Need Help with 582 rudder trim
Goto page 1, 2  Next
capt_riney(at)yahoo.com
PostPosted: Thu Feb 24, 2011 8:42 pm    Post subject: Need Help with 582 rudder trim Reply with quote
I'm trying to work out in my head which side of the rudder I need to put the trim tab on. I've got 582 powered mark3 with 3 bladed warp prop. Most of the mark3's I've seen have the trim tab on the left side of the rudder, but I think they were mostly 912 powered and I think that engine rotates opposite the 582. The 582 rotates clockwise aft looking forward, so I believe I'll need right rudder takeoff
Mark Rinehart
N68MR
byoungplumbing(at)gmail.c
PostPosted: Thu Feb 24, 2011 9:14 pm    Post subject: Need Help with 582 rudder trim Reply with quote
Mark Rinehart
N68MR
I need right rudder on take off,,,, and left rudder on approach,,,, the secret to rudder trim is what do you need in straight and level flight. for the short time on takeoff and the short time on glide slope,, you can use the pedals.... what you want to eliminate is the constant rudder pressure during the bulk of the flight. that is what you need to trim out. tell me what you need in level flight, not takeoff, climb out, or decent.
if you really need right rudder trim in level flight.... you should put the tab an the left side of the rudder, and bend it to the left. that will force the rudder to the right,
if you need left rudder in level flight, put the trim tab on the right and bend it to the right, that will force the rudder to the left.
boyd young
mkiii utah
Dana
PostPosted: Fri Feb 25, 2011 3:48 am    Post subject: Need Help with 582 rudder trim Reply with quote
Fly it first, then decide where the tab needs to be... you might get lucky and not need one at all.
-Dana
+REAL+ programmers use EDLIN to create Windows apps
Richard Pike
PostPosted: Fri Feb 25, 2011 7:42 am    Post subject: Re: Need Help with 582 rudder trim Reply with quote
Before you put the trim tab on, hold off for a bit until I try out Kolb's new wing shim bracket. We now have about 2.5 hours on the FSII after the rebuild, and like most all 2 stroke powered Kolbs, it wants to roll left and yaw right under power.
Kolb sells a rear spar bracket that allows you to raise or lower the trailing edge of the wing, and tomorrow we will drop the trailing edge of the left wing by a couple washers and see what happens. The expectation is that it will pick up the left wing and center the ball. If so, no trim tabs needed. Maybe... We'll see...
Richard Pike
MKIII N420P (420ldPoops)
 Filesize:  68.75 KB
 Viewed:  16303 Time(s)
Richard Pike
PostPosted: Sat Feb 26, 2011 1:41 pm    Post subject: Re: Need Help with 582 rudder trim Reply with quote
The results are inconclusive. We dropped the left trailing edge about 3/16". The thinking was as follows: It wants to roll left and yaw right, so we will drop the left trailing edge to pick up the left wing, and the additional drag on the left side will pull the nose left and bring the ball back to the middle.
In hindsight 3/16" was way too much. It kicked the ball out of the box to the right as the drag on the left side went way up, and it still wanted to roll left. Also it just plain felt screwed up, since it was trying to fly cross-controlled with left roll and left slip.
So we put it back like it was and I came home - I had flown to a nearby airport for the EAA meeting and burgers, and the wind was constantly increasing as the day progressed, so had to cut things short. My strip is one way in, one way out, and landing with a ten+ mph tailwind is not one of my favorite things to do. So called it quits for today.
Will try dropping it just one washer this next week and see how that does. Also will call Travis tomorrow for advice.
Richard Pike
PostPosted: Sat Feb 26, 2011 1:57 pm    Post subject: Need Help with 582 rudder trim Reply with quote
Richard Pike
Richard P:
A rudder trim tab corrected a similar problem on the last MKIIIx we tested
three years ago.
