Head protection
occom
PostPosted: Sun Mar 06, 2011 1:49 pm    Post subject: Head protection Reply with quote
There were three Kitfox aircraft here locally that I am aware of. There may
be (probably) a couple I am unfamiliar with so far. One (sister to mine) met
with an approach stall I think (it had a very heavy Subaru engine in it)
Details are sketchy because the pilot has no memory of the incident. One
other was destroyed after many hours in a bad float landing, totally pilot
error. The reason I bring these incidents up is that in both cases the pilot
hit their heads quite badly on the cabin structure. This is no criticism,
both pilots survived and one had only minor injury, a major plus for
Kitfoxes IMHO.
The reason I bring it up is to ask if others have padded the tubes above our
heads or if they wear a helmet. I am somewhat tempted to the latter as I
have very little hair and a helmet would provide protection from sun as well
as impact. Anyway, I was thinking about it and watching videos of papilot's
vw Kitfox on YouTube, noticed the pads and got to wondering what others have
done.
Those tubes probably hurt like the dickens and they aren't that far off my
noggin.
Mnflyer
PostPosted: Sun Mar 06, 2011 4:02 pm    Post subject: Re: Head protection Reply with quote
A proper fitting and secured helmet is excellent protection, a proven safety devise, the padding of the tubes will only help with bumping your head while getting in or out the the plane will provide no real protection in the event of a accident. A helmet must fit properly a chin strap and a neck nape strap are needed for full benefits.
GB
MNFlyer
Flying a HKS Kitfox III
Lynn Matteson
PostPosted: Sun Mar 06, 2011 7:34 pm    Post subject: Head protection Reply with quote
One of my test pilots also bumped his head in mine so he suggested
padding, which I did, and just never removed it.
Lynn Matteson
Jabiru 2200, #2062
Prince prop (64 x 30, P-tip)
Rotec TBI-40 injection (sleeved to 35mm)
Status: flying...1083 hrs (since 3-27-2006)
There may
mine) met
in it)
incident. One
totally pilot
the pilot
criticism,
Kitfoxes IMHO.
above our
as I
sun as well
papilot's
others have
done.
off my
noggin.
Lynn
Kitfox IV-Jabiru 2200
N369LM
PMorel
PostPosted: Mon Mar 07, 2011 4:45 am    Post subject: Re: Head protection Reply with quote
This has been a concern of mine too. I went down to my local Home Depot and purchased pipe insulation for tube padding. Works just fine.
 Filesize:  89.86 KB
 Viewed:  7045 Time(s)
Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com
Guy Buchanan
PostPosted: Mon Mar 07, 2011 9:36 am    Post subject: Head protection Reply with quote
Oh yes. I covered the tubes to the side and rear with foam tube
insulation. I've used them many a time, as I fly in any turbulence. The
hard one to protect is the perfectly vertical -1 g bump that raps your
headset band smartly into the skylight. I once saw a Kitfox skylight hit
so hard this way it popped the fasteners along one side and back edge.
I'm getting shorter with age though so maybe this won't be a problem in
the future. Wink
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 592-C / Warp 3cs / 500 hrs. and grounded
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
