PORT SIDE FAIRING
bakerocb
PostPosted: Fri Mar 04, 2011 5:49 am    Post subject: PORT SIDE FAIRING Reply with quote
3/4/2011
Hello Alfred, You wrote: ".....damage to bottom part of port side fairing is
such that it needs to be replaced/rebuilt."
and
"If you know where one can still get that fairing part plse let me know?"
It is a bit difficult to give specific advice on the part involved without
seeing a picture of the damage, but please let me comment in anticipation.
A) The original kit provided bottom of the wing fairings did not work at all
for me. My solution was to position the fuselage upside down and install the
wing.
B) Then I bridged the entire area to be faired with multiple strips of tape
that epoxy would not stick to.
C) Then I put a few layers of epoxy soaked fiberglass on the tape and let it
cure.
D) Then I removed the fairly stiff leather like piece of fiberglass fairing,
removed the tape covering the gap, trimmed the fairing edges, and used that
layup as my lower wing fairing.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
PS: Keep in mind that Julian Bond did extensive wing fairing mods to his KIS
TR-1. I have attached just one of the pictures that are available.
Hi Rich,
Chuckle ... yes, going in a circle is a good way to get nowhere fast :O)
Judged by the eye, linear speed in the arc was 8-10 miles/hr when left
wingtip connected the side of Cessna's tail section. The wing did flex
backward a bit and the hinge of the flap actuator was bent approx half an
inch out of line. The wing will have to come off anyway because flap
actuator mechanism needs work and damage to bottom part of port side fairing
is such that it needs to be replaced/rebuilt.
Good news is that there are no cracks whatsoever in fuselage or spar box
attachment (which was built much stronger than specified) Firewall and
engine mount is fine too. The plane had a huge aluminium spinner which
absorbed most of the impact and shock.
Besides fixable damage to left wing tip front corner, other airframe damage
is constrained to wing fairings and rudder actuator hinge mechanism. Photos
will follow once insurance matters are resolved.
The list of glass fibre repair items include:
1) cowling top and bottom left front side
2) left wing fairing (extensive)
3) right wing fairing (negligible)
3) starboard side of tail fin (scratches and one small perforation)
4) left wing tip front corner
5) fibre panel to front of left flap actuator hinge has a hole in it.
6) topside of left wing has scratches and a shallow dent just to inside fuel
cap but is not pulverised or cracked (from sliding underneath the tail
section of Cessna)
7) port hatch to be re-attached and scratches on top side of cabin to be
mended
Cool windscreen to be replaced
Rudder modifications, zero timed engine and complete repaint to round it all
off.
Alfred
 Filesize:  649.74 KB
 Viewed:  23973 Time(s)
kentpyle(at)iland.net
PostPosted: Fri Mar 04, 2011 12:33 pm    Post subject: PORT SIDE FAIRING Reply with quote
Alfred, first of all. I am sorry to hear bout your mishap and your resolve
to fix everything back is a good thing.
My kit did not come with the farings, so I made my own by using the top of
the wing as the pattern. I layed tape on the surface so the glue would not
stick. Then 4 layers of fiberglass cloth. I epoxyed glued that and let it
in place for a couple of days. When I peeled the fibeglass from the upper
surface, and trial fitted it in place it fit suprisingly well considering
the curvatures wee not the same. After using #8 counterset screws every 4
inches on both sides, it conforms to the contures very well.
Rich was able to get me a replacement faring. Kent
BlueSkyFlier
PostPosted: Fri Mar 04, 2011 12:40 pm    Post subject: Re: PORT SIDE FAIRING Reply with quote
Thanks OC.
That confirms the thoughts I had. The difficult part is getting the plane upside down with gear and all Very Happy. Empty weight without engine is ~ 720 lb. but nothing is impossible.
I could use inflatable mattress to put pressure on layups from below.
- Alfred
_________________________________________
bakerocb
PostPosted: Fri Mar 04, 2011 2:36 pm    Post subject: PORT SIDE FAIRING Reply with quote
3/4/2011
1) "The difficult part is getting the plane upside down with gear and
all...."
That is very true, but I bet that if you had the engine, nose gear, and
wing off (may be a very likely configuration in the process of your repair)
the plane could be tipped over going nose down tail up. It is not that hard
to rig sling straps for the fuselage to rest in while upside down.
