BlueSkyFlier
Posted: Fri Mar 04, 2011 4:24 am Post subject: Zero timing a O-240-E engine |
Hi Scott,
You wrote: "The new windshield should be easy. The company that has the molds is Aircraft Windshield Company, 562-430-8108 in the Los Angeles area. What kind of engine do you have?"
Thank you for the windshield info. I shall contact them forthwith.
My engine is a Rolls Royce Continental O-240-E as originally fitted to Cessna FRM-150 Aerobats out of the Reims factory in France.
More info at http://en.wikipedia.org/wiki/Continental_O-240
Does anyone have knowledge of a reliable shop where I can have the engine zero-timed for a fair price?
Alfred
_________________ _________________________________________ |
Keith.Miller(at)esa.int Guest
Posted: Fri Mar 04, 2011 5:42 am Post subject: Zero timing a O-240-E engine |
Alfred
when you get a price for the windshield , please share the info . also Some
time back we had some discussions on the thickness and the material, maybe
look in the archives
Keith
From: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com>
To: kis-list(at)matronics.com
Date: 04/03/2011 13:28
Subject: Zero timing a O-240-E engine
Sent by: owner-kis-list-server(at)matronics.com
Hi Scott,
Alfred
http://forums.matronics.com/viewtopic.php?p=332731#332731
bakerocb
Posted: Fri Mar 04, 2011 6:05 am Post subject: Zero timing a O-240-E engine |
3/4/2011
Hello Alfred, You wrote: "Does anyone have knowledge of a reliable shop
where I can have the engine zero-timed for a fair price?"
I don't know how the regulations read in your part of the world, but in the
USA the only entity that is authorized to return an engine to zero time
through a remanufacturing or rebuilding process is the original manufacturer
of the engine.
Both Lycoming and TCM have service bulletins published on the subject of
prop strikes or engine sudden stoppages. I will dig them out and post them
if you are interested.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
To: <kis-list(at)matronics.com>
Sent: Friday, March 04, 2011 7:24 AM
Hi Scott,
Alfred
ftyoder(at)yoderbuilt.com Guest
Posted: Fri Mar 04, 2011 7:44 am Post subject: Zero timing a O-240-E engine |
I think the original was 1/8", I had Rich get me one 3/16". If memory
serves, that was in 1993.
BlueSkyFlier
Posted: Fri Mar 04, 2011 8:52 am Post subject: Re: Zero timing a O-240-E engine |
OC,
The manufacturer info about prop strikes you mentioned earlier will be most welcome. I expect that there will be duly licensed shops which can also zero-time an engine. There has been talk of Norvik, but I have not had time to look that up yet.
Alfred
galinhdz(at)gmail.com Guest
Posted: Fri Mar 04, 2011 1:01 pm Post subject: Zero timing a O-240-E engine |
I can highly recommend an engine shop (Zephyr Engines) here in the USA. They did the prop strike rebuild on my engine (Lycoming O-360) 250hrs ago and they did an awesome job.
Galin
On Fri, Mar 4, 2011 at 6:24 AM, BlueSkyFlier <bleuskyfly(at)teledynamix.com (bleuskyfly(at)teledynamix.com)> wrote:
[quote]--> KIS-List message posted by: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com (bleuskyfly(at)teledynamix.com)>
Hi Scott,
Alfred
http://forums.matronics.==========
rowse, Chat, FAQ,
="http://www.matronics.com/Navigator?KIS-List" target="_blank">http://w===
http://forums.m le, List Admin.
fredorosa(at)gmail.com Guest
Posted: Fri Mar 04, 2011 1:27 pm Post subject: Zero timing a O-240-E engine |
Galin,
You need to wait another 1,750 hours before you declare an awesome job.
Al
On Fri, Mar 4, 2011 at 3:58 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote] I can highly recommend an engine shop (Zephyr Engines) here in the USA. They did the prop strike rebuild on my engine (Lycoming O-360) 250hrs ago and they did an awesome job.
Galin
| Quote: | --> KIS-List message posted by: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com (bleuskyfly(at)teledynamix.com)>
Hi Scott,
Alfred
rowse, Chat, FAQ,
et="_blank">http://www.matronics.com/Navigator?KIS-List
| [b]
Posted: Fri Mar 04, 2011 4:12 pm Post subject: Zero timing a O-240-E engine |
Well, with Zephyr Engines being rated #1 in the last 3 AOPA polls there are others out there that feel the same as I do. Besides, I can declare and recommend whatever I want even if you don't agree. ;o)
Galin
On Fri, Mar 4, 2011 at 3:25 PM, ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
[quote] Galin,
Al
| Quote: | I can highly recommend an engine shop (Zephyr Engines) here in the USA. They did the prop strike rebuild on my engine (Lycoming O-360) 250hrs ago and they did an awesome job.
