Tire pressure
Goto page 1, 2  Next
Pat Reilly
PostPosted: Sun Apr 10, 2011 4:14 pm    Post subject: Tire pressure Reply with quote
Kitfoxers, I have Lowell Fitt's bush gear with Nanco 21"x12"x8" tires on aluminum rims with tubes. What tire pressure should I run? The bush gear is tough, but those die springs are stiff with very little travel. I'd like to get as much added suspension out of the tires as possible without spinning a tire on the rim.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Paul A. Franz, P.E.
PostPosted: Sun Apr 10, 2011 5:39 pm    Post subject: Tire pressure Reply with quote
tire on the rim.
Tires that big are for landing in rough stuff. To get the most out of that you want
the pressure as low as possible. Probably air them with no weight on the tires to 15
to 20 psi when the tires are warm. Then after they sit for a while and stretch out
with that high pressure in them, let out all the air and immediately put the valves
back in. That should be about right. If you find that they slip loose from the rims,
add just a little air. Probably less than 3 psi. There is some compromise here, with
that low pressure you shorten your landing roll and can take harder hits from the
rocks and other bumps but you will also lengthen your takeoff roll, especially on
pavement.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
Office 425.440.9505
425.241.1618 Cell
In general, the art of government consists of taking as much money as possible from
one party of the citizens to give to the other.
-- Voltaire (1764)
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
WurlyBird
PostPosted: Sun Apr 10, 2011 6:18 pm    Post subject: Re: Tire pressure Reply with quote
I have the Nanco tires as well and have found that about 8 lbs indicated on my dial is working good as a compromise for taking off on asphalt and then landing wherever. My issue is I have not been able to find a good pressure gauge for this range. Any one have a good suggestion of where to find a gauge the is indicating clearly between 0 and 10 lbs?
James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl.
Flydad57(at)neo.rr.com
PostPosted: Sun Apr 10, 2011 7:04 pm    Post subject: Tire pressure Reply with quote
Your local off-road motorcycle dealer should have such a gauge. ATV tires
are often inflated to less than 10 pounds.
Bob Taylor
TigerCub N657RT
From: "WurlyBird" <james.t.trizzino(at)us.army.mil>
Sent: Sunday, April 10, 2011 10:18 PM
Subject: Re: Tire pressure
James
Kitfox 3 / 582 / 70&quot; IVO 2 blade GA
50 hrs on the Fox in between deployments,
now she lies in wait
http://forums.matronics.com/viewtopic.php?p=336589#336589
thesupe(at)hotmail.com
PostPosted: Sun Apr 10, 2011 7:35 pm    Post subject: Tire pressure Reply with quote
I've had a set of these tires on my Avid MK IV and found that if I tried to run them at much less than 8 lbs, they would leak around the bead.  I ended up putting tubes in them to overcome this, but had one tire spin on the rim on blacktop runway and it cut the valve stem off the tube.  I've heard there is some type of bead sealer the 4 wheeler guys use for running tires at low pressure, but have never used it myself.  Take care,  Jim Chuk   Avid MK IV (flying0  Kitfox 4 (building)  Northern Mn
> From: Flydad57(at)neo.rr.com
Subject: Re: Re: Tire pressure
Date: Sun, 10 Apr 2011 23:01:59 -0400
--> Kitfox-List message posted by: "Robert Taylor" <Flydad57(at)neo.rr.com>
Bob Taylor
TigerCub N657RT
> --> Kitfox-List message posted by: "WurlyBird"
> James
[quote] _=====
Dick Maddux
PostPosted: Mon Apr 11, 2011 4:25 am    Post subject: Tire pressure Reply with quote
Pat,
I have the same gear/tires that you do and having been running 10 lbs of air pressure in them for well over a year. That appears to be a good pressure. Get it too low and you might have a possibility of tire movement on the rim thus shearing the inflation stem.
      Dick Maddux
      Milton,Fl
 Filesize:  386.4 KB
 Viewed:  20982 Time(s)
Pat Reilly
PostPosted: Mon Apr 11, 2011 5:13 am    Post subject: Tire pressure Reply with quote
James, I have a low pressure gage. Not sure where I got it, but I got it when racing dirt bikes. Try a dirt bike parts supplier, maybe Dennis Kirk in MN. or a local shop.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Sun, Apr 10, 2011 at 9:18 PM, WurlyBird <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)> wrote:
--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
James
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
malpass
PostPosted: Mon Apr 11, 2011 8:08 am    Post subject: tire pressure Reply with quote
My 2 cents worth on tire pressures..............
I have a model III with a 582. When I was learning how to ground manuever this plane, I went through 3- high hour instructors, and they all said this was the toughest plane to take off and land that they had ever experienced. I had to put in 32 hours on grass before I felt I could advance to hard surface. I already had 150 hours on ultralights. One thing I found, was I was using too much pressure (about 20 lbs). I does make it easier to roll on the ground though.
