jeffrey-j-paris(at)excite Guest
Posted: Wed May 04, 2011 3:50 pm Post subject: N196ZP "B" CH601XLB Model finished! |
Hello Zenith Land,
Tomorrow is the big day, I will attempt my first start-up and flght in my "B" Zodiac since Oct of 2009 when I grounded my aircraft. I completely stripped and repainted my airplane.
Any advice for starting an engine that hasn't run for such a long time? ( she was drained of all fuel and cylinder heads/barrels were sprayed with preservative oil)
The weather looks good for tomorrow and I so want to enjoy my bird again. Thanks for your time and consideration.
Jeff Paris
Rochester, NY
| Description: |
| Filesize: |
448.13 KB |
| Viewed: |
2892 Time(s) |
| Description: |
| Filesize: |
392.57 KB |
| Viewed: |
2892 Time(s) |
n801bh(at)netzero.com Guest
Posted: Wed May 04, 2011 7:31 pm Post subject: N196ZP "B" CH601XLB Model finished! |
Nice lookin plane.... Be safe on your first flight.
Ben Haas
N801BH
www.haaspowerair.com
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Thu May 05, 2011 2:43 am Post subject: Re: N196ZP |
Jeff,
Be safe on your second, first flight. If you have not run your engine in a while, a good looking over of the Bing would be in order. Make sure the bowl area is clean of a sediment/varnishing. Also make sure the slide piston moves easily and that there is no corrosion present. This is all typical things to look at. Personally, I would also run it a bit, including a static RPM check, and then remove the cowls and check things over one more time prior to the flight.
After that...have fun!
Dave
_________________ David Gallagher
Cincinnati, OH area |
