10(at)gmail.com
>> Rob Kermanj
>> Sent from my iPhone
>> <<mailto:ibspud(at)roadrunner.com><mailto:ibspud(at)roadrunner.com>ibspud(at)roadrunner.com
>>> *For those of you using an iPad – what sort of mounting is working out well? I’m thinking of buying the Sporty’s Flight Gear iPad Kneeboard ($39.95) and wonder if anyone else is using it. I’ve also thought about a RAM hard mount but wonder if that would get in the way.*
>>> *Albert Gardner*
>>> *N991RV*
>>> *Yuma, AZ*
>>> ref=" <http://www.matronics.com/Navigator?RV10-List>http://www.matronics.com/Navigator?RV10-List"> <http://www.matronics.com/Navigator?RV10-List>http://www.matronics.com/Navigator?RV10-List
>>> <http://ums.matronics.com>ums.matronics.com <http://ums.matronics.com>"> <http://forums.matronics.com>http://forums.matronics.com
>>> <http://www.matronics.com/contribution>http://www.matronics.com/contribution"> <http://www.matronics.com/contribution>http://www.matronics.com/contribution
>> ums.matronics.com <http://ums.matronics.com>">http://forums.matronics.com
Posted: Fri May 13, 2011 4:56 pm Post subject: iPad |
Thanks for the tip.
Rob Kermanj
On May 13, 2011, at 8:38 PM, Tim Olson <Tim(at)MyRV10.com> wrote:
> light outside.
> Do not archive
> Rob Kermanj
> Sent from my iPad
>> you get a chance?
>> Albert
>> Sent from my iPad
>>> Rob Kermanj
>>> Sent from my iPhone
>>>> *Albert Gardner*
>>>> *N991RV*
>>>> *Yuma, AZ*
aerosport1
Posted: Sun May 15, 2011 4:54 pm Post subject: iPad |
I have been working on a new flip up mount. It will hold the iPad, knee
board or any ipod or phone. It is great when traveling.
It is still a work in progress.
Geoff Combs
N829GW
198.05 KB |
10985 Time(s) |
120.52 KB |
10985 Time(s) |
120.92 KB |
10985 Time(s) |
120.27 KB |
10985 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
jdriggs49(at)msn.com Guest
Posted: Sun May 15, 2011 5:33 pm Post subject: iPad |
I hope you plan on marketing them. I want to be first on your list to purchase it.
[quote] From: g.combs@aerosportmodeling.com
To: rv10-list@matronics.com
Subject: Re: RV10-List: iPad
Date: Sun, 15 May 2011 20:49:53 -0400
Geoff Combs
N829GW
Albert Gardner
Posted: Mon May 16, 2011 9:05 am Post subject: iPad |
I found that my bad Elf GPS unit doesn't always seem to pick up the satellites so I got an extension cable so that the GPS can lay up on the glare shield (along with the Garmin 496 GPS and WX pucks). I may have to start thinking about external gps antennas although I'm going to try placing the Bad Elf up in the overhead console next. Extension cable was 4.99 + 4.99 shipping from cellphoneshop.com so not as expensive as I had imagined. I'm learning to love this iPad and Foreflight.
Albert Gardner
N991RV
Yuma, AZ
RV-10 N991RV |
rwwende
Posted: Fri May 20, 2011 11:19 am Post subject: Re: iPad |
Another good option is from Proclipusa.com
