ron.mcgann(at)baesystems. Guest
Posted: Sun May 07, 2006 3:41 pm Post subject: Aileron Pushrod Assemblies |
Howdy all,
I was working the aileron pushrod assemblies yesterday. Figure 2 of 39-2 indicates an F-1064 length of 12 5/8". The supplied F-1064 in my kit is 13 1/16" (for both pushrods). Interestingly, the supplied F-1065 is 20 1/2", the same as called for in the plans.
When the 30 1/16" F-1064s are used with the 1/2" pushrod sleeves, the total assembly length comes in at 15 1/2", well over the 14 7/8" called for in the plans. If the two pushrod sleeves are removed, the assembly can easily be adjusted to 14 7/8". Photos attached.
Obvious solution is to trim the F-1064s to the correct length. But these are pre drilled and threaded and trimming will also remove some of the thread. I don't know whether there will be sufficient thread depth if trimmed. The other option is to halve the size of the sleeves, or exclude them all together.
Pictures on other web sites (eg Tim O.'s) have the collars included. If the F-1064 length is maintained at 13 1/16", why are the collars required? Have others experienced this problem?
as always, thanks in advance
Ron
187 fuse.
67.87 KB |
330 Time(s) |
61.77 KB |
351 Time(s) |
Tim(at)MyRV10.com Guest
Posted: Sun May 07, 2006 4:38 pm Post subject: Aileron Pushrod Assemblies |
Ron, Wish I could be of more help and tell you if I cut them or not,
but whatever I did, I had them be to the exact plans length, so there
was no fudging involved. I wish I understood what that collar was for
too. My only thought was that it perhaps shields things that could be
rubbed by the threads on the rod end, but that would seem strange that
you'd even have anything that close to the rod ends. Mine are
loose on the part, since the jamb nut is up against the hex piece
holding the rod end tight, so the other collars kind of float free
a bit.
McGANN, Ron wrote:
| Quote: | Howdy all,
Ron
187 fuse.
LarryRosen
Posted: Sun May 07, 2006 5:02 pm Post subject: Aileron Pushrod Assemblies |
I actually got one rod 12 5/8" and one 13 1/16", so I called Vans. They
said they were changing to the longer rod and eliminating the sleeves.
Just put them together with out the sleeves.
Larry Rosen
#356
McGANN, Ron wrote:
Howdy all,
Ron
187 fuse.
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
acs(at)acspropeller.com.a Guest
Posted: Sun May 07, 2006 5:48 pm Post subject: Aileron Pushrod Assemblies |
Hi Ron,
I’m on this section as well.
Mine were the longer rod and no collars (sleeves)
40315
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Monday, 8 May 2006 9:39 AM
Subject: Aileron Pushrod Assemblies
Howdy all,
Ron
187 fuse.
Posted: Mon May 08, 2006 3:21 pm Post subject: Aileron Pushrod Assemblies |
All,
For those yet to hit this point, response from Vans:
"Current DWG 39-5 (Rev 1) shows 1064 13 1/8 for hex rod and overall length 14 7/8. F-1065 is hex rod: 20 1/2 and overall: 22 5/8.
There are no sleeves, just rod-end bearings and jam nuts.
If these lengths of pushrod are in your kit, I would expect DWG 39-5 to show this. Check to see if you have revision 1."
I have rev 0 of the plans. Checked Vans website and there is no rev 1 in the "Service Information/Revisions" Section. Does anyone have a list of the CURRENT drawings by any chance? I wonder how many other drawings are out of date (a good chunk of Sections 26 and 29 I bet!)
Ron
Rick S.
Posted: Mon May 08, 2006 6:39 pm Post subject: Aileron Pushrod Assemblies |
Ron,
My plans are marked 39-5 Rev 1.
As for sections 26 thru 29 revs as per the Vans web listing.
40315
ericmpmail-rv10(at)yahoo. Guest
jesse(at)itecusa.org Guest
Posted: Tue May 09, 2006 4:23 am Post subject: Aileron Pushrod Assemblies |
Kit 40415 came with the teardrop shape already in it. The plans still
showed the rectangle, but the teardrop shape was there. We had to cut the
teardrop in the doubler, but it was already in the spar.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
n8vim(at)arrl.net Guest
Posted: Tue May 09, 2006 6:54 am Post subject: Aileron Pushrod Assemblies |
Kit 40384 (With Wing Main spar assemblies S/N 350) also had the teardrop
in the rear spars, but not on the plans.
-Jim 40384
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
jaybrinkmeyer(at)yahoo.co Guest
Posted: Tue May 09, 2006 6:59 am Post subject: Aileron Pushrod Assemblies |
Does anyone have photos of there modifications?
Jay
The next "challenge" you will find is when aileron
pushrods get installed onto the wing. I suspect that
everyone without a teardrop shaped aperture on the
rear spar will be doing some grinding soon... The
point of the "drop" goes a little into the hinge
itself. You can mount it up and see the clearance
issue right away with the retangular hole that came
stock from Van's. Randy had to widen. I will on kit
40150. Factory plane also has this cut out to a tear
drop shape to prevent rubbing/binding. I snapped a pic
of this awhile ago on the factory plane.
Not sure why this is not a revision from Van's.
Perhaps it has changed on kits beyond mine? I pointed
it out here about 2-3 months ago when I was worried
about the range of travel for autopilots and worked
with Randy to get the numbers for his.
Make sure you have full range of travel without any
rubbing or binding. To check full range to need wings
linked or measure angles. There is only one hard stop
for travel per wing (together they are full stops)
toaster73(at)earthlink.ne Guest
Posted: Tue May 09, 2006 5:51 pm Post subject: Aileron Pushrod Assemblies |
Mine came as teardrop shape but I ordered my wings about a year ago, so I
think it depends on when you ordered your wings not what kit number you
have.
-Chris
#40072
