radio
davidjoyce(at)doctors.org
PostPosted: Sun Feb 20, 2011 8:30 am    Post subject: radio Reply with quote
Dear All, I wonder whether anyone has an old radio and an old non mode S
transponder, that they might consider parting with at a bargain price for a
good cause. I am involved with a local consortium of schools (headed by
Marling) who are building a Rans S-6 plane provided by the Build a Plane
Project with volunteer supervisors (including me). The plane comes with
basic instruments but without a radio. The school has the flying of the
plane for 150 hrs after its completion, and in the local environment that
would be immensely safer with a radio, but school budgets being in a state
of meltdown, they are not best placed to buy a shiny new one!
So if you have just upgraded from a microair or similar to an
all singing/dancing Garmin SL30 etc, please get in touch.
Regards, David Joyce, G-XSDJ
Bill & Sue
PostPosted: Mon Feb 21, 2011 7:33 am    Post subject: Re: radio Reply with quote
David,
Now, I'd just crossed an sl40 off my list of possible radios because it appears to be a fraction too long to fit the panel... do I infer correctly from your note that it can be made to fit the standard Europa panel after all?
PS sorry, this would be a first one -not a replacement!
PostPosted: Mon Feb 21, 2011 8:09 am    Post subject: radio Reply with quote
Bill, I had rather picked that out of the air as the sort of radio that folk
might upgrade to, although I thought I had said SL30 which has twin Nav as
well as twin com channels. One of those fits very nicely in my Europa XS,
and is a fantastic bit of kit.(Picture attached) If you do mean SL40 then I
imagine that would be the same size or smaller.
 Filesize:  2.22 MB
 Viewed:  6284 Time(s)
trevpond(at)aol.com
PostPosted: Mon Feb 21, 2011 8:56 am    Post subject: radio Reply with quote
I have an SL30 in my Europa G-LINN - fitted straight in the panel.
Trev Pond
On 21 Feb 2011, at 15:56, "David Joyce" <davidjoyce(at)doctors.org.uk> wrote:
[quote] Bill, I had rather picked that out of the air as the sort of radio that folk might upgrade to, although I thought I had said SL30 which has twin Nav as well as twin com channels. One of those fits very nicely in my Europa XS, and is a fantastic bit of kit.(Picture attached) If you do mean SL40 then I imagine that would be the same size or smaller.
richard.churchill-coleman
PostPosted: Mon Feb 21, 2011 9:08 am    Post subject: radio Reply with quote
There's a Eurocontrol consultation underway at the moment to introduce
mandatory 8.33kHz capable transceivers to new fit outs from roughly June
2012, below FL195 as well as the current above FL195 requirement. If
implemented (highly likely) it will also mandate that all new radios offered
on the market after June 2012 must be 8.33kHz capable. As a result Garmin
should be thinking hard about an SL30/SL40 8.33kHz unit for the market early
next year - might be worth holding out for.
Richard C-C
Bill & Sue
PostPosted: Mon Feb 21, 2011 9:19 am    Post subject: Re: radio Reply with quote
Thanks David,
I believe the sl30 and sl40 come in the same size box, just the sl40 lacks the Nav bits as you say, I had measured my panel depth as about 2cm short of the required depth. However this clearly can't be the case!
The SL30 which does indeed look a fantastic peice of kit, but I am currently planning on buying a com-only box and putting the money towards the Garmin G3 ... I'm putting some of the panel in now but although I'm necessarily planning what goes where, the current intention is to delay buying the actual avionics until the last minute.
Thanks to your reassurance I'll look again at the SL40, which was my original preferred choice.
Bill & Sue
PostPosted: Mon Feb 21, 2011 9:29 am    Post subject: Re: radio Reply with quote
Thanks Trev and Richard - that crossed in the aether- I hadn't thought that 8.33 would affect us but methinks you would be the person to know about these things in particular, and that makes another reason to delay buying the electronic bits until I'm a little closer to actually using them.