I don't think I can describe the way that airplane flew before we got a
rudder trim tab on it. Was a very unnatural feeling, as if the controls
were rigged backwards. Wink
jbhart(at)onlyinternet.ne
PostPosted: Sun Feb 27, 2011 8:07 am    Post subject: Need Help with 582 rudder trim Reply with quote
Richard,
In trying to trim out your plane, it looks like you are getting lost in the
interaction of too many variables. One thing you can do to see if the wings
are set at the same angle of attack is to remove the engine torque from the
mix. Climb to altitude and move the throttle to the idle position, and
maintain your normal cruise speed in a glide with the wings level. Watch to
see what the ball does. If it does not go to zero, you have an asymmetrical
wing rigging problem. Kick rudder pedals and move the stick to put the
plane in a gliding wing level slip to determine which aileron is high and
which aileron is low.
On the ground adjust wing incidence to correct the above problem, and repeat
the above flight until the ball zeros in a no power cruise glide. Then
check what happens at level flight under power. At this point you do not
have very many options. One can place a tab on an aileron or use a
bungee/spring to bias the roll system to level the wings at cruise. This
action will remove all side stick pressure at cruise. Then add a tab to the
rudder or rotate the reduction unit to move the thrust line or a combination
to bring the ball the rest of the way in.
Jack B. Hart FF004
Winchester, IN
Yesterday I saw a kill deer, robins and doves walking around on the snow.
Spring is coming?
Richard Pike
PostPosted: Sun Feb 27, 2011 11:16 am    Post subject: Re: Need Help with 582 rudder trim Reply with quote
Richard,
Jack B. Hart FF004
Winchester, IN
Tried to do that, with the setting as shown in the picture, the wings appear to be at the same angle of attack, however in a power off glide, the ball is slightly out to the left, and the aircraft rolls left. Dropping the left trailing edge and then once again trying a power off glide the ball was way out to the right, and the airplane still rolled left with no changes in roll rate.
I am currently assuming that trim tabs are inevitable, but still open for suggestions on changing the wing angle. In theory (except that we rebuilt a wreck...) I would think it ought to glide straight ahead power off if everything is straight, and it pretty much is. Weather is supposed to be good for three days the middle of this next week, will be doing (hopefully) some more test flights.
To make sure I understand your suggestions correctly, let me read them back with a couple additions to make sure I got the picture. You fly the plane gliding level with the ball centered and then look at the ailerons to see where they are, and then raise or lower the wing with the washers until the ailerons are equal in trail. At this point, I assume that you could turn loose of the stick and it would continue to glide level?
Also at this point you could take your feet off the rudders and the plane would continue to glide straight and level with the ball centered? Or is that an unwarranted assumption, and getting that part fixed requires second step B? Feel free to make suggestions Jack, I consider you the guru in this particular area.
Richard Pike
Richard Pike
PostPosted: Sun Feb 27, 2011 11:17 am    Post subject: Re: Need Help with 582 rudder trim Reply with quote
Roger that! That's why I put it back like it was before flying it home.
Richard Pike
slyck(at)frontiernet.net
PostPosted: Sun Feb 27, 2011 11:33 am    Post subject: Need Help with 582 rudder trim Reply with quote
Richard, let us know how rudder trim affects your ride.
BB
> john h
> mkIII
> Titus, Alabama
Richard Pike
http://forums.matronics.com/viewtopic.php?p=332211#332211
PostPosted: Sun Feb 27, 2011 12:39 pm    Post subject: Need Help with 582 rudder trim Reply with quote
Richard Pike
Richard P:
Initial flight in he newest model MKIIIx resulted in right wing low in
straight and level flight. However, to keep the aircraft in that attitude
required right stick, not left stick. Felt like every control was out of
whack. A couple flight like that and I was ready to give up.
Temporarily stuck a big rudder trim tab on it, same size as on my MKIII.
Next test flight it flew straight with wings level, trim ball centered.
Would have never thought this was all it was going to take to get the job
done.
john h - Kolb tinkerer!!!
PostPosted: Tue Mar 01, 2011 3:51 pm    Post subject: Need Help with 582 rudder trim Reply with quote
At 11:16 AM 2/27/11 -0800, you wrote:
Richard, I have added some thoughts.
