BlueSkyFlier
Posted: Tue Mar 01, 2011 7:04 am Post subject: Are your rudder pedals safe? |
Fellow KIS owners,
Now that the formalities have been dealt with, I can share with you that I had the misfortune to be involved in a hapless accident on the ground last week. I would like to share my experience with other KIS TR-1 owners; perhaps it can help prevent a similar incident.
A copy of section 16 of the aircraft accident reporting form below conveys the essential information.
16 YOUR ASSESSMENT OF THE CAUSE
My right foot slipped off the starboard rudder pedal at crucial moment whilst straightening out the steering nose wheel upon commencing the second stage/leg of a taxiing manoeuvre intended to take me away from the disembarkation area. Despite a tightly strapped full harness, the unexpected forward lurch of right hip and shoulder resulted in an inadvertent knock-on to the throttle, increasing the engine rpm setting substantially beyond my self-imposed limit for taxiing on tarmac. To fill up the mug of misfortune, the uppers of my shoe heel caught on the rear edge of the starboard pedal or brake hinge upon pull-back, effectively locking in a turn to port side whilst also rendering me incapable of braking and/or steering effectively. Three seconds later, with foot still stuck, it was all over with two aircraft substantially damaged and probably destinied to be written off.
Safety factors: (specifically relevant to other KIS TR-1 owners)
1) Rudder pedals should be aligned squarely with pilot’s hips, not offset at an angle inboard. The vertical angle of rudder and brake pedal should allow full surface contact with pilot’s foot at all times and pedal surfaces should have high friction coefficient.
2) The release mechanism on a vernier throttle should be operated by pulling action on a bell shaped slider or finger hook at the rear of the throttle knob (as on automatic gear shift levers of many vehicles) so as to automatically enable reduction in power when pilot pulls on the throttle control mechanism from the rear. Activating the release mechanism by depressing a knob from the front allows for inadvertent escalation in power by knock-on at front of the throttle control, whereas it does not facilitate reduction in power when pilot tries to pull/tug it the throttle outwards in an emergency situation.
The accident resulted in the destruction of two aircraft, mine and another which was parked. Fortunately, I did adhere to my rule not to start up or taxi when there are people moving around airside and by God’s grace I escaped with nothing but a headache and a few scratches.
Please take the time to critically re-inspect your rudder pedal configuration - I suspect many of you have the same smooth and rather skimpy pedals which my aircraft is fitted with. If it is at all possible that your rudder pedals could enable/allow the same accident to happen – do not postpone getting proper pedals fitted. I did, and it cost me dearly.
Having insured the hull only for the amount I paid for it, it seems that it will be more cost effective for the insurance company to scrap it. So it seems that I may soon be looking for another KIS TR-1 to buy.
These things do happen in the blink of an eye, so please watch your step (on the pedals and everywhere).
Kind regards,
Alfred
_________________ _________________________________________ |
teds532(at)wk.net Guest
Posted: Tue Mar 01, 2011 7:43 am Post subject: Are your rudder pedals safe? |
I have the rudder pedals out of a 75 Cessna in my kis cruiser.If you are
interested in building another Kis I have a Kis TR4 for sale with a new all
balanced fuel injected lycoming XP360 180 hp engine built by Mattituck.I am
about 65% finished,I will take any reasonable offer.I am 79 years old and do
not think that I will be flying any more.You can see some of my work
building this airplane on the buiders web site.Ted Scott.phone 731 247 5643
bakerocb
Posted: Tue Mar 01, 2011 9:25 am Post subject: Are your rudder pedals safe? |
3/1/2011
Hello Alfred. I was very saddened to read of your accident.
You wrote:
1) "Please take the time to critically re-inspect your rudder pedal
configuration"
This is a very crucial issue. There are four things wrong with the orginal
KIS TR-1 rudder pedal - brake arrangement.
A) The rudder pedals are too small. This means that one can not get
sufficient leverage when pressing on the top of the pedals to apply the
brakes -- particularly with the early on crappy Matco braking system.
B) There is no means of telling precisely where your foot is located on the
pedal and the foot can slide off the side of the pedal very easily.
Both of these problems can be solved with aluminum angle extensions riveted
onto the original pedals. See the attached picture.
C) The rudder cross bars are too short. This means that in order to place
one's feet properly upon the rudder pedals one must angle one's legs
slightly towards the center line of the airplane -- off a bit to the right
for the pilot.
