plevyakh
Posted: Sat May 14, 2011 8:20 am Post subject: Ok to bend uninsulated ring terminals? |
I'm installing my L-60 alternator and have an issue with clearance of the B-lead nut and trying to install an uninsulated Ring Terminal (4AWG, .25" Stud). The standard flat terminal directs the wire 90 degrees from the B-lead nut.
I need the wire to run AFT or parallel to the B-Lead post to be able to feed it through my front right engine baffle and then towards the starter contactor sitting on the firewall.
Is it acceptable to bend the uninsulated ring terminal 75 to 90 degrees? Or is there a different #4AWG terminal I could use that would allow the wire to come off the B-Lead post pointing AFT instead of perpendicular to the post?
Howard
_________________ Howard Plevyak
GlaStar / Cincinnati, Ohio |
Posted: Sat May 14, 2011 10:41 am Post subject: Ok to bend uninsulated ring terminals? |
At 12:20 PM 5/14/2011, you wrote:
Sure. But one bend only. After all, the barrel
of a ring terminal is "bent" to form the barrel.
There are terminals with factory-bent flags that
accommodate the functionality you're needing. Those
products might be heat-treated after the bending
operation for stress relief . . . but not necessarily
so.
All metals have a relatively predictable behavior
with respect to stresses in the material and the
number of times that stress can be applied before
failure occurs.
I'm told that this characteristic gave rise to
an early-on requirement for running an engine
for 75 hours on a test stand as part of the
certification process. Not that 75 hours of 'service
life' was good enough. It was based on the premise
that if a ferrous (iron based) parts did not fail
in 10 million cycles at rated stresses, it wasn't
going to fail during service life due to overstress.
That didn't mean the engine wouldn't wear out in
200 hours . . . it just meant that it wasn't going
suffer breakage at those stress levels.
Non-ferrous parts (copper, alum, etc) behave a bit
differently. They DO have a stress-to-cycles service
life. Furthermore, it's a non-linear curve. For example:
You might bend your copper terminal over a 90 degree
flex say 10 times before it cracks. Change that
to 45 degrees and the number goes up markedly . . .
say 50 times. Change that to a vibratory oscillation
that deflects it just a fraction of a degree, and the
number might be in the millions of cycles . . . BUT IT
WILL break eventually, even at that small level of
deflection.
This is why wings have been known to fall off and cabin
tops have blown out of venerable airplanes. The
phenomenon can usually be traced to an error of analysis
for the stress-to-events ratio of the part that failed.
So you're safe in forming the flag on your terminals
as needed to accommodate the installation but strive
minimize the number of events for this very severe
stress on the material. Know that by doing this one
bend, you have reduced the service life by some
large but probably insignificant number (1 billion
down to 800 million????) for the as-installed
condition.
This is why it's a good idea to limit the stress
applied to such terminals by supporting the wire
as close as practical to the terminal or perhaps
fabricating the wire from some very flexible material
(like welding cable) to minimize that wire's ability
to apply a lever-moment (length x mass) to the
terminal.
Taking the b-lead wire immediately away from the
alternator to attach at some point on the airframe
does not offer much means for near-terminal support
of that wire. In fact, the terminal end will be
shaking with the amplitude of engine vibration
while the airframe end is much more stationary.
Can you leave the terminal flat, support the wire
close to the terminal and then route off to the
airframe?
The same admonition applies to bolting fat-wires to
the lead posts on many of the RG batteries we're
so fond of. Lead posts have a similarly non-linear
s/n to failure curve. In years past, we've heard
from builders who suffered a battery post failure
due to vibrations stresses of a 2AWG jumper wire
bolted to the battery.
This is why we've recommended 4AWG welding cable
jumpers from the (+) post to contactor and (-) post
to ground for such batteries . . . irrespective
of the size of fat wires elsewhere in the system.
You might want to consider a welding cable jumper
from your alternator's b-lead to where ever that
segment ties off to the rest of the system.
These are gross examples of what that copper sleeve
inside the insulator of a PIDG terminal is all about.
When you mashed the terminal on the wire, you placed
the wire under severe stress to achieve the gas-tight
connection. Support immediately adjacent to that
stress riser is key to long service life.
The terminal itself benefits from the same consideration
for reducing cyclic stresses to the material.
rjquillin(at)cox.net Guest
Posted: Sat May 14, 2011 11:28 am Post subject: Ok to bend uninsulated ring terminals? |
On 5/14/2011 11:36, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> Bob,
Sure. But one bend only. After all, the barrel of a ring terminal is
There are terminals with factory-bent flags that ccommodate the
products might be heat-treated after the bending operation for
stress relief . . . but not necessarily so.
I would suggest an effort to maximize the bend radius would also prove
wise to distribute stress, as opposed to a minimal radius 'sharp' 90
degree bend that would concentrate it; as one might obtain by clamping
the ring in a vise and whacking the crimp barrel over with a hammer
would likely produce.
Posted: Sat May 14, 2011 1:08 pm Post subject: Ok to bend uninsulated ring terminals? |
| Quote: | | I would suggest an effort to maximize the bend radius would also prove wise to distribute stress, as opposed to a minimal radius 'sharp' 90 degree bend that would concentrate it; as one might obtain by clamping the ring in a vise and whacking the crimp barrel over with a hammer would likely produce. |
Excellent point. If one has an 1/8" piece
of aluminum or mild steel from which to fabricate
a bend radius tool . . .
[img]cid:7.1.0.9.0.20110514165610.01db16f8(at)aeroelectric.com.0[/img]
Bob. . .
34.59 KB |
7858 Time(s) |
plevyakh
Posted: Sat May 14, 2011 2:03 pm Post subject: Re: Ok to bend uninsulated ring terminals? |
I'll try to maximize the bend radius and support the wire as well.
Thank-you both for the replies. Just what I needed to keep making progress.
Howard
