hgmckay
Posted: Thu Apr 21, 2011 2:41 pm Post subject: New Rotax Oil Pressure Regulator Parts |
Fixing to install the new Rotax Oil pressure regulator replacement parts (cone, spring, and Hex screw). I don’t believe an oil system purge is necessary or required when replacing the old parts with these new ones. However, as I remember an old SI for replacing the spring and cleaning the “ball” stated to follow the purging procedure. Any comment?
Hugh G. McKay III, P.E.
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
http://www.wwegeo.com
 Download |
| Filename: |
Hugh.vcf |
364 Bytes |
| Downloaded: |
440 Time(s) |
bob(at)fly-ul.com Guest
Posted: Thu Apr 21, 2011 3:00 pm Post subject: New Rotax Oil Pressure Regulator Parts |
Not needed. Only a little oil will dribble out when you make the change. No different than removing the oil filter
--Bob Comperini
On Apr 21, 2011, at 3:37 PM, "Hugh McKay" <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
[quote] Fixing to install the new Rotax Oil pressure regulator replacement parts (cone, spring, and Hex screw). I don’t believe an oil system purge is necessary or required when replacing the old parts with these new ones. However, as I remember an old SI for replacing the spring and cleaning the “ball” stated to follow the purging procedure. Any comment?
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email [url=mailto:hgmckay(at)bellsouth.net]hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)[/url]
<Hugh.vcf>
Roger Lee
Posted: Thu Apr 21, 2011 4:13 pm Post subject: Re: New Rotax Oil Pressure Regulator Parts |
Hi Hugh,
I'm with Bob. No purge. Too little oil drool to worry about.
Hi Bob,
How have you been?
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
hgmckay
Posted: Fri Apr 22, 2011 5:31 am Post subject: New Rotax Oil Pressure Regulator Parts |
Bob, Roger,
Thanks, I thought that was the case.
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
