CJ6 Shimmy damper problems
CJ6XXK
PostPosted: Sat Mar 26, 2011 7:35 pm    Post subject: CJ6 Shimmy damper problems Reply with quote
I just done some high speed taxi runs in my cj6 today and have a few problems.
First thing is that i raise the the nose of the plane then put it down again and i have got massive amounts of shimmy.
This was a brand new shimmy damper i bought and fitted as well.
Is there a special way to set them up?
Thanks Daniel
dsavarese0812(at)bellsout
PostPosted: Sun Mar 27, 2011 6:50 pm    Post subject: CJ6 Shimmy damper problems Reply with quote
You may also have an out of balance nose wheel tire and wheel. Very
common problem.
Dennis
Thanks Daniel
http://forums.matronics.com/viewtopic.php?p=335149#335149
cjpilot710(at)aol.com
PostPosted: Sun Mar 27, 2011 8:39 pm    Post subject: CJ6 Shimmy damper problems Reply with quote
Not only out of balance but if the scissors is loose at all you'll get the same thing. There can not be any play in the bolts that are part of the scissor assembly.
Jim "Pappy" Goolsby
In a message dated 3/27/2011 10:51:58 P.M. Eastern Daylight Time, dsavarese0812(at)bellsouth.net writes:
--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
common problem.
Dennis
--> Yak-List message posted by: "CJ6XXK"<Danielt_355(at)hotmail.com>
Thanks Daniel
&gt========================e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
PostPosted: Mon Mar 28, 2011 4:01 am    Post subject: CJ6 Shimmy damper problems Reply with quote
Very true Pappy. He should jack the nose up and try to move the nose
wheel assembly side to side and fore and aft to see if there is any play
in the bushings and bolts.
Dennis
Jim "Pappy" Goolsby
common problem.
Dennis
few problems.
> Thanks Daniel
Noplugs
PostPosted: Mon Mar 28, 2011 9:51 am    Post subject: Re: CJ6 Shimmy damper problems Reply with quote
A friend of mine had the same problem on his CJ after he installed a US wheel and tire mod. His first thought was the new mod was the problem and looked at everything that the mod would cause the shimmy. Well to make the long story short I told him to look at the shimmy dampener. He was skeptical because how could it go bad in one flight. Well he took off the dampener, opened it up and found the oil watery and dirty (His words to describe a light weight oil) and it was not full of oil. He cleaned and re-serviced the unit reinstalled it and the shimmy was gone. So my advice is to look at dampener, it does all the work so it would be the weakest link in this issue.
barryhancock
PostPosted: Sat Apr 09, 2011 8:55 am    Post subject: Re: CJ6 Shimmy damper problems Reply with quote
Guys, a common culprit of nose wheel shimmy on the CJ is improper pressure in the nose wheel strut. Check to make sure you have proper pressure there (I'm on the road and don't recall the number). But a 200 lb. guy hanging from the prop should be able to deflect the strut about 2-3"....
Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com
Vic
PostPosted: Sat Apr 09, 2011 4:42 pm    Post subject: Re: CJ6 Shimmy damper problems Reply with quote
Hello,
the shimmy damper is only fighting the real problem. That is considerable unbalance and run out of the rim. You can not fix run out after manufacture of the wheel. But you can do a lot more to balance the wheels by adding lead weights to the rims. With the main wheels you can put stick-on weights inside the rim - see photo. With the nose wheel there is less scope for that. But I would pour lead into the cavity opposite the valve, let it cool, then take it out, clean and degrease the weight and rim cavity and glue it in with silicone. The unbalance is mainly caused by the valve and rubber block of the inner tube. In fact this can be more than 150 grams/ 5 ounces. You would definitely not accept that on your car.
Cheers
Vic
 Filesize:  354.02 KB
 Viewed:  8442 Time(s)
 Filesize:  387.08 KB
 Filesize:  381.95 KB