D) The mechanism for mounting the pedals to the floor board is too weak and
flexible. Considerable beefing up in this area is needed while constructing
the floor boards and any bolt pivot supports should be supported on both
ends, not just cantilevered.
2) "The release mechanism on a vernier throttle......."
I do not recommend vernier controls on a throttle -- just push / pull with a
friction adjustment.
I know that it is small consolation or help to you now Alfred, but the
subject of brake pedal deficiencies in the KIS TR-1 has been written up
several times. Here is one of the earliest postings on this subject found in
the archives from 22 January 1999:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=87656?KEYS=brake_pedals?LISTNAME=KIS?HITNUMBER=29?SERIAL=08552929623?SHOWBUTTONS=YES
I found it necessary eventually to abandon the Matco wheels, brake system,
and pedal cylinders and replace them entirely with Grove wheels, brake
system and pedal cylinders.
OC
From: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com>
To: <kis-list(at)matronics.com>
Sent: Tuesday, March 01, 2011 10:04 AM
Subject: Are your rudder pedals safe?
Fellow KIS owners,
1) Rudder pedals should be aligned squarely with pilot's hips, not offset at
full surface contact with pilot's foot at all times and pedal surfaces
taxi when there are people moving around airside and by Godâ?Ts grace I
rudder pedals could enable/allow the same accident to happen â?" do not
Kind regards,
Alfred
19.82 KB |
10667 Time(s) |
sstearns2(at)yahoo.com Guest
Posted: Tue Mar 01, 2011 9:33 am Post subject: Are your rudder pedals safe? |
Ahhh, what terrible news....
I, and a few others, have installed alternate rudder pedals using larger pedals and a generally more robust system. The vernier throttle was not included or specified in the kit to my knowledge.
Hopefully you can find a good replacement...
Scott
--- On Tue, 3/1/11, BlueSkyFlier <bleuskyfly(at)teledynamix.com> wrote:
To: kis-list(at)matronics.com
Date: Tuesday, March 1, 2011, 7:04 AM
--> KIS-List message posted by: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com (bleuskyfly(at)teledynamix.com)>
Fellow KIS owners,
Kind regards,
Alfred
http://forums.matronics.com/viewtopic.php?p=332363#332363
http://www.matronics.com/Navigator?KIS-List< - ; -Maww.matronics.com/contribution" target=_blank>http://www.matronics.com/con=================
Posted: Tue Mar 01, 2011 10:05 am Post subject: Are your rudder pedals safe? |
THE RUDDER PEDALS SHOULD BE AS SAFE AS THEY WERE IN THE IN THE 76
CARDINAL.THERE ARE PHOTOS ON THE KIS WEB SITE
ftyoder(at)yoderbuilt.com Guest
Posted: Tue Mar 01, 2011 4:22 pm Post subject: Are your rudder pedals safe? |
Sorry to hear that, thanks for the information.
gbrighton(at)skymesh.com. Guest
Posted: Tue Mar 01, 2011 6:35 pm Post subject: Are your rudder pedals safe? |
Yep ..second that ..very sorry to hear about ur accident too ...glad u are
ok though ..
Graham
jpetrie(at)sonicfactory.c Guest
Posted: Tue Mar 01, 2011 9:21 pm Post subject: Are your rudder pedals safe? |
I'm really sorry to hear of your mishap Alfred.
I know of a Glasair on its way back to you if you're interested
| Quote: | From: BlueSkyFlier <bleuskyfly(at)teledynamix.com>
Reply-To: <kis-list(at)matronics.com>
Date: Tue, 1 Mar 2011 07:04:26 -0800
Fellow KIS owners,
Kind regards,
Alfred
Keith.Miller(at)esa.int Guest
Posted: Wed Mar 02, 2011 12:50 am Post subject: Are your rudder pedals safe? |
Alfred ,
sorry to hear about the accident , what damage was done to the KIS ? .f you
need any advise on repairing it , this forum is the best place to ask for
help
Going back to your particular KIS. Clearly some non- standard
modifications were made during the build , the Cessna steerable Nose gear
being one of them, which probably has not helped in this particular accident
, as the castoring nose gear would have straightened it self under power,
assuming one brake was not locked up .
The choice of a vernier or push pull throttle was a personal choice made
by the builder , it was not specified in the build manual., and I suspect
not many of us have gone that route , as I can see little advantage of such a
throttle on a single engine and my inspector in the UK would not have
agreed to one , after he had a similar experience flying one fitted to a
Kitfox.
