lcfitt(at)sbcglobal.net Guest
Posted: Fri Apr 15, 2011 11:24 am Post subject: Gascolator |
Lynn tripped me up when I mentioned 45° AN hardware in an earlier post. What got me going on that was a bit of web research on the correct angle as I had forgotten. The reason I mention it is that in my searching, I found that there are 45° AN flared fittings. Don't know how common or where to get them but the article was about knowing what you have. I simply took the 50/50 guess as to which flare angle is ours and lost again. There is an Indian casino close by, now everyone should know why I have never been there - enough drain on the bank account already finishing up another Model IV.
Lowell
Sent: Friday, April 15, 2011 11:57 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Re: Re: Gascolator
On 4/15/2011 10:35 AM, Lynn Matteson wrote: | Quote: | | Has some rebel out there tried to use a 45° flare on an *experimental* aircraft?.....hint: notice the word experimental. I realize that if you have an "real" aircraft part with a 37° flare on it, you have to match it, but otherwise what is sacred about 37°? (other than selling us a special tool) |
Lynn,
What is sacred about 37 degrees is matching AN hardware, nothing else. 45 degrees for plumbing hardware, 37 for AN. What happens if you mix is mostly that they leak. What happens if you decide to honk on it and form fit the flare depends on the tubing you're using. If T6 then you'll probably just bust up the seats and threads. If T0, then you'll probably modify the flare to fit. Nothing sacred about AN hardware except that it's a good bit lighter than brass, is stronger than plastic, and looks cool. (Most important.)
Guy Buchanan
Scoutmaster – Troop 680
760.809.6145
scoutmaster(at)troop680.org (scoutmaster(at)troop680.org)
www.troop680.org
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Lynn Matteson
Posted: Fri Apr 15, 2011 12:26 pm Post subject: Gascolator |
I'm gonna take a WAG here and that is that the 37° for aircraft is
because that is a less dramatic flare than a 45°, therefore less apt
to split the harder grades of metals being flared. Anybody know the
history of the 37 versus 45? Somebody must have come up with a pretty
good reason to make a change, eh?
And, Guy, I would not suggest mixing the two in any one joint, but
I'd be rebel enough to use both angles of flares at different
locations on the same experimental airplane....clearly marked, of
course.
Lynn Matteson
Jabiru 2200, #2062
Prince prop (64 x 30, P-tip)
Rotec TBI-40 injection (sleeved to 35mm)
Status: flying...1096 hrs (since 3-27-2006)
On Apr 15, 2011, at 3:19 PM, Lowell Fitt wrote:
| Quote: | Lynn tripped me up when I mentioned 45° AN hardware in an earlier
another Model IV.
Lowell
Lynn,
Guy Buchanan
760.809.6145
www.troop680.org
forums.matronics.comhref="http://www.matronics.com/
contribution">http://www.matronics.com/c_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
kirkhull(at)kc.rr.com Guest
Posted: Fri Apr 15, 2011 12:44 pm Post subject: Gascolator |
That’s easy 37 is aircraft specific so they can charge you more it.
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Fri Apr 15, 2011 6:28 pm Post subject: Re: Gascolator |
Well for 40 bucks I can bite that bullet, I am getting a little tired of the $100 bullets. The tool is on it's way.
As for the 37 vs 45 thing, my guess is that it is fractional. I agree that it was to have less deformation to the point of damage. I bet they were discussing it and someone said, lets reduce the angle by a sixth. Arbitrary enough. 5/6 * 45 = 37.5
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Float Flyr
Posted: Sat Apr 16, 2011 5:03 am Post subject: Gascolator |
Lynn:
37deg allows more sealing surface for the same outside diameter flare. As
you know it is easy to stretch metal but putting it back is like adding an
inch tot he 2x4 you just cut too short, next to impossible. If you put a 45
deg flare on a 37 deg fitting the flare will have to crumple a bit to seat.
The crumpling will cause it to leak under low pressure. That was one of the
things demonstrated to us in AME school. (AME = Aircraft Maintenance
Engineer)
Trying to put a 37 degree flare on a 45 degree fitting is almost as bad as
the seat again is reduced inside the fitting.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Sat Apr 16, 2011 5:11 am Post subject: Gascolator |
Don’t feel too bad Lowell... I had to look it up too.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Lowell Fitt
Sent: April 15, 2011 4:50 PM
Lowell
Lynn,
Guy Buchanan
760.809.6145
www.troop680.org
| Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c&nbsUse the Matronics List Features Navigator to & Download, 7-Day Browse, Chat, --> http://www.matron===================http://forums.matronics.com - List Contribution Web Site -Matt Dralle, href="http://www.matronics.com/contribution">http://www.matronics.com/c=[/b] |
Kitfox III-A
Float Flyr
Posted: Sat Apr 16, 2011 5:13 am Post subject: Gascolator |
Apparently some racing cars also use the 37 degree flare.
I guess they spend money too.
Noel
Kitfox III-A
Float Flyr
Posted: Sat Apr 16, 2011 5:34 am Post subject: Gascolator |
We used to do things like the flare on a regular basis... The work at the FBO (in Canada AMO) was all contract work and billing out a flare would have been phohibitive. We did certainly charge for anything we had to sign on though and it never ceased to amaze me that a fellow would think nothing of spending $1000.00 on an old truck but balk at a $500 bill on his $250,000 plane.... go figure.
