seeping header shutoff valve
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
larry(at)macsmachine.com
PostPosted: Thu Apr 14, 2011 6:08 pm    Post subject: seeping header shutoff valve Reply with quote
Hi Guys,
This past month an experimental burned up in a t-hangar in Davenport. The suspected reason was a milk house heater setup that was running on and off and that he had a leaking fuel system. The 182 in the adjoining hangar and a boat in the other were both burned. The 182 was written off as totaled. The fuselage exploded and the heat caused the beams above to sag a little. Worst of it all was that he had no insurance. None!
Anyway, I realized my heater system was the same as his and my cockpit had that familiar smell too, so I put my finger around the shutoff fittings and it was damp. It’s the automotive brass cone type with springs that keep it tight for a year or two. This one was the second I’d replaced, so I went to the hardware store and bought a ball valve type with a yellow handle denoting the gas, oil and water compatibility. It took a little while to drain the tank and get the fittings arranged to keep from re-plumbing everything and using a piece of the shutoff without the handle. A slight mod to the valve handle took care of the job.
If you’re using one of these brass fitting, take a look at it! The ball valve types are a much safer bet.
http://www.macsmachine.com/images/controllinkages/full/fuelshutoff2.gif
This week there’s no smell and it’s dry in there.
I’m flying again with great weather and looking forward to more. Endorphins are up again.
Do fly safe,
Larry McFarland at www.macsmachine.com
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
