Bus bar
wdaniell(at)etb.net.co
PostPosted: Fri May 13, 2011 8:39 am    Post subject: Bus bar Reply with quote
Can anyone send me a picture of their bus bar/advise me on the best option.
The ones that come with the Europa wiring kit seem to be plastic domestic
terminal blocks with one side (as it were) liked by wires/ring terminals
(Crimped not soldered Wink).
the wiring seems to me to add another point of failure whereas a straight
copper bar would eliminate this - indeed one of the crimped connections was
not crimped and I had to redo it.
Will
davidjoyce(at)doctors.org
PostPosted: Fri May 13, 2011 9:02 am    Post subject: Bus bar Reply with quote
William, Mine are brass bars pre-drilled to take bolts for ring terminals.
The positive one has a plastic cover over it. The system has worked well.
Unfortunately I can't remember where they came from! regards, David
mau11(at)free.fr
PostPosted: Fri May 13, 2011 9:17 am    Post subject: Bus bar Reply with quote
Will
Will,
I send to you a PDF drawing of my bus bar off this forum
Good evening
Michel AUVRAY
mau11(at)free.fr
alanb(at)dpy01.co.uk
PostPosted: Fri May 13, 2011 10:09 am    Post subject: Bus bar Reply with quote
I bought some brass bar from the local DIY Store B&Q, in UK, drilled and tapped them myself.
Alan
Will
rparigoris
PostPosted: Fri May 13, 2011 11:16 am    Post subject: Re: Bus bar Reply with quote
Hi Will
Some bus info:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=30683
Worth looking here too at flat thin copper wire, connectors and port negative inter ground wire connector/bus:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=30710
Ron Parigoris
frans(at)privatepilots.nl
PostPosted: Fri May 13, 2011 3:07 pm    Post subject: Bus bar Reply with quote
I just put a few bolts through the firewall. One bolt is connected to
ground, another to the 12 Volt power. On these bolts I can hook as many
ring terminals as I want, on the engine side as well as on the cabin
side. The amount of connections is only limited by the length of the
bolts. Wink And the maximum current is determined by the diameter of the
bolt. An AN3 will transfer more than enough current.
It is simple, economic, fail proof, light weight, it solves the problem
to get the power through the firewall, etc.
A bolt is just as good as a bar. And to fix the bar you need two bolts
anyway. Wink
Frans
kingsnjan(at)westnet.com.
PostPosted: Fri May 13, 2011 5:22 pm    Post subject: Bus bar Reply with quote
Will,
As with so many things in life nowadays, there are many alternatives.
I chose the Bussmann fuse block as depicted in the following link. This
unit
has its own bus bar (dual bus if required) that feeds up to 32 fuses. Mine
is the 20 fuse model. Only one wire needs to come through the firewall or
two if separate feeds are required for the dual bus.
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/15710_Fuse_Panel.pdf
I fitted mine as per the attached.
Cheers
Kingsley
 Filesize:  741.19 KB
 Viewed:  6523 Time(s)
graeme bird
PostPosted: Sat May 14, 2011 3:14 am    Post subject: Re: Bus bar Reply with quote
I did the same as Frans, used brass bolts through the firewall as the main star points, I fed 5 wires with ring ends through a hole from the instrument panel and connected on the bolts so I can easily remove the instrument panel. I had noisy and quiet power and return and alternator output. Really you want the battery to be the bus (but then my battery is in the FWFD). In the instrument panel again I wired to brass bolts on the ledge 2" from the bottom for ground star connections to low power instruments etc.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
bill mcclellan
PostPosted: Sat May 14, 2011 5:34 am    Post subject: Bus bar Reply with quote
I am considering Vertical Power to simplify fusing and wiring. Has anyone used this system? http://www.verticalpower.com/
Bill McClellan
PostPosted: Mon May 16, 2011 8:12 am    Post subject: Bus bar Reply with quote
Thanks to all for input
this wiring/instrument thing is pesky
Will