For my KIS , I did not like the offset pedals from the first moment I
mounted them and sat in the plane, it clearly felt wrong so they were
modified quite easily by cutting and welding the pilots left Pedal and
Co-pilots right pedal exactly in the opposite direction , this eliminates
the off set feeling completely Plus as OC mentions adding aluminium
plates to the pedals to make them easier to find and operate
I do not remember the builder of your KIS participating to this forum ,
which is a pity since most of this was discussed over the years ,
Keith
Date: 01/03/2011 16:06
Sent by: owner-kis-list-server(at)matronics.com
Fellow KIS owners,
Kind regards,
Alfred
John Jackson
Joined: 27 Mar 2010 Posts: 14 Location: Shrewsbury, UK
Posted: Wed Mar 02, 2011 1:12 am Post subject: Are your rudder pedals safe? |
Alfred. Terrible news.
I have the vernier throttle on my Kis and quite like it as it allows fine MAP adjustments as i have an electric variable pitch prop.
I know of a part-built Kis in the UK that may be available for sale. From memory its got a Subaru engine conversion. Failing that, I would consider letting mine go for the right offer.
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
Keith.Miller(at)esa.int wrote:[quote] --> KIS-List message posted by: Keith.Miller(at)esa.int Alfred , sorry to hear about the accident , what damage was done to the KIS ? .f you need any advise on repairing it , this forum is the best place to ask for help Going back to your particular KIS. Clearly some non- standard modifications were made during the build , the Cessna steerable Nose gear being one of them, which probably has not helped in this particular accident , as the castoring nose gear would have straightened it self under power, assuming one brake was not locked up . The choice of a vernier or push pull throttle was a personal choice made by the builder , it was not specified in the build manual., and I suspect not many of us have gone that route , as I can see little advantage of such a throttle on a single engine and my inspector in the UK would not have agreed to one , after he had a similar experience flying one fitted to a Kitfox. For my KIS , I did not like the offset pedals from the first moment I mounted them and sat in the plane, it clearly felt wrong so they were modified quite easily by cutting and welding the pilots left Pedal and Co-pilots right pedal exactly in the opposite direction , this eliminates the off set feeling completely Plus as OC mentions adding aluminium plates to the pedals to make them easier to find and operate I do not remember the builder of your KIS participating to this forum , which is a pity since most of this was discussed over the years , Keith From: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com> To: kis-list(at)matronics.com Date: 01/03/2011 16:06 Subject: Are your rudder pedals safe? Sent by: owner-kis-list-server(at)matronics.com --> KIS-List message posted by: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com> Fellow KIS owners, Now that the formalities have been dealt with, I can share with you that I had the misfortune to be involved in a hapless accident on the ground last week. I would like to share my experience with other KIS TR-1 owners; perhaps it can help prevent a similar incident. A copy of section 16 of the aircraft accident reporting form below conveys the essential information.16 YOUR ASSESSMENT OF THE CAUSE My right foot slipped off the starboard rudder pedal at crucial moment whilst straightening out the steering nose wheel upon commencing the second stage/leg of a taxiing manoeuvre intended to take me away from the disembarkation area. Despite a tightly strapped full harness, the unexpected forward lurch of right hip and shoulder resulted in an inadvertent knock-on to the throttle, increasing the engine rpm setting substantially beyond my self-imposed limit for taxiing on tarmac. To fill up the mug of misfortune, the uppers of my shoe heel caught on the rear edge of the starboard pedal or brake hinge upon pull-back, effectively locking in a turn to port side whilst also rendering me incapable of braking and/or steering effectively. Three seconds later, with foot still stuck, it was all over with two aircraft substantially damaged and probably destinied to be written off. Safety factors: (specifically relevant to other KIS TR-1 owners) 1) Rudder pedals should be aligned squarely with pilot’s hips, not offset at an angle inboard. The vertical angle of rudder and brake pedal should allow full surface contact with pilot’s foot at all times and pedal surfaces should have high friction coefficient. 2) The release mechanism on a vernier throttle should be operated by pulling action on a bell shaped slider or finger hook at the rear of the throttle knob (as on automatic gear shift levers of many vehicles) so as to automatically enable reduction in power when pilot pulls on the throttle control mechanism from the rear. Activating the release mechanism by depressing a knob from the front allows for inadvertent escalation in power by knock-on at front of the throttle control, whereas it does not facilitate reduction in power when pilot tries to pull/tug it the throttle outwards in an emergency situation.The accident resulted in the destruction of two aircraft, mine and another which was parked. Fortunately, I did adhere to my rule not to start up or taxi when there are people moving around airside and by God’s grace I escaped with nothing but a headache and a few scratches. Please take the time to critically re-inspect your rudder pedal configuration - I suspect many of you have the same smooth and rather skimpy pedals which my aircraft is fitted with. If it is at all possible that your rudder pedals could enable/allow the same accident to happen – do not postpone getting proper pedals fitted. I did, and it cost me dearly. Having insured the hull only for the amount I paid for it, it seems that it will be more cost effective for the insurance company to scrap it. So it seems that I may soon be looking for another KIS TR-1 to buy. These things do happen in the blink of an eye, so please watch your step (on the pedals and everywhere). Kind regards, Alfred --------Read this topic online here: [quote][b]
richard_trickel(at)yahoo. Guest
Posted: Wed Mar 02, 2011 4:33 am Post subject: Are your rudder pedals safe? |
Alfred
Sorry to here of your mishap. I hope the plane can be repaired. Is there a possibility that you could send me pictures of the damage to your plane. It would take a lot to total it so hope for the best.