I then started to experiment with was tire pressure. I found the plane was the least squirrley on the ground with 9 pounds of air. Not 10 but 9 ! The one pound made the difference. I have the Grove gear on my Kitfox. The tires may in fact slip on the wheels. If the wheel seat is good and clean you shouldnt loose any air. You can buy tubes that have locking stems so that the stems wont get sheared off. I may get those if I see my tire pressure going down too often. Go to a lawnmower repair shop or recreational vehicle place to get the tubes.
Try that and see what you think.
Bill Malpass N793RK
Model III 582 with grove gear and wheel pants.
kitfox III w/ 582 greyhead
Pat Reilly
PostPosted: Mon Apr 11, 2011 3:14 pm    Post subject: tire pressure Reply with quote
Kitfoxers, Well after all the advice on tire pressure, remember I am running the Nanco 21"x12"x8'' rim, Fitt's bush gear, 582, 628# empty, mod 3. I reduced my tire pressure to 5 1/2 # today and took off of grass and landed in a bean field. My instructor, with me since it has been 5 months since I have flown, commented on how much suspension the tires provided, and asked how much pressure I carried. He is a Luscomb pilot and not familiar with the high flotation low presssure tires. He was surprised when I told him 6 pounds and that was a little higher than the 3 to 4 pounds some of the tundra tire drivers use. Anyway I was happy today with the 5 1/2 #.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Mon, Apr 11, 2011 at 11:05 AM, Bill Malpass <malpass-architect(at)att.net (malpass-architect(at)att.net)> wrote:
I then started to
Bill Malpass  N793RK
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Pat Reilly
PostPosted: Mon Apr 11, 2011 3:44 pm    Post subject: Tire pressure Reply with quote
Dick, I am on the grass and dirt and used 5 1/2 # today successfully. I will increase the pressure to 9 or 10 pounds if I am going to land on a paved runway to avoid spinning a tire on the rim. Thanks for the advice.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Mon, Apr 11, 2011 at 7:19 AM, <Catz631(at)aol.com (Catz631(at)aol.com)> wrote:
Pat,
                                              Dick Maddux
                                              Milton,Fl
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Paul A. Franz, P.E.
PostPosted: Mon Apr 11, 2011 7:40 pm    Post subject: Tire pressure Reply with quote
I have a couple of thoughts on this.
1) Are rim locks like the ones used on motocross bikes feasible and available?
2) The maximum possible braking effort is reduced with larger diameter tires compared
to the same brakes with smaller diameter tires. If the wheels are also larger, then
the shear stress is reduced (the stress that causes the tire to slip on the wheel) so
this would also contribute to a lower tire pressure required.
3) Isn't it true that the biggest risk of slipping the tire on the wheel is hard
braking on a surface the tire can't slide on? And aren't runways that are paved mostly
so long you don't need to use the brakes at all?
4) I accidentally deleted the e-mail but didn't someone suggest some kind of an
available guard so that the inner tube can't slip or something protects the valve stem
from shearing off?
5) I assume that large low pressure tires require innertubes.
Paul A. Franz
Bellevue WA
Office 425.440.9505
425.241.1618 Cell
-- Voltaire (1764)
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
Dick Maddux
PostPosted: Tue Apr 12, 2011 4:03 am    Post subject: Tire pressure Reply with quote
Paul and Pat,
I operate off of grass and pavement. I find it easier to turn on the grass with a little more air pressure (ie;aprox 10 lbs)
My tires were installed on the rims with rim adhesive which helps hold the tires to the rims and help to prevent air loss,although I still have to top up from time to time.
Prior posts on this site (about a year ago) had mentioned shearing of the inflation valve with movement of the tire on the rim and that is why I use 10 lbs of pressure ,as recommended by the posters. This has worked well for me.
    Dick Maddux
    Milton,Fl
jack(at)comconn.com
PostPosted: Tue Apr 12, 2011 4:35 am    Post subject: tire pressure Reply with quote
I did all of my training in a Kitfox I on pavement.
I did find that lower tire pressure made a world of difference
in landings, and I also wore out a set of tires fairly
quickly. I found replacement carlisle tires at the local
tractor supply, and had them mounted at a lawnmower
repair shop.
The original builder of the plane had drilled the lip of the rim
and used a short, maybe #12 stainless metal screw in three places,
which ran into, not through, the bead of the tire. Rather than
explain, I took the screws out before having the tire mounted,
and put them back in myself. Never spun the tire, even when
I landed with a flat (I hate mesquite thorns!).
And, yes, I always run tubes.
-Jack
Austin, TX
Avid MK IV, Jabiru 22AX01 (flying)
Avid Catalina Hirth F30 (building)
Time: 08:40:12 PM PST US
From: "Paul Franz - Merlin GT" <paul(at)eucleides.com>
then
so
mostly
stem
from shearing off?
Paul A. Franz
Bellevue WA
Office 425.440.9505
425.241.1618 Cell
Pat Reilly
PostPosted: Tue Apr 12, 2011 3:25 pm    Post subject: tire pressure Reply with quote
Jack, I was considering putting screws in the bead. I have seen that done on dirt bikes. I will do it to my Nanco tires. Wonder if I can do it with out dismounting the tire. I guess it would be easy to stop short of drilling all the way thru and run a sheet metal screw in. You didn't state what pressure you ran in the tires.
