Wood Fairings
rawheels
PostPosted: Wed Mar 30, 2011 8:59 am    Post subject: Wood Fairings Reply with quote
WurleyBird's recent post on the PVC wing struts has got me looking into finally streamlining the bush gear that I installed a while ago. Is anyone cutting the wooden streamline strips, or happen to have some extra left over from their project by chance?
Av8r3400
PostPosted: Thu Mar 31, 2011 4:27 am    Post subject: Re: Wood Fairings Reply with quote
Brett at Airdale has this wood faring material on hand.
http://www.airdale.com/
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos
Dick Maddux
PostPosted: Thu Mar 31, 2011 4:35 am    Post subject: Wood Fairings Reply with quote
Rawheels,
You could do this for your bush gear.
      Dick Maddux
      Fox 4
      Milton,Fl
 Filesize:  374.04 KB
 Viewed:  13746 Time(s)
rawheels
PostPosted: Thu Mar 31, 2011 7:38 am    Post subject: Re: Wood Fairings Reply with quote
Dick,
I have always just planned on using wood & fabric like my original gear, so I didn't go for the fairing option on the Highwing, LLC gear. That means I don't have the welded tabs. I could ask Lowell if there is another way to attach their fairings. Sure do like their workmanship. Although, I'd still be looking at trying to streamline a portion of the spring tube that doesn't get covered by their fairing.
lcfitt(at)sbcglobal.net
PostPosted: Thu Mar 31, 2011 9:40 am    Post subject: Wood Fairings Reply with quote
The formed fairings need the tabs. The original idea for these fairings was
something that was fairly easily replaceable in the event of damage as they
are right below the doors. Wood and fabric is what I had on my original
bungee gear and it seemed to work fine.
Lowell
Sent: Thursday, March 31, 2011 8:38 AM
Subject: Re: Wood Fairings
Dick,
http://forums.matronics.com/viewtopic.php?p=335581#335581
kerrjohna(at)comcast.net
PostPosted: Thu Mar 31, 2011 9:43 am    Post subject: Wood Fairings Reply with quote
MIght be a little heavier, but is easy to work with, but I am pleased with the result of PVC lift strut fairings from Kitfox LLC. Snaps on, holds position with LTV and can be covered/painted, etc.
John Kerr
rawheels
PostPosted: Sat Apr 16, 2011 7:11 am    Post subject: Re: Wood Fairings Reply with quote
Just wanted to give a quick user report.
Airdale does carry the wood streamlined strips (at) $2/ft. Brett was very easy to work with, and the test pieces I ordered were delivered quickly.
I've attached some photos of the product. There are a few observations that probably need to be pointed out about them if someone else is looking at ordering some for their project.
1. As shown in the photos, the shape of the pieces aren't really "streamlined"; your buying a 1x2 with a couple of angled table saw cuts and a pass across a router. So, don't expect a lot for the low price.
2. The piece feels pretty heavy (at) 1.2 lbs for a 3' section (I'm assuming it is pine). This might hold up better on the back edge of my landing gear, but that could add up if you were doing struts. With Balsa (at) ~$18 for a 2x4x36 board from ACS, you could make some lighter ones for about the same price if you have the tools already.
3. The strips will make the tubes more streamlined, but they fall short of the desired 4:1 teardrop shape. When attached to a 1" tube the overall length is a little shorter than 2.75". That is about the same size as on my old landing gear, and will work for my purpose, but may not be desirable for others.
Ryan
 Filesize:  20.85 KB
 Viewed:  13621 Time(s)
 Filesize:  27.65 KB
 Filesize:  36.84 KB
Kitfox IV-1200
Indianapolis, IN
Pat Reilly
PostPosted: Sat Apr 16, 2011 7:34 am    Post subject: Wood Fairings Reply with quote
Kitfoxers, Try western red cedar, It's lighter than pine (not balsa wood light), readily available in tapered cross section as beveled cedar siding, easy to machine, and reasonably priced. If you haven't got a table or bench saw and hand plane to finish it up, you probably belong in a certified airplane.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Sat, Apr 16, 2011 at 10:11 AM, rawheels <rawheels(at)yahoo.com (rawheels(at)yahoo.com)> wrote:
--> Kitfox-List message posted by: "rawheels" <rawheels(at)yahoo.com (rawheels(at)yahoo.com)>
Ryan
Ryan Wheeler
Kitfox IV-1200
Indianapolis, IN
http://forums.matronics.com/viewtopic.php?p=337130#337130
http://forums.matronics.com//files/img00072_20110415_1025_210.jpg
http://forums.matronics.com//files/img00070_20110415_1024_206.jpg
http://forums.matronics.com//files/img00069_20110415_1=======================
y Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Kitfox-List" target="_blank">http:=====
http://forums.mle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
7suds(at)Chartermi.net
PostPosted: Sat Apr 16, 2011 10:37 am    Post subject: Wood Fairings Reply with quote
Guys,
I looked at streamlining my horizontal stab and wing jury struts with balsa and ordered some from National Balsa, link below. Have the plastic on my wing struts and left it there for now. I have not done anything with the balsa I bought yet, moved my focus to getting the plane in the air first. My thought was to glue and contour then cover with single layer carbon fiber or fiberglass.
Lloyd C
Northern Mi.
KF 5 912ul IVO IFA
http://www.specializedbalsa.com/products2/lead_trail_aileron.php#TE
http://www.nationalbalsa.com/Balsa_Trailing_Edge_s/62.htm
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Patrick Reilly
Sent: Saturday, April 16, 2011 10:27 AM
Subject: Re: Re: Wood Fairings
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Ryan
Ryan Wheeler
Kitfox IV-1200
Indianapolis, IN
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
[/url][url=http://forums.matronics.com/][/url][url=http://forums.matronics.com/][/url][url=http://forums.matronics.com/][b][u]http://www.matronics.com/Navigator?Kitfox-List
n61kf
PostPosted: Sun Apr 17, 2011 3:49 am    Post subject: Re: Wood Fairings Reply with quote
This light weight plastic fairing might be worth looking into. It would have to be split in order to install on our struts, then foam filled.
http://www.streamline.8k.com/
Keith Schneider
Red Stewart Airfield
Waynesville Ohio
KF IV 912ul