Rich
--- On Wed, 3/2/11, helixaviation(at)googlemail.com <helixaviation(at)btinternet.com> wrote:
From: helixaviation(at)googlemail.com <helixaviation(at)btinternet.com>
Subject: Re: Are your rudder pedals safe?
Date: Wednesday, March 2, 2011, 9:08 AM
Keith.Miller(at)esa.int wrote: | Quote: | --> KIS-List message posted by: Keith.Miller(at)esa.int Alfred , sorry to hear about the accident , what damage was done to the KIS ? .f you need any advise on repairing it , this forum is the best place to ask for help Going back to your particular KIS. Clearly some non- standard modifications were made during the build , the Cessna steerable Nose gear being one of them, which probably has not helped in this particular accident , as the castoring nose gear would have straightened it self under power, assuming one brake was not locked up . The choice of a vernier or push pull throttle was a personal choice made by the builder , it was not specified in the build manual., and I suspect not many of us have gone that route , as I can see little advantage of such a throttle on a single engine and my inspector in the UK would not have agreed to one , after he had a similar experience flying one fitted to a Kitfox. For my KIS , I did not like the offset pedals from the first moment I mounted them and sat in the plane, it clearly felt wrong so they were modified quite easily by cutting and welding the pilots left Pedal and Co-pilots right pedal exactly in the opposite direction , this eliminates the off set feeling completely Plus as OC mentions adding aluminium plates to the pedals to make them easier to find and operate I do not remember the builder of your KIS participating to this forum , which is a pity since most of this was discussed over the years , Keith From: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com> To: kis-list(at)matronics.com Date: 01/03/2011 16:06 Subject: Are your rudder pedals safe? Sent by: owner-kis-list-server(at)matronics.com --> KIS-List message posted by: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com> Fellow KIS owners, Now that the formalities have been dealt with, I can share with you that I had the misfortune to be involved in a hapless accident on the ground last week. I would like to share my experience with other KIS TR-1 owners; perhaps it can help prevent a similar incident. A copy of section 16 of the aircraft accident reporting form below conveys the essential information. 16 YOUR ASSESSMENT OF THE CAUSE My right foot slipped off the starboard rudder pedal at crucial moment whilst straightening out the steering nose wheel upon commencing the second stage/leg of a taxiing manoeuvre intended to take me away from the disembarkation area. Despite a tightly strapped full harness, the unexpected forward lurch of right hip and shoulder resulted in an inadvertent knock-on to the throttle, increasing the engine rpm setting substantially beyond my self-imposed limit for taxiing on tarmac. To fill up the mug of misfortune, the uppers of my shoe heel caught on the rear edge of the starboard pedal or brake hinge upon pull-back, effectively locking in a turn to port side whilst also rendering me incapable of braking and/or steering effectively. Three seconds later, with foot still stuck, it was all over with two aircraft substantially damaged and probably destinied to be written off. Safety factors: (specifically relevant to other KIS TR-1 owners) 1) Rudder pedals should be aligned squarely with pilot’s hips, not offset at an angle inboard. The vertical angle of rudder and brake pedal should allow full surface contact with pilot’s foot at all times and pedal surfaces should have high friction coefficient. 2) The release mechanism on a vernier throttle should be operated by pulling action on a bell shaped slider or finger hook at the rear of the throttle knob (as on automatic gear shift levers of many vehicles) so as to automatically enable reduction in power when pilot pulls on the throttle control mechanism from the rear. Activating the release mechanism by depressing a knob from the front allows for inadvertent escalation in power by knock-on at front of the throttle control, whereas it does not facilitate reduction in power when pilot tries to pull/tug it the throttle outwards in an emergency situation. The accident resulted in the destruction of two aircraft, mine and another which was parked. Fortunately, I did adhere to my rule not to start up or taxi when there are