Pat Reilly
Mod 3 582 Rebuilt.
Rockford,IL
On Tue, Apr 12, 2011 at 7:29 AM, Jack L Bell <jack(at)comconn.com (jack(at)comconn.com)> wrote:
--> Kitfox-List message posted by: Jack L Bell <jack(at)comconn.com (jack(at)comconn.com)>
repair shop.
-Jack
Austin, TX
From: "Paul Franz - Merlin GT" <paul(at)eucleides.com (paul(at)eucleides.com)>
then
> so
> mostly
> stem
from shearing off?
Paul A. Franz
> Bellevue WA
Office [url=tel:425.440.9505]425.440.9505[/url]
[url=tel:425.241.1618]425.241.1618[/url] Cell
as List Un/Subscription,
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Pat Reilly
PostPosted: Tue Apr 12, 2011 3:36 pm    Post subject: Tire pressure Reply with quote
Paul, IIt appears all of your suppositions are correct. I think the tube valves can be ripped off no matter what precautions you take if the tire spins on the rim. Thanks for reminding me that the braking force the brakes exert is less with the larger tires. My brakes work fine, but they would be more powerful with smaller tires. Rim locks that are used on dirt bikes could work. But, screws thru the rim into the bead are as effective and much easier to install.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Mon, Apr 11, 2011 at 10:36 PM, Paul Franz - Merlin GT <paul(at)eucleides.com (paul(at)eucleides.com)> wrote:
--> Kitfox-List message posted by: "Paul Franz - Merlin GT" <paul(at)eucleides.com (paul(at)eucleides.com)>
from shearing off?
Paul A. Franz
Bellevue WA
-- Volta=================
y Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Kitfox-List" target="_blank">http:=====
http://forums.mle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Paul A. Franz, P.E.
PostPosted: Tue Apr 12, 2011 3:58 pm    Post subject: tire pressure Reply with quote
Pat,
I think that is a great idea. I'm kind of a perfectionist or worrier depending on your
perspective but I would dismount the tire before drilling the wheel so you can measure
and judge where the best place would be for the screws to penetrate the tire bead.
Then I would *NOT* drill a pilot hole into the tire. Here's my thinking. Drilling will
remove material and possibly damage connective fibers whereas sinking a sheet metal
screw no more than 3/4ths of the depth of the tire bead will make it tighter on the
screw and hopefully spread the fibers, not cut them.
Of course, this is my judgement and perception, not based on any actual experience.
Paul A. Franz
Bellevue WA
Office 425.440.9505
425.241.1618 Cell
-- Voltaire (1764)
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
Pat Reilly
PostPosted: Tue Apr 12, 2011 4:15 pm    Post subject: tire pressure Reply with quote
Paul, I bet I can do it with the tire on the rim. I won't drill all the way thru the rim. I'll stop short of hitting the tire and run a sheet metal screw thru whats left of the aluminum rim. It would be nice to see how thick the bead is to choose what length of screw to use. I would guess 1/2" # 10 sheet metal screw would do it. I just remembered I did this on a dirt bile years ago. But, I had drilled and measured the bead before mounting the tire.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Tue, Apr 12, 2011 at 6:55 PM, Paul Franz - Merlin GT <paul(at)eucleides.com (paul(at)eucleides.com)> wrote:
Pat,
Paul A. Franz
Bellevue WA
-- Voltaire (1764)
Subscription,
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Paul A. Franz, P.E.
PostPosted: Tue Apr 12, 2011 4:58 pm    Post subject: tire pressure Reply with quote
tire.
I'm a bit more patient in my old age having been beat up so many times by short cut
decisions. I would want the best hole location and to know exactly how thick the rim
is and the thickness of the bead at the point where the screw penetrates. Of course,
you may already know that information from working with the tires and wheels.
Paul A. Franz
Bellevue WA
Office 425.440.9505
425.241.1618 Cell
-- Voltaire (1764)
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
dave
PostPosted: Tue Apr 12, 2011 5:24 pm    Post subject: Re: Tire pressure Reply with quote
5 1/2 " likely a bit low if your guage accurate but it ands nice extra softness to take out the bumps. You plane will feel quite a bit differnt on pavement than on grass. Grass a lot more forgiving.
If you use tubes -even more worry of tearing off a valve stem. With no tubes the tires might slip but you will un-likely be able to get the bead to break-- These Atv wheels hold them quite well.
btw - anyone got a set of wheels for sale with brakes?
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Dwayne
PostPosted: Tue Apr 12, 2011 9:12 pm    Post subject: tire pressure Reply with quote
HELLLLLLOOOOOOO? Did anyone see my initial post?
--- On Wed, 4/13/11, Paul Franz - Merlin GT <paul(at)eucleides.com> wrote:
From: Paul Franz - Merlin GT <paul(at)eucleides.com>
Subject: Re: tire pressure
Date: Wednesday, April 13, 2011, 12:56 AM
tire.
Paul A. Franz
Bellevue WA
Office 425.440.9505
425.241.1618 Cell
one party of f="http://www.matronics.com/Navigator?Kitfox-List" --> http:========================
Goto page 1, 2  Next
Page 1 of 2
