Bistable relay control
jan_de_jong(at)casema.nl
PostPosted: Tue Mar 08, 2011 9:33 am    Post subject: Bistable relay control Reply with quote
I'm thinking of making a monostable relay type control for bistable
relays (if and when) in one or more (or none) of the following shapes:
- 2 square inches of pcb
- mounted in a DSub DE-9 backshell
- integrated with a Tyco BDS-A contactor plug
Components will be SMD's.
Attached two contemplated variations.
Any and all comments welcome.
Jan de Jong
Tycolatchingswitch.pdf
 Filename:  Tycolatchingswitch.pdf
 Filesize:  60.61 KB
 Downloaded:  1041 Time(s)
latchingswitch.pdf
 Filename:  latchingswitch.pdf
 Filesize:  60.48 KB
 Downloaded:  515 Time(s)
JLuckey(at)pacbell.net
PostPosted: Tue Mar 08, 2011 10:57 am    Post subject: Bistable relay control Reply with quote
Jan,
I'm assuming that you are referring to the Tyco latching relays that were
discussed here a few weeks ago.
That looks like a lot of (pretty cool) engineering, but is it really
necessary? I'm thinking that a SPDT (on)- off - (on) toggle switch is all
that is really req'd to control the Tyco latching relay.
Am I missing something?
PostPosted: Tue Mar 08, 2011 12:51 pm    Post subject: Bistable relay control Reply with quote
Jeff,
You are absolutely right.
It is only when one wants to do more than switch one latching relay on
and off that it is useful for latching relays to behave like monostable
relays.
Say there are several latching relays in a system:
1. Progressive power down may be needed so that a relay has power for
switching off (can also be in a checklist)
2. It may be nice to have a handle position reflect a relay state (can
also be provided with an indicator led)
3. The system requires automation - automation has open/close outputs
and cannot be expected to provide pulses.
Jan de Jong
Jeff Luckey wrote:
Jan,