Galin
BlueSkyFlier
Posted: Fri Mar 04, 2011 5:41 pm Post subject: Re: Zero timing a O-240-E engine |
After doing my homework I decided to get the work done this side of the pond. After weeding out the bad apples the potential repair shops are:
http://www.arrowaviationservices.co.uk/page7.php
http://www.nicholsonmclaren.com/
http://norvic.com/en/Lycoming_Continental_Franklin_shockload
CFS at Coventry - http://www.cfsaeroproducts.co.uk/engines.html
Airspeed at Derby - http://www.derbyaeroclub.com/Airspeed.html
Dukeries Aviation, Netherthorpe - Dave Bonsall Netherthorpe, Worksop, Nottinghamshire S80 3JQ, Tel: 01909481802
Multiflight - http://www.multiflight.com/engineering/capabilities-and-approvals.php
CSE - http://www.avbuyer.com/PDFs/CSE%20Page%202.pdf
As the first three are the closest, one of them will most likely be chosen unless significant price advantage comes from one of the remaining lot - transport costs can easily erode the advantage.
Alfred.
bakerocb
Posted: Fri Mar 04, 2011 8:25 pm Post subject: Zero timing a O-240-E engine |
3/4/2011
1) "The manufacturer info about prop strikes you mentioned earlier will be
most welcome."
Please see below links and the attached TCM SB96-11B:
http://www.tcmlink.com/fiddefault.aspx?cgroup=MATTITUCK&cpagename=SS
http://www.lycoming.textron.com/support/publications/service-bulletins/pdfs/SB533A.pdf
2) "I expect that there will be duly licensed shops which can also zero-time
an engine."
In the USA this is not true. Here is an extract from US Part 14 CFR (Code of
Federal Regulations):
"91.421 Rebuilt engine maintenance records.
(a) The owner or operator may use a new maintenance record, without previous
operating history, for an aircraft engine rebuilt by the manufacturer or by
an agency approved by the manufacturer.
(b) Each manufacturer or agency that grants zero time to an engine rebuilt
by it shall enter in the new record-
(1) A signed statement of the date the engine was rebuilt;
(2) Each change made as required by airworthiness directives; and
(3) Each change made in compliance with manufacturer's service bulletins, if
the entry is specifically requested in that bulletin.
(c) For the purposes of this section, a rebuilt engine is a used engine that
has been completely disassembled, inspected, repaired as necessary,
reassembled, tested, and approved in the same manner and to the same
tolerances and limits as a new engine with either new or used parts.
However, all parts used in it must conform to the production drawing
tolerances and limits for new parts or be of approved oversized or
undersized dimensions for a new engine."
What 91.421 is saying:
A} Only a rebuilt (or new) engine gets a new (zero time) maintenance record
(engine log book).
B} An overhauled engine does not get a new (zero time) maintenance record
(engine log book).
C} Only the manufacturer or an agency approved by the manufacturer can
create a rebuilt engine.
Even Teledyne Mattituck Services Inc which is owned by TCM does not use the
term rebuilt in any of their literature, but instead uses the term
overhauled. I am unaware of any agency in the US that either Lycoming or TCM
has approved, other than themselves, to rebuild (zero time) their engines.
What do the regulations in your country permit?
Here is some additional information on this subject:
http://www.mattituck.com/articles/ohterms.htm
http://www.lycoming.textron.com/engines/service/zero-time-rebuilt-engines.html
3) "There has been talk of Norvik, but I have not had time to look that up
yet."
I see only the term overhauled used on their web site:
http://norvic.com/en/Aircraft_engine_overhaul_exchange_shockload_repair
Sent: Friday, March 04, 2011 11:52 AM
Subject: Re: Zero timing a O-240-E engine
OC,
Alfred
 Download |
| Filename: |
SB96-11B.pdf |
42.32 KB |
| Downloaded: |
1123 Time(s) |
BlueSkyFlier
BlueSkyFlier
Posted: Mon Mar 07, 2011 7:42 am Post subject: Re: Zero timing a O-240-E engine |
Hallo Scott,
(Replying in this thread to your message in the "Wing Fairing" tread.)
Upon meeting, the Cessna's aileron and my prop shook hands first. Both being sharp edged, that would have helped to take the worst edge off the engine shock profile. The remaining stubs passed freely beneath the wing before splintering further against the side of the Cessna's engine compartment - the alu panels giving way would have helped to slow the engine down. The very tip of the quite prominent spinner then got jammed somewhere on the Cessna engine mounting and stalled the engine as the spinner's alu shell twisted somewhat - but no damage to spinner attachment points or any other part of the engine assembly (besides cooling intake and a slight shift on top left engine mounting rubber).
So, all things considered, the engine was spared as much as one could have hoped for in any event. It does still turn over by hand with good compression and no strange sounds. I'll do a compression check and starter churn check before firing her up again - only briefly due to lack of air flow. Then we'll take the engine off.
With a complete top overhaul (incl magnetos, starter and carb) done only 50 hours ago, I am hoping that the inspection/repair can be facilitated/expedited by taking it to the same shop. Hopefully they will allow me to do most of the stripping and assembly - once again I'll learn (have rebuilt a couple of Anglia and Suzuki engines in my misspent youth) and save a few bob too.
The forum information regarding alternator linkage will come in handy too.
Alfred
