Keith.Miller(at)esa.int Guest
Posted: Fri Mar 04, 2011 2:22 am Post subject: IO-240B With the 15V 60A TCM alternator |
Hopefully mine will last a bit longer , but good to know that there are some
options
From: "helixaviation(at)googlemail.com" <helixaviation(at)btinternet.com>
To: kis-list(at)matronics.com
Date: 04/03/2011 11:11
Subject: Re: IO-240B With the 15V 60A TCM altinator
Sent by: owner-kis-list-server(at)matronics.com
Keith. My alternator drive coupling failed after about 50 hours. I put it
down to kickback on startup and had the mags retarded a little. The original
coupling was elastomeric and had failed in sheer. I managed to locate an
alternative style that was mechanical but has rubber inserts for shock
absorbtion. I got it second hand and from memory only cost about £100. John
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
Keith.Miller(at)esa.int wrote:
want to hear , my IO240B is just coming up to 400hrs , but thanks for
sharing it with us anyway , at least the shock will be less when it
eventually happens to mine Keith From: "F. Tim Yoder"
<ftyoder(at)yoderbuilt.com> To: <kis-list(at)matronics.com> Date: 04/03/2011
04:09 Subject: IO-240B With the 15V 60A TCM altinator Sent by:
owner-kis-list-server(at)matronics.com FYI, I was fly a couple weeks ago and
lost The Alt. I determined that the Alt. was not producing power and
removed it. I am sure Cont. could have made that job harder if they tried.
I found the Alt. was ok but the Alt. Drive Coupling Assembly (P/N 635796)
was broken, the Lord rubber mount came loose from the ss shroud. Better if
the Alt was bad. The bad news is that Cont. wants $2077.00 for this part,
no, the engine is not included! The not so bad news is that Drake rebuilds
them and they can be had for $600.00 to $900.00, with a good core. I only
had a little over 400 hrs. on the engine. I had to remove a Slick Mag to
get the Alt. out, so I had the mag 500 hr service done. New points and
replaced a bad gear. So for only a $1000.00 + I now have lots of amps &
volts. Hope you have the "good" ones!