people moving around airside and by God’s grace I escaped with nothing but a headache and a few scratches. Please take the time to critically re-inspect your rudder pedal configuration - I suspect many of you have the same smooth and rather skimpy pedals which my aircraft is fitted with. If it is at all possible that your rudder pedals could enable/allow the same accident to happen – do not postpone getting proper pedals fitted. I did, and it cost me dearly. Having insured the hull only for the amount I paid for it, it seems that it will be more cost effective for the insurance company to scrap it. So it seems that I may soon be looking for another KIS TR-1 to buy. These things do happen in the blink of an eye, so please watch your step (on the pedals and everywhere). Kind regards, Alfred -------- Read this topic online here: | Quote: |
=nofollow target=_blank>http://www.matronics.com/Navigator?KIS-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
mantafs(at)earthlink.net Guest
Posted: Wed Mar 02, 2011 6:04 pm Post subject: Are your rudder pedals safe? |
Hi Alfred,
Sorry to hear about your accident but glad to hear no one was hurt!
Please add me to the camp that thinks a vernier on the throttle is a bad idea. Reducing throttle should not require 2 actions.
Some builders have cut off the inward turned outboard rudder pedal tube and rewelded it so that it is outboard pointing. This allows the outboard rudder pedal to farther outboard so that they can be centered. This will increase stress on the part so really this whole tube assembly should be rebuilt or at least reinforced.
Mark
BlueSkyFlier
Posted: Wed Mar 02, 2011 6:32 pm Post subject: Re: Are your rudder pedals safe? |
Thank you everyone for commiserations expressed.
I am of course thoroughly gutted and miserable about the whole debacle, but spunk is nonetheless slowly seeping back into the spine. Tomorrow we shall take a serious look at the possibility of repairing the plane.
So very glad to hear that you are on the mend Rich! You are right, it does take a lot to total her. You should see the other guy – and he was all metal. Suffice to say I now have a greatly increased respect and appreciation for the strength of a composite plane.
Since the engine will need a shock-load inspection anyway I’ll have it zero-timed in case we decide to repair her. The engine mounting and firewall seemed unperturbed on initial inspection. For the airframe we have two primary challenges (unless others come to light tomorrow).
1) The LAA (PFA) here may argue that the spar was stressed to some extent – to prove the integrity of the wing is a tricky business at the best of times. Hence I’m all the more glad to see you back on the forum Rich. Your opinion will carry considerable clout with the LAA. Since the wing tanks are not leaking I am thinking it can’t be too bad, but what do I know? )
2) I shall be in need of a new windscreen because the chewed-up elevator of the Cessna came slicing through mine. (I’m growing a beard now as that was as close a shave as I want to have for quite some time.)
The port hatch is complete unhinged – hence my headache – and the instrument panel is dislodged, but both those should fairly straightforward to fix. With the collective knowledge and experience of everyone on this forum decisions regarding the best way forward will surely be greatly facilitated. For instance, a few weeks before the accident I spoke to a KIS owner here who described his deregistered KIS as ‘bent’. Quite likely that parts of his plane could be re-usable and I’ll follow that up. (He is now building a Glastar.)
John (Jackson), I would very much like to discuss the options you mentioned. Could you please send your contact details via direct email?
And thank you also to Keith (Miller) for the tip about fixing the alignment of the rudder pedals. Given opportunity, I shall implement that together with OC’s pedal mod.
In case we decide to investigate the repair options further after tomorrow’s inspection I shall open a new thread for that.
Thanks again and best regards to all.
- Alfred
Posted: Wed Mar 02, 2011 8:40 pm Post subject: Are your rudder pedals safe? |
Hi Alfred,
I'm sure if you provide some pictures you will get lots of advise on how to fix.
The new windshield should be easy. The company that has the molds is Aircraft Windshield Company, 562-430-8108 in the Los Angeles area.
What kind of engine do you have?
Scott
Date: Wednesday, March 2, 2011, 6:32 PM