Commercial contracts were always better than private. Commercial operators want their planes to be safe... That doesn’t mean they want to throw money at the plane but they relaize flying is expensive and they past the cost on to their customers.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of bob noffs
Sent: April 15, 2011 7:54 PM
at the field where i hangar the fbo charges $45/hr. he says that he can't even often do that or he will not get repeat business and he is very good.the shops around me charge $90 for snowmobile work and $100/hr for outboards. i can't ever imagine, under any circumstances asking the fbo to perform his profession for me without pay. this is what he does to keep the lights on at home, i just do it for fun.
bob noffs
On Fri, Apr 15, 2011 at 9:51 AM, Noel Loveys <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)> wrote:
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)>
While it may be next to impossible to borrow one of these tools if you bring
the pieces to an FBO they will probably do the flares for you for a
reasonable price... maybe even free.
Noel
Kitfox III-A
Tom Jones
Posted: Sat Apr 16, 2011 6:14 am Post subject: Re: Gascolator |
Here's a link to "Hints for Homebuilders" short video on using the high dollar 37.5 flare tool. You can see why it is expensive. This is the tool the local FBO mechanic let me use in his shop and showed me how to use it.
http://bcove.me/1y8pfd94
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Sun Apr 17, 2011 5:14 am Post subject: Gascolator |
Understood, Noel, but I wasn't advocating mixing a 37 and a 45 in the
same joint....I was merely wondering why did the aircraft industry
adopt the 37° flare, and what is sacred about it?
Obviously, the automotive industry has managed to save a few lives
using a 45° flare for a couple of years in their brake lines. etc.
Not getting any answer that satisfied me, I went looking, and found
this:
Background
AN stands for "Air Force-Navy Aeronautical Standard" and was an
aviation fitting standard developed around WWII. The fitting featured
a 37 degree mating angle which provided superior sealing compared to
the common 45 degree fittings. The fittings also utilized a higher
class of thread quality. Eventually the AN fittings saw widespread
military use and a multiple manufacturers began producing the
fittings, leading to quality problems. The Joint Industries Council
(JIC), an industry organization, sought to standardize the
specifications on this type of fitting and created the "JIC" fitting
standard, a 37 degree fitting with a slightly lower class of thread
quality than the military AN version. The SAE went on to adopt the
JIC standard as well. As a result JIC or SAE 37 degree fittings are
perfectly interchangeable with AN fittings, and while this may not be
acceptable for military aviation use, for automotive use there is no
downside other than perhaps mismatched color coordination as JIC
fittings are not available in the pretty anodize aluminum colors.
However this may be a worthy tradeoff considering the JIC fittings
are a fraction of the price of their true "AN" counterparts. We mixed
and matched in this article to show you their interchangeability.
3 key facts about AN fittings.
Flare angle is 37°, not 45°
Interchangeable with JIC fittings
Divide AN # by 16 to get inches
Apparently some testing was done, and it was determined that the 37°
flare will hold more pressure than the 45° flare...just how much more
pressure wasn't revealed in what I read, but like a lot of other
things, if it's a "little bit better" then the government/military
will adopt it as gospel.
For myself, I'll accept the fact that the 37 holds more pressure, but
will I ever see the need for that pressure in my homebuilt.....when
the highest pressure in my plane is the brake lines, and they are
made of plastic (nylon)?
Just for the record, I use 37° flares for the *2* fittings in my fuel
system that require them...gravity feed fuel line to the Rotec TBI,
subject to...what?....3 pounds of head pressure?
Lynn Matteson
Jabiru 2200, #2062
On Apr 16, 2011, at 8:58 AM, Noel Loveys wrote:
Lynn:
flare. As
adding an
put a 45
to seat.
one of the
Engineer)
bad as
Noel
62 Bytes |
10146 Time(s) |
62 Bytes |
10146 Time(s) |
62 Bytes |
10146 Time(s) |
N369LM |
Float Flyr
Posted: Sun Apr 17, 2011 6:23 am Post subject: Gascolator |
The reason I suspect outside of having more sealing surface, is what you
mentioned about not stretching the tubing as far and therefore not as
susceptible to cracking.
I also noticed the 45 degree pipe flare doesn't use or at least I haven't
seen one use a sleeve inside the B-Nut.
Noel
Kitfox III-A
mikeperkins
Posted: Sun Apr 17, 2011 6:40 am Post subject: Re: Gascolator |
Here are some inexpensive 37.5 degree flaring tools:
$55 - http://www.speedwaymotors.com/Standard-Flaring-Tool-37-Degree-AN,2931.html
$40 - http://www.amazon.com/Ridgid-23332-Flaring-Tool/dp/B000X4K9KO/ref=pd_bxgy_hi_img_a
$16 - http://www.amazon.com/Great-Neck-Degree-Flaring-Tool/dp/B004FEJF2Q
I have one similar to the $16 version and it's worked well over the years. Deburr the tubing end, apply a little grease, then flare.
- Mike
Model I w/532
Pat Reilly
Posted: Sun Apr 17, 2011 7:35 am Post subject: Gascolator |
Mike, I have 2 cheap 45 degree flaring tools one that will do double flares. I knew there had to be a similar inexpensive 37 degree tool. Thanks for the source. I ordered the Great Neck model just to have on hand at that price. Maybe I should have ordered the double flare model. Any of you guys use a double flare?
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Sun, Apr 17, 2011 at 9:40 AM, mikeperkins <michael.perkins(at)rauland.com (michael.perkins(at)rauland.com)> wrote:
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