First of all even if your plane is perfectly symmetrical in rigging, and
with the throttle closed, it should fall off in the direction that is the
opposite to the propeller rotation. Even though the throttle is closed the
ailerons will have to be moved to counter the propeller driving torque.
Only with the engine shut off and perfect rigging with some dihedral can you
expect to let go of the stick and achieve a level glide. If you glide with
the wings level, neutral rudder, at your normal cruise speed, and the left
and right wings are set at the same angle of attack, the side pressure on
the stick to keep the wings level should be minimal, and the ball should not
be out very far. And you should be able to apply a little rudder to move the
ball in. If this is not the case, I would go back and check the wing rigging.
While assembling the FireFly, I checked the wing rigging by using clear
plastic tubing filled with colored water. First I hung a plumb bob from the
root tube down to the top of the tail boom tube and adjusted or shimmed the
wheel axles so that the cage was true vertical. This makes sure the FireFly
CG is directly below the root tube. Then I hung water levels from tip to tip
atthe main spar point, and then from front to back at the tip and in close
to the fuselage. From these levels one can determine if the wings have
equal dihedral and twist from the other end and at the wing root from side
to side. During construction this was done with A frames supporting the out
end of the wing panels and shims where used to bring the panels into proper
alignment and then the strut tubes were slipped into place marked, drilled
and mounted.
This technique can be used on your aircraft, to see how well you have
reassembled your aircraft. Small plastic tubing is not very expensive, and
water levels work.
step B?
With the engine running at any power setting, one cannot expect the ball
will be center, unless the plane has been trimmed out at that speed and
load.
Sometimes it is necessary to narrow focus by discovering what is not the
problem.
Jack B. Hart FF004
Winchester, IN
Richard Pike
PostPosted: Wed Mar 02, 2011 3:59 pm    Post subject: Re: Need Help with 582 rudder trim Reply with quote
Today I changed the shim again, this time dropping the left wing trailing edge by just one washer. Went flying just before sunset, zero wind and turbulence. WooHoo! With with the throttle back to 3,000 rpm - which I am guessing to be somewhere around zero thrust at the hands off 45 mph glide speed - the airplane just barely rolls left, and the ball is almost centered. It is also very easy to hold the airplane level or roll it right or left with rudder. Under cruise power - which with the 582 is 5,000 rpm for 65 mph - using the stick to hold the wings level has the ball in the middle of the cage. Not sure why that is, wasn't what I was expecting, but I'll take it.
Tomorrow I will install the trim tab for the right aileron and see if that will have it flying hands off. Once it is, will see where the ball ends up, and if it need a tab for the rudder.
Bottom line: Kolb's funky rear wing attach bracket did the job. Thanks guys.
Richard Pike
pj.ladd(at)btinternet.com
PostPosted: Thu Mar 03, 2011 10:51 am    Post subject: Need Help with 582 rudder trim Reply with quote
Hi Richard,
dont understand why you are so interested in being trimmed accurately in the
glide. As soon as you apply power it will be wrong. How much time do you
spend gliding?
Trim it accurately for cruise, surely.
Before you start fixing bits of tim to the rudder etc. try some draught
excluder. I have some which is designed with a flat piece and a tube.
Normally the flat fixes to a door and the tube fills the gap around a door
or window.
My Extra tended to roll left. I lowered the trailing edge of the left wing
to increase the angle of attack and get a bit more lift. A bit of draught
excluder on the rudder plus Johns patented stick grabber to compensate for
sitting to one side and she is fine.
Good luck
Pat
cspoke
PostPosted: Thu Mar 03, 2011 11:29 am    Post subject: Re: Need Help with 582 rudder trim Reply with quote
Pat, I also dropped the left trailing edge on my Xtra. I am waiting for calmer winds to start trimming for yaw. Could you give some more information on your draught excluder? How did you attach it. Maybe some pictures? Thanks
Craig Spoke
Mark111 Xtra
VW Redrive
Lillian, AL
cspoke@mediacombb.net
Richard Pike
PostPosted: Thu Mar 03, 2011 12:48 pm    Post subject: Re: Need Help with 582 rudder trim Reply with quote
pj.ladd(at)btinternet.com wrote:
Hi Richard,
spend gliding?
or window.