Also consider that one can make epoxy - fiberglass layups onto an overhead
surface. It is more difficult than having gravity to help you, but it can be
done.
2) "I could use inflatable mattress to put pressure on layups from below."
An excellent idea -- thin plywood between the matress and the fiberglass
layup with a release surface and peel ply on the plywood could create a very
nice fairing surface ready for filling, priming, and painting.
OC
From: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com>
To: <kis-list(at)matronics.com>
Sent: Friday, March 04, 2011 3:40 PM
Subject: Re: PORT SIDE FAIRING
Thanks OC.
- Alfred
ftyoder(at)yoderbuilt.com
PostPosted: Fri Mar 04, 2011 3:06 pm    Post subject: PORT SIDE FAIRING Reply with quote
I went a different direction with the bottom fairings. I made them out of
thin Aluminum sheet and screwed them on. They make large inspection doors
and were easy fit.
If you are interested I could take some photos and post them.
Robert Reed
PostPosted: Fri Mar 04, 2011 3:53 pm    Post subject: PORT SIDE FAIRING Reply with quote
Much easier to use some plastic, tape, and vacuum.
To: kis-list(at)matronics.com
Sent: Fri, March 4, 2011 2:40:31 PM
--> KIS-List message posted by: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com (bleuskyfly(at)teledynamix.com)>
Thanks OC.
- Alfred
http://forums.matronics.com/viewtopic.php?p=332784#332784[b]
richard_trickel(at)yahoo.
PostPosted: Sat Mar 05, 2011 10:38 am    Post subject: PORT SIDE FAIRING Reply with quote
Alfred
Make the fairing on the top skin as referred to earlier. The difference is minimal and the material is flexible enough to work. Just trim and put in place. No need to flip the plane over.
Rich
To: kis-list(at)matronics.com, bleuskyfly(at)teledynamix.com
Date: Friday, March 4, 2011, 10:31 PM
--> KIS-List message posted by: <bakerocb(at)cox.net (bakerocb(at)cox.net)>
3/4/2011
1) "The difficult part is getting the plane upside down with gear and all...."
That is very true, but I bet that if you had the engine, nose gear, and wing off (may be a very likely configuration in the process of your repair) the plane could be tipped over going nose down tail up. It is not that hard to rig sling straps for the fuselage to rest in while upside down.
Also consider that one can make epoxy - fiberglass layups onto an overhead surface. It is more difficult than having gravity to help you, but it can be done.
An excellent idea -- thin plywood between the matress and the fiberglass layup with a release surface and peel ply on the plywood could create a very nice fairing surface ready for filling, priming, and painting.
OC
From: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com (bleuskyfly(at)teledynamix.com)>
To: <kis-list(at)matronics.com (kis-list(at)matronics.com)>
Thanks OC.
nbsp; --> http://www.matronics.com/con=================
BlueSkyFlier
PostPosted: Sat Mar 05, 2011 10:59 am    Post subject: Re: PORT SIDE FAIRING Reply with quote
Much obliged for the sage advice Rich.
Since the front part of the port upper fairing is also somewhat damaged that makes a lot of sense. Together with Tim's idea of using thin plate below the wing I think this repair issue is now resolved.
I'll get a professional to handle the wingtip, dent on topside of the wing and the tail fin.
The rest is easy enough if I can source a stock 3/16" windscreen from the guys in Los Alamitos who apparently have the mold.
Alfred
sstearns2(at)yahoo.com
PostPosted: Sat Mar 05, 2011 5:34 pm    Post subject: PORT SIDE FAIRING Reply with quote
I think the best way to make the lower wing fairings is to get the airfoil coordinates off the web and cut two templates and make a sandwich with a block of low density foam and use a long sanding board to sand the foam to match the templates. I think you could make a nice mold in an hour or less and it would be the correct shape.
I made my lower fairings and my wingtips by laying up on the wing itself and I don't think using the top of the wing as a mold would produce a good quality part.
I would try to avoid dropping the wing unless you have to. There's a fair amount of risk of damaging things during the demate procedure and it might be a real challenge getting it all lined up again.  You can jack the wing up under the spar and remove one bolt at a time to inspect the bolts and bushings.
As for the engine... I assume you were running a wood prop? A lot of people I know would just check the runout on the crank and call it good after a low power prop strike with a wood prop.
