rudder pedal pads and heel plate
graeme bird
PostPosted: Mon Feb 21, 2011 4:56 am    Post subject: rudder pedal pads and heel plate Reply with quote
I have been looking for some pictures to show what I should do to make some rudder pedals - don't much like the pipe - too narrow, shall I just make some wood or aluminum blocks and self tap screw on. Also I think I have seen plates at the bottom for ones heels, is that the thing to do?
Help appreciated
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
kevinmarie(at)blueyonder.
PostPosted: Mon Feb 21, 2011 5:17 am    Post subject: rudder pedal pads and heel plate Reply with quote
Graeme
I know what you mean looking at the standard rudder pedals. I thought the same but in use I have never had a problem. They are fine.
Kevin
Help appreciated
Graeme Bird
http://forums.matronics.com/viewtopic.php?p=331706#331706
steven.pitt2(at)ntlworld.
PostPosted: Mon Feb 21, 2011 6:26 am    Post subject: rudder pedal pads and heel plate Reply with quote
Graeme
Sorry can't remember where you are based but I used two footplates produced
by Ripspeed in the UK. They are lightweight aluminium and have ridges and
holes for fitting to the pedals - non slip and ideal for the Europa. The
only problem is you have to buy them in 3s as they are for cars.
Steve Pitt
G-SMDH
PostPosted: Mon Feb 21, 2011 6:36 am    Post subject: rudder pedal pads and heel plate Reply with quote
A picture tells a thousand words.
Steve Pitt
 Filesize:  1022.28 KB
 Viewed:  3943 Time(s)
ptag.dev(at)tiscali.co.uk
PostPosted: Mon Feb 21, 2011 6:53 am    Post subject: rudder pedal pads and heel plate Reply with quote
Hi! Graham.
The rudder pedals (crude though they look) work just fine ....if it "ain't
broke don't fix it" with more weight !
Bob Harrison.