Good luck
Pat
It seems reasonable to me that before you trim the airplane properly for cruise, you start off with an airplane that flies straight in the first place. Like Jack said, you narrow your focus by discovering what is not the problem. Now that I have an airplane that flies properly hands off, everything I do from now on is related to cruise power settings, and I don't have to wonder if the basic platform is whopperjawed. I like that.
Not sure what a draught excluder is, but the gap seal that goes on both the top and bottom sides of the center section leaves no gaps. The only gap around the doors is at the top of each door where the hinge leaves a little bit, approx 1/2" long by 1/8" wide, and I doubt that counts for much.
Richard Pike
PS: Non-Kolb related - does anybody else on the list play World of Tanks? If so, contact me off list, maybe we can make a platoon.
PostPosted: Thu Mar 03, 2011 3:06 pm    Post subject: Need Help with 582 rudder trim Reply with quote
Not sure what a draught excluder is,>>
Sorry Richard,#
cultural difference. I don`t know what you call it but in the UK a draught
excluders function is to stop draughts, not on an airplane but around the
house, where doors and windows don`t fit tightly.
Sometimes it is a narrow strip of sticky backed foam. What I am referring to
is, in section, a flat piece of rubber about a sixteenth of an inch in
thickness and half an inch wide. One edge has a rubber tube about the
diameter of a drinking straw fixed to it. Now imagine that as a simple
extrusion available in rolls from which you can cut the length required and
you have it.
I hope that is clear????
It works as a trim when fixed to the trailing edge of control surfaces and
is almost un noticeable..
Cheers
Pat
Now that you know that I hope the rest of the explanation falls into place.
PostPosted: Thu Mar 03, 2011 3:16 pm    Post subject: Need Help with 582 rudder trim Reply with quote
How did you attach it. Maybe some pictures? Thanks>>
Craig,
see my reply to Richard about the configuration.
The flat piece in stuck to the control surface so that the tube part is at
the trailing edge of the control.
I have it fixed to the rudder and for some reason which I now forget, to the
underside of the port elevator. As both sides of the elevator work in unison
I cant see the logic for that but it must have seeme dto work at some point.
I think the bungee stick grabber is the most useful part of the set up.
I am away from tonight for around a week. If I can take a pic. and work out
how to send it I will try on my return
Cheers
Pat
rickofudall
PostPosted: Thu Mar 03, 2011 9:56 pm    Post subject: Need Help with 582 rudder trim Reply with quote
Pat, you have independently discovered the drinking straw Gurney Flap AKA the drinking stray wicker bill. Instead of forming tape around the straw you've refined it by using a stick on rubber extrusion.
Rick Girard
On Fri, Mar 4, 2011 at 1:14 AM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
--> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
Craig,
The flat piece in stuck to the control surface so that the tube part is at the trailing edge of the control.
I have it fixed to the rudder and for some reason which I now forget, to the underside of the port elevator. As both sides of the elevator work in unison I cant see the logic for that but it must have seeme dto work at some point.
I am away from tonight for around a week. If I can take a pic. and work out how to send it I will try on my return
Cheers
Pat
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Thom Riddle
PostPosted: Fri Mar 04, 2011 4:50 am    Post subject: Re: Need Help with 582 rudder trim Reply with quote
Rick,
Rick,
Now you've done it. VGs are so 20th century, we must all now install Gurney Flaps on our airplanes because it " increases lift by altering the Kutta condition at the trailing edge.[4][6] The wake behind the flap is a pair of counter-rotating vortices that are alternately shed in a von Kármán vortex street.[21] ". according to the wikipedia article. Who can resist a sales pitch like this?
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Goto page 1, 2  Next
Page 1 of 2
