Cont: annual on Tiger
teamgrumman(at)yahoo.com
PostPosted: Sun Mar 13, 2011 11:41 am    Post subject: Cont: annual on Tiger Reply with quote
During the initial look around I noticed the grounding straps were not installed. Once the cowling came off and I started going though things, I found them. One on each side. However, the paint on the engine mount wasn't removed. Good thing really.
ALSO, notice the primer line. It was installed backward. The fitting on the back where the input line goes was cocked over to the side. The input line is broken off. Once the primer line was turned around, things fit a lot better
 Filesize:  64.16 KB
 Viewed:  6752 Time(s)
 Filesize:  40.99 KB
A home made nose gear boot with a zipper down the back side.
 Filesize:  55.26 KB
PostPosted: Sun Mar 13, 2011 11:42 am    Post subject: Cont: annual on Tiger Reply with quote
Someone took the time to patch a hole in the heat muffler. BUT, they didn't remove the screw that was too long.
 Filesize:  61.6 KB
flyv35b(at)minetfiber.com
PostPosted: Mon Mar 14, 2011 5:13 am    Post subject: Cont: annual on Tiger Reply with quote
The idea has some merit. Even splitting the boot part way back from the
strut, enough so you could easily pull it down to the fairing and around
the strut V-fairing would help getting the cowl on and off. You could
glue and sew two pieces of Velcro on to the rubber possibly, or maybe a
couple of snaps.
Cliff
PostPosted: Mon Mar 14, 2011 8:50 am    Post subject: Cont: annual on Tiger Reply with quote
How about replacing the boot with an STCd fiberglass piece that resembles . . . .
Sent: Mon, March 14, 2011 6:10:36 AM
Subject: Re: Cont: annual on Tiger
 Filesize:  41.48 KB
 Viewed:  6738 Time(s)
jamey
PostPosted: Mon Mar 14, 2011 10:11 am    Post subject: Cont: annual on Tiger Reply with quote
But that won’t catch all your loose parts and bits of safety wireL
Jamey
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary Vogt
Sent: Monday, March 14, 2011 9:45 AM
Checked by AVG - www.avg.com
Version: 10.0.1204 / 03/14/11
PostPosted: Mon Mar 14, 2011 11:40 am    Post subject: Cont: annual on Tiger Reply with quote
resembles . . . .
*To:* teamgrumman-list(at)matronics.com
*Sent:* Mon, March 14, 2011 6:10:36 AM
*Subject:* Re: Cont: annual on Tiger
You talking about a separate fairing what would attach to the bottom of
the cowling via a flange and nutplcates inside the cowling?
PostPosted: Mon Mar 14, 2011 5:23 pm    Post subject: Cont: annual on Tiger Reply with quote
the cowling via a flange and nutplates inside the cowling?
Yes. But, it won't need to come off.
Sent: Mon, March 14, 2011 12:37:21 PM
--> TeamGrumman-List message posted by: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
resembles . . . .
*From:* flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
*To:* teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
allenc3(at)bellsouth.net
PostPosted: Mon Mar 14, 2011 5:36 pm    Post subject: Cont: annual on Tiger Reply with quote
Claude Allen
On Mar 14, 2011, at 9:18 PM, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote]You talking about a separate fairing what would attach to the bottom of
From: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
To: [url=mailto:teamgrumman-list(at)matronics.com]teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)[/url]
--> TeamGrumman-List message posted by: flyv35b <[url=mailto:flyv35b(at)minetfiber.com]flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)[/url]>
resembles . . . .
*From:* flyv35b <[url=mailto:flyv35b(at)minetfiber.com]flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)[/url]>
*To:* [url=mailto:teamgrumman-list(at)matronics.com]teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)[/url]
t">http://www.matronics.com/Navigator?TeamGrumman-List
ums.matronics.com">http://forums.matronics.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