Scott
Date: Saturday, March 5, 2011, 10:59 AM
Alfred
http://forums.matronics.com/viewtopic.php?p=332853#332853http://www.matronics.com/Navigator?KIS-Listhttp://forums.matronbsp; - List Contribution Web Site -http://www=======================
PostPosted: Sat Mar 05, 2011 6:05 pm    Post subject: PORT SIDE FAIRING Reply with quote
Scott, it madea very good quality part!! Kent
PostPosted: Sat Mar 05, 2011 7:40 pm    Post subject: PORT SIDE FAIRING Reply with quote
It seems to me it wouldn't fit well at the leading edge, but maybe your fairings are different than mine.
You can just make a layup on a flat table and make it work as long as you don't have to go around the leading edge very far, but I think with a little more effort you can make a part that matches the curve of the wing.
Scott
--- On Sat, 3/5/11, kent pyle <kentpyle(at)iland.net> wrote:
Subject: Re: Re: PORT SIDE FAIRING
Date: Saturday, March 5, 2011, 6:03 PM
PostPosted: Sun Mar 06, 2011 9:14 am    Post subject: PORT SIDE FAIRING Reply with quote
Scott, mine still fits very well. Kent
PostPosted: Sun Mar 06, 2011 11:05 pm    Post subject: PORT SIDE FAIRING Reply with quote
Did some reading about prop strikes.  The engine shop websites all say there is no way to know what might be wrong in the engine without tearing it down, but with a wood prop the chances of anything being damaged are less.
One specific area on Continental engines to look at seems to be the gearing to the alternator.
Very curious to hear what they find (or hopefully don't find) during the teardown.
Scott
Date: Saturday, March 5, 2011, 5:30 PM
Scott
--> KIS-List message posted by: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com>
  Alfred
http://forums.matronics.com/viewtopic.php?p=332853#332853 http://www.matronics.com/Navigator?KIS-List http://forums.matronbsp; - List Contribution Web Site - http://www=======================
=nofollow target=_blank>http://www.matronics.com/Navigator?KIS-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
gbrighton(at)skymesh.com.
PostPosted: Mon Mar 07, 2011 3:08 am    Post subject: PORT SIDE FAIRING Reply with quote
Alfred,
Hope i'm wrong .. but if have wing root fairing damage and
damaged Flap hinge ... it sounds like u could have damage at the rear spar
attach point ..... mine fractured there during a forced landing ..and my
wing didn't have any impact at all ..
Attached are the Pics of my damage ... i have a fix under way but other jobs
are taking priority at the moment ..
Graham
KIS TR1 #80
BlueSkyFlier
PostPosted: Mon Mar 07, 2011 6:51 am    Post subject: Re: PORT SIDE FAIRING Reply with quote
Hi Graham,
After working through the builder's manual over the weekend I arrived at the same conclusion.
Rich did of course spot that in the first instance and said that repairing the rear spar bushing would not be difficult. So I'm not too worried as we also did not notice anything amiss there during the first inspection. I shall surely take a closer look at that particular area tomorrow.
Perhaps I'll even drop the wing tomorrow ... Scott's advice to avoid dropping the wing is sound, but I need to be sure about the spar after the unusual loading from the top it got from the Cessna's tail section. By doing it myself I'll learn quite a bit about the plane. Besides, it will save me a bit on the repair and the repaint of the wing (and perhaps even reduce hangar fees if I reduce the area occupied for the time being Surprised).
Will take some pictures tomorrow.
Alfred
BlueSkyFlier
PostPosted: Fri Mar 11, 2011 9:50 am    Post subject: Re: PORT SIDE FAIRING Reply with quote
TO: Graham (Brighton)
Graham,
The message you posted on Monday mentions some attached pictures, but I don't see any pictures via the message board.
I tried contact you directly but the mail address does not resolve.
Would you be so kind as to send the pics you mentioned directly to me at the following address?: blueskyflier(at)teledynamix.com
Thanks and regards,
Alfred
PostPosted: Sun Mar 13, 2011 4:01 am    Post subject: PORT SIDE FAIRING Reply with quote
G'Day back Alfred,
Been a couple of days away ..... don't know
why u couldn't receive/open the Pics i attached previously but i'll resend
them to u direct ..
Graham